bobby121418 1 Posted October 2, 2021 Share Posted October 2, 2021 (edited) Hi, I have registered a domain with Duckdns, not sure if there is a better one. But the issue that is causing problem is creating certificate with Letsencrypt. I have tried numerous times with Security-》Certificate-》Add-》Add a new certificate-》Get a certificate from Lets Encrypt I have added the domain name and my email but I keep gettimg error: No response from destination server. Please try again later. I have ports 80, 443 forwarded and in External Access-》 Router configuration I get OKs when testing the connection. So, any help would be appreciated. Many thanks Best Bob Edited October 2, 2021 by bobby121418 Spelling Quote Link to post Share on other sites
DawnRaven 0 Posted October 3, 2021 Share Posted October 3, 2021 (edited) Hello I'm facing the same issue. Everything working good until 4 or 5 days ago. I've tried several ways but still no luck. Message log say 'certificate.cpp:965 syno-letsencrypt failed. 100 [Server is not reachable.]'. Does any one has anything news for this case? Thanks Edited October 3, 2021 by DawnRaven Quote Link to post Share on other sites
jensmander 175 Posted October 3, 2021 Share Posted October 3, 2021 Depends on your DSM version. If your DSM is < 6.2 then you’ll have to modify your system as described in here: Quote Link to post Share on other sites
DawnRaven 0 Posted October 3, 2021 Share Posted October 3, 2021 (edited) 20 minutes ago, jensmander said: Depends on your DSM version. If your DSM is < 6.2 then you’ll have to modify your system as described in here: Hello, thank you for answering. My DSM version is 6.2.3-25426 and it's already using API v02 and i can ping from my NAS to acme-v02.api.letsencrypt.org without any problems. It's very weird. Edited October 3, 2021 by DawnRaven Wrong url Quote Link to post Share on other sites
crristib 0 Posted October 3, 2021 Share Posted October 3, 2021 On 10/2/2021 at 4:43 PM, bobby121418 said: Hi, I have registered a domain with Duckdns, not sure if there is a better one. But the issue that is causing problem is creating certificate with Letsencrypt. I have tried numerous times with Security-》Certificate-》Add-》Add a new certificate-》Get a certificate from Lets Encrypt I have added the domain name and my email but I keep gettimg error: No response from destination server. Please try again later. I have ports 80, 443 forwarded and in External Access-》 Router configuration I get OKs when testing the connection. So, any help would be appreciated. Many thanks Best Bob I had the same problem with version 6.2.3-25426. I installed update 3 and then it worked, it's worth a try. Quote Link to post Share on other sites
DawnRaven 0 Posted October 3, 2021 Share Posted October 3, 2021 (edited) 1 hour ago, crristib said: I had the same problem with version 6.2.3-25426. I installed update 3 and then it worked, it's worth a try. Hello I'm new to xpenology and know nothing much about it. I'm using JUN'S LOADER v1.04b - DS918+ on VMWare and trying to download update 2 from here https://download.synology.com/download/DSM/criticalupdate/update_pack/25426-2/ using "synology_apollolake_918+.pat" file but when i try to manual update, at 95% it say "Fail to update the file. The file is probably corrupt.". I've also tried with 25426-3 but it's the same. Please help me with that. Thank you. Edited October 3, 2021 by DawnRaven Quote Link to post Share on other sites
bobby121418 1 Posted October 3, 2021 Author Share Posted October 3, 2021 4 hours ago, jensmander said: Depends on your DSM version. If your DSM is < 6.2 then you’ll have to modify your system as described in here: Thank you, I have DSM 6.1.7-15284 so will give this a try. Can I update to 6.2? I am using bootloader 1.02b. Thanks Quote Link to post Share on other sites
billat29 60 Posted October 3, 2021 Share Posted October 3, 2021 2 hours ago, bobby121418 said: Thank you, I have DSM 6.1.7-15284 so will give this a try. Can I update to 6.2? I am using bootloader 1.02b. Thanks You will need to create a new bootloader if you want to upgrade. See here: https://xpenology.com/forum/topic/13333-tutorialreference-6x-loaders-and-platforms/ 1 Quote Link to post Share on other sites
flyingcloud2012 0 Posted October 8, 2021 Share Posted October 8, 2021 On 10/3/2021 at 12:53 PM, DawnRaven said: Hello I'm new to xpenology and know nothing much about it. I'm using JUN'S LOADER v1.04b - DS918+ on VMWare and trying to download update 2 from here https://download.synology.com/download/DSM/criticalupdate/update_pack/25426-2/ using "synology_apollolake_918+.pat" file but when i try to manual update, at 95% it say "Fail to update the file. The file is probably corrupt.". I've also tried with 25426-3 but it's the same. Please help me with that. Thank you. did you get this resolve? I have the same issues Quote Link to post Share on other sites
haydibe 310 Posted October 8, 2021 Share Posted October 8, 2021 (edited) DSM6.2.3 commes with OpenSSL 1.0.2u-fips, which has problems with the algorithms used by the new Letsencrypt certificates. You will either have to wait until a u4.pat gets released that includes openssl libraries >=1.1.0. Chances are high that this will never happen. DSM7 (does not work with Jun's bootloaders) commes with OpenSSL 1.1.1k and an update list of ca certificates. Both are required to make Letsencrypt certificates work again. It does not suffer from the problem. I have no idea what OpenSSL version commes with DSM6.2.4 (does not work with Jun's bootloaders) Many recent updates of SynoCommunity packages shouldn't be affected as well, as they provide their own and updated OpenSSL library under the hood. Since the SynoCommunity repo can't be access due their webservers use a Letsencrypt certificate, you will need to download recent packages from here https://search.synopackage.com/sources/synocommunity, and install them manualy. Edited October 8, 2021 by haydibe Quote Link to post Share on other sites
bobby121418 1 Posted October 10, 2021 Author Share Posted October 10, 2021 Hi, Thanks for you help billat29. I updated my loader to 1.03b and installed DSM 6.2.3-25426 and I could work through Security-》Certificate-》Add-》Add a new certificate-》Get a certificate from Lets Encrypt to get the certificate and now its working nicely. Cheers Bob Quote Link to post Share on other sites
haldi 6 Posted December 3, 2021 Share Posted December 3, 2021 (edited) They changed again? When i press "add new cerificate" i get the "no response" thingy on 6.2.3.25426 Edit: Solution here: Edited December 3, 2021 by haldi Quote Link to post Share on other sites
