Hiromatsu Posted January 2, 2016 Share #1 Posted January 2, 2016 Hello everyone, I am struggling with a proplem. In the /lib/modules/ folders there is a mpt3sas.ko This is the driver file for my HBA (LSI 9300 8i) I can SSH into my box and load it manually via: insmod /lib/modules/mpt3sas.ko But apparantly I am too stupid to find a way to automatically load the ko file during the boot up sequence. Can anybody help? If its important: I am running my box on ESXi 6.0 with the controller passed through. Link to comment Share on other sites More sharing options...
Trantor Posted January 3, 2016 Share #2 Posted January 3, 2016 The mpt3sas will be automatically load at boot in next release. You can easily edit /etc/rc.local and add your insmod command to load the mtp3sas.ok module Link to comment Share on other sites More sharing options...
Hiromatsu Posted January 3, 2016 Author Share #3 Posted January 3, 2016 The mpt3sas will be automatically load at boot in next release. You can easily edit /etc/rc.local and add your insmod command to load the mtp3sas.ok module Thank you very much @Trantor Sorry for not telling right away what kind of newbie I am: So I browsed for the rc.local file, but there isn't any Can I just create one? Or do I have to follow a special procedure? something like (I googled this but it is made for Fedora) su - (root password) touch /etc/rc.local chmod +x /etc/rc.local (add the insmod) systemctl enable rc-local.service And what content does the rc.local need to have? Is it sufficient to just have: #!/bin/sh # Copyright © 2000-2014 Synology Inc. All rights reserved. insmod /lib/modules/mpt3sas.ko Does this file needs to be in etc only or in etc.defaults too? Thank you Link to comment Share on other sites More sharing options...
snoopy78 Posted January 4, 2016 Share #4 Posted January 4, 2016 try like that... cp mpt3sas.ko /lib/modules/mpt3sas.ko (do this from where you stored the .ko into your sys) echo "insmod /lib/modules/mpt3sas.ko" >> /etc/rc.local of course you need to put the file 1st into correct dir Link to comment Share on other sites More sharing options...
Hiromatsu Posted January 5, 2016 Author Share #5 Posted January 5, 2016 Thank you very much my friend. It worked. Link to comment Share on other sites More sharing options...
