synocodectool-patch for DSM 7.0+
nakwonelec
On 4/12/2022 at 4:19 AM, phone guy said:
Here you are, from 7.1-42661
Make sure try who can restore original file using SSH. It is test version for 7.1 42661
Please test latest version. I update 7.1-42661 on my repository.
Instruction is same as previous.
On 10/29/2021 at 1:46 PM, nakwonelec said:
ref:
https://github.com/dmc31a42/synocodectool-patch
for DSM 7.0+
I modify a script bug of https://github.com/stl88083365/synocodectool-patch working on DSM 7.0 and pull request.
Before merge, use my repo.
thanks stl88083365 and likeadoc
Right now, I do not have 7.1 system. So, I cannot test in this time. Please, give me feedback. thanks.
If there is any problem, I'll make 7.1 system and will test.
Edited by nakwonelec
1 hour ago, nakwonelec said:
Partially done. From DSM 7.1 CodecPack require synology login.
Except HEVC(HEIF) and AAC, synocodectool patch work in 7.1.
Tested, work like a charm.
Patched and then disable because my server too weak to transcode :))
12 minutes ago, synofreak said:
Hi!
No Problem.😌
cu-ya
maybe i think, it seems aac codec issue
Working on it and I will notice
  • 4 weeks later...
On 5/12/2022 at 8:39 PM, javikobcn said:
Thx for the work but I have such bad luck that my version of dsm(7.1 42661-1) is just the one that is not included, would an update be possible?😂
+1 with this version
vi patch.sh
find line "7.1 42661-0" ,  then add a new line "7.1 42661-1"
sudo ./patch.sh -p
  • Like 2
  • 1 month later...
On 6/1/2022 at 12:40 PM, recoco said:
vi patch.sh
sudo ./patch.sh -p
7.1 42661 Update 3 got released and it is supported using Xpenology. Not sure if the initial patch is still valid and adding "7.1 42661-3" works.
Is it possible to check? I am unable to validate as my test DSM VM is unavailable.
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
Question. Im remote from my xpenology box. Does testing this patch tool on a 7.1-42661 Update 1 break the xpenology from booting up or is it simply that the patch tool doesnt install or work? I would like to try this but just wondering if itll break the loader on the box?
THe link for the 7.1.x doesnt seem to be working.
Lastly, if this doesnt help with HEVC or AAC that what does this codec patch activate? Thanks
Edited by alirz1
Hi all.
so I have a 7.1 42661 dsm xpenology setup. I’ve done this syncocodec patch and it said it was successful. I only use the photos app so there was only a single thing for me to patch.
however I still don’t get HEVC thumbnails in the photos app? Does anything else need to be installed like the advanced media extensions package? Because that won’t install due to the serial check!
EDIT: ok so i read some place else that hevc thumbnails are created if the video was uploaded via the photos app. But not if the video was directly copied from another location into the photos folder. I tested and that does seem to be the case. So now i need to figure out how to have the photos app create thumbnails for the copied hevc files. Re-indexing didnt seem to do anything.
Edited by alirz1
