I need some help (reboot issue)
mene
Hello!
I have xpenology installed on an old Toshiba laptop, with core 2 duo T7200 and intel express chipset 945gm.
The problem is that I can not reboot the system. Each time I want to reboot or shut down and start again, I have to made a new xpenoboot usb. It 'sees' it in the bios and boot from it, but if I reboot again the usb is not 'seen'.
I'm looking for a solution...
Edited by Guest
Thanks!
Mine shuts down normally but it doesn't start, either if it is after a shut down or a reboot. When I check in bios, the usb is not in the bootable options. I have to create another bootable usb each time, on a different usb stick.
Also, when the system is eventually started, I can see the bootable usb as "usbshare2". I can also map it to my windows pc.
Thanks!
That you can see the drive is good.
Have you tried to plug the usb stick into another port? Sometimes that works.
