old Posted July 28, 2013 Share #1 Posted July 28, 2013 (edited) I'm new to xpenology and to synology. It was uber easy for me to install Synology DS3612xs - DSM 4.2 build 3202 on my new gigabyte GA-E350N Win8, but I just can't seem to set the ip address correctly. It's weird, even though I can connect to it using webman, the xpenology box doesn't appear in the connections on my pfSense router. (under Status, DHCP leases.) I try to change the domain on the xpenology server to put it on the pfSense domain 192.168.1.x, but it seems to stay on another domain 169.254.109.205. I feel like I need a more basic resource to help guide me. Anyone know a good site to refer me to ? Any help is greatly appreciated. Edited July 29, 2013 by Guest Link to comment Share on other sites More sharing options...
Schnapps Posted July 29, 2013 Share #2 Posted July 29, 2013 I'm new to xpenology and to synology. It was uber easy for me to install Synology DS3612xs - DSM 4.2 build 3202 on my new gigabyte GA-E350N Win8, but I just can't seem to set the ip address correctly. It's weird, even though I can connect to it using webman, the xpenology box doesn't appear in the connections on my pfSense router. (under Status, DHCP leases.) I try to change the domain on the xpenology server to put it on the pfSense domain 192.168.1.x, but it seems to stay on another domain 169.254.109.205. I feel like I need a more basic resource to help guide me. Anyone know a good site to refer me to ? Any help is greatly appreciated. Hi mate, Try the 4.2 3211 x64 version. Maybe it's working well Link to comment Share on other sites More sharing options...
old Posted July 29, 2013 Author Share #3 Posted July 29, 2013 oh shoot; I had just gotten home from climbing way up on mount Hood and was delerious because I'm way out of shape. I had managed to plug my network cables into the wrong places. So my xpe server and my win box were both not connected into my lan, but they each were able to see each other (being connected to the same switch.) So, problem solved. Thanks for the help again, Schnapps. Link to comment Share on other sites More sharing options...
Schnapps Posted July 29, 2013 Share #4 Posted July 29, 2013 oh shoot; I had just gotten home from climbing way up on mount Hood and was delerious because I'm way out of shape. I had managed to plug my network cables into the wrong places. So my xpe server and my win box were both not connected into my lan, but they each were able to see each other (being connected to the same switch.) So, problem solved. Thanks for the help again, Schnapps. Well, with pleasure! For nothing! Link to comment Share on other sites More sharing options...
old Posted July 29, 2013 Author Share #5 Posted July 29, 2013 @Schnapps Yeah sorry about that. Wow, this Gigabyte board you recommended sure seems great. And man, it is sooo much quieter than the Atom Gigabyte it replaced. I can't even hear it. Link to comment Share on other sites More sharing options...
