BTRFS RAID1 Volume crashed and size is not correct
tdse13
Recently, 1 of the 2 drives in my 12 TB Raid1 failed. I then stopped the server and changed the 2 disks with larger ones (14 TB Toshiba MG08ACA14TE) and rebuild the raid1 one by one. Unfortunately, now the volume still crashes and the volume size does not recognize the new disks whereas the storage pool shows the new value (12,73 TB instead of 10.47 TB). In Fille Station I can still see my data.
#cat /proc/mdstat
md2 : active raid1 sda3[2] sdb3[3]
      13667655616 blocks super 1.2 [2/2] [UU]
md3 : active raid1 sdd5[0]
      464020416 blocks super 1.2 [1/1] [U]
md1 : active raid1 sda2[0] sdb2[2] sdd2[1]
      2097088 blocks [16/3] [UUU_____________]
md0 : active raid1 sda1[1] sdb1[0] sdd1[2]
      2490176 blocks [16/3] [UUU_____________]
unused devices: <none>
Model: Linux Software RAID Array (md)
Disk /dev/md0: 2550MB
Sector size (logical/physical): 512B/512B
Partition Table: loop
Disk Flags:
Number  Start  End     Size    File system  Flags
 1      0.00B  2550MB  2550MB  ext4
Disk /dev/md1: 2147MB
Disk Flags:
 1      0.00B  2147MB  2147MB  linux-swap(v1)
Disk /dev/md2: 14.0TB
Disk Flags:
 1      0.00B  14.0TB  14.0TB  btrfs
# dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP PREEMPT Tue Nov 24 17:18:27 CST 2020
[    0.000000] Command line: syno_hdd_powerup_seq=1 HddHotplug=0 syno_hw_version=DS918+ vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_hdd_detect=0 syno_port_thaw=1 root=/dev/md0 sn=1840PDN858004 mac1=0011328F44F0 mac2=0011328F44F1 netif_num=2 vid=0x0781 pid=0x5567
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000] x86/fpu: xstate_offset[3]:  960, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]: 1024, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Supporting XSAVE feature 0x01: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x02: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x08: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x10: 'MPX CSR'
[    0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 1088 bytes, using 'standard' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000100-0x000000000003dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000003e000-0x000000000003ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000040000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000000fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000010000000-0x0000000012150fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000012151000-0x0000000072d33fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000072d34000-0x00000000755bbfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000755bc000-0x00000000755f4fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000755f5000-0x0000000075654fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000075655000-0x0000000075ae0fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000075ae1000-0x00000000764e3fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000764e4000-0x000000007658ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000076590000-0x0000000076bfffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000076c00000-0x000000007fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d0000000-0x00000000d0ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d3709000-0x00000000d3709fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe042000-0x00000000fe044fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe900000-0x00000000fe902fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] e820: update [mem 0x00100000-0x0010000f] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000100-0x000000000003dfff] usable
[    0.000000] reserve setup_data: [mem 0x000000000003e000-0x000000000003ffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000040000-0x000000000009dfff] usable
[    0.000000] reserve setup_data: [mem 0x000000000009e000-0x00000000000fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000000010000f] usable
[    0.000000] reserve setup_data: [mem 0x0000000000100010-0x000000000fffffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000010000000-0x0000000012150fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000012151000-0x0000000072d33fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000072d34000-0x00000000755bbfff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000755bc000-0x00000000755f4fff] ACPI data
[    0.000000] reserve setup_data: [mem 0x00000000755f5000-0x0000000075654fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x0000000075655000-0x0000000075ae0fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000075ae1000-0x00000000764e3fff] usable
[    0.000000] reserve setup_data: [mem 0x00000000764e4000-0x000000007658ffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000076590000-0x0000000076bfffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000076c00000-0x000000007fffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000d0000000-0x00000000d0ffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000d3709000-0x00000000d3709fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fe042000-0x00000000fe044fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fe900000-0x00000000fe902fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000047fffffff] usable
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi:  ACPI=0x75652000  ACPI 2.0=0x75652014  SMBIOS=0x758f2000  SMBIOS 3.0=0x758f1000  ESRT=0x6f5c2c98
[    0.000000] esrt: Reserving ESRT space from 0x000000006f5c2c98 to 0x000000006f5c2cd0.
[    0.000000] SMBIOS 3.2.0 present.
[    0.000000] Kernel/User page tables isolation: disabled
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x480000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 00FF000000 mask 7FFF000000 write-combining
[    0.000000]   1 base 0000000000 mask 7F80000000 write-back
[    0.000000]   2 base 0077000000 mask 7FFF000000 uncachable
[    0.000000]   3 base 0078000000 mask 7FF8000000 uncachable
[    0.000000]   4 base 0100000000 mask 7F00000000 write-back
[    0.000000]   5 base 0200000000 mask 7E00000000 write-back
[    0.000000]   6 base 0400000000 mask 7F80000000 write-back
[    0.000000]   7 base 0090000000 mask 7FF0000000 write-combining
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WT  UC- UC  WB  WT  UC- UC
[    0.000000] e820: last_pfn = 0x76c00 max_arch_pfn = 0x400000000
[    0.000000] Base memory trampoline at [ffff880000096000] 96000 size 28672
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x01a06000, 0x01a06fff] PGTABLE
[    0.000000] BRK [0x01a07000, 0x01a07fff] PGTABLE
[    0.000000] BRK [0x01a08000, 0x01a08fff] PGTABLE
[    0.000000] BRK [0x01a09000, 0x01a09fff] PGTABLE
[    0.000000] BRK [0x01a0a000, 0x01a0afff] PGTABLE
[    0.000000] BRK [0x01a0b000, 0x01a0bfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x364c6000-0x37ffffff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x0000000075652014 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x0000000075651728 0000D4 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.000000] ACPI: FACP 0x00000000755F2000 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000755E5000 00C7B3 (v02 ALASKA A M I    01072009 INTL 20160930)
[    0.000000] ACPI: FACS 0x0000000075654000 000040
[    0.000000] ACPI: FPDT 0x00000000755E4000 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FIDT 0x00000000755E3000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 0x00000000755F4000 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.000000] ACPI: DBG2 0x00000000755F3000 000072 (v00 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.000000] ACPI: DBGP 0x00000000755E2000 000034 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.000000] ACPI: HPET 0x00000000755E0000 000038 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.000000] ACPI: LPIT 0x00000000755DF000 00005C (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.000000] ACPI: APIC 0x00000000755DE000 000084 (v04 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.000000] ACPI: NPKT 0x00000000755DD000 000065 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.000000] ACPI: SSDT 0x00000000755D8000 003F72 (v02 INTEL  DptfTab  00000003 BRXT 0100000D)
[    0.000000] ACPI: SSDT 0x00000000755D1000 0010B3 (v02 INTEL  UsbCTabl 00000003 BRXT 0100000D)
[    0.000000] ACPI: SSDT 0x00000000755D0000 0009FF (v01 Intel_ Platform 00001000 INTL 20160930)
[    0.000000] ACPI: AAFT 0x00000000755CF000 0002CE (v01 ALASKA OEMAAFT  01072009 MSFT 00000097)
[    0.000000] ACPI: SSDT 0x00000000755CE000 0004D5 (v02 PmRef  Cpu0Ist  00003000 INTL 20160930)
[    0.000000] ACPI: SSDT 0x00000000755CD000 000775 (v02 CpuRef CpuSsdt  00003000 INTL 20160930)
[    0.000000] ACPI: SSDT 0x00000000755CC000 00035F (v02 PmRef  Cpu0Tst  00003000 INTL 20160930)
[    0.000000] ACPI: SSDT 0x00000000755CB000 0001E6 (v02 PmRef  ApTst    00003000 INTL 20160930)
[    0.000000] ACPI: SSDT 0x00000000755C8000 00286F (v02 SaSsdt SaSsdt   00003000 INTL 20160930)
[    0.000000] ACPI: TPM2 0x00000000755C7000 000034 (v04 ALASKA A M I    00000001 AMI  00000000)
[    0.000000] ACPI: WDAT 0x00000000755E1000 000104 (v01                 00000000      00000000)
[    0.000000] ACPI: WSMT 0x00000000755DC000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000047fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000003dfff]
[    0.000000]   node   0: [mem 0x0000000000040000-0x000000000009dfff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000000fffffff]
[    0.000000]   node   0: [mem 0x0000000012151000-0x0000000072d33fff]
[    0.000000]   node   0: [mem 0x0000000075ae1000-0x00000000764e3fff]
[    0.000000]   node   0: [mem 0x0000000076590000-0x0000000076bfffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000047fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000047fffffff]
[    0.000000] On node 0 totalpages: 4135921
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 24 pages reserved
[    0.000000]   DMA zone: 3995 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 7218 pages used for memmap
[    0.000000]   DMA32 zone: 461910 pages, LIFO batch:31
[    0.000000]   Normal zone: 57344 pages used for memmap
[    0.000000]   Normal zone: 3670016 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at [mem 0x78000000-0x7fffffff]
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-119
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0003e000-0x0003ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x00100000-0x00100fff]
[    0.000000] PM: Registered nosave memory: [mem 0x10000000-0x12150fff]
[    0.000000] PM: Registered nosave memory: [mem 0x72d34000-0x755bbfff]
[    0.000000] PM: Registered nosave memory: [mem 0x755bc000-0x755f4fff]
[    0.000000] PM: Registered nosave memory: [mem 0x755f5000-0x75654fff]
[    0.000000] PM: Registered nosave memory: [mem 0x75655000-0x75ae0fff]
[    0.000000] PM: Registered nosave memory: [mem 0x764e4000-0x7658ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x76c00000-0x7fffffff]
[    0.000000] PM: Registered nosave memory: [mem 0x80000000-0xcfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xd0000000-0xd0ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xd1000000-0xd3708fff]
[    0.000000] PM: Registered nosave memory: [mem 0xd3709000-0xd3709fff]
[    0.000000] PM: Registered nosave memory: [mem 0xd370a000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfe041fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe042000-0xfe044fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe045000-0xfe8fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe900000-0xfe902fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe903000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfed00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed01000-0xfed01fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed02000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0x80000000-0xcfffffff] available for PCI devices
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 31 pages/cpu @ffff88047fc00000 s87448 r8192 d31336 u524288
[    0.000000] pcpu-alloc: s87448 r8192 d31336 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 4071271
[    0.000000] Kernel command line: syno_hdd_powerup_seq=1 HddHotplug=0 syno_hw_version=DS918+ vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_hdd_detect=0 syno_port_thaw=1 root=/dev/md0 sn=1840PDN858004 mac1=0011328F44F0 mac2=0011328F44F1 netif_num=2 vid=0x0781 pid=0x5567
[    0.000000] Power on seq num: 1
[    0.000000] Synology Hardware Version: DS918+
[    0.000000] Vender format version: 2
[    0.000000] SYNO GPIO hdd detect pin: 0
[    0.000000] Serial Number: 1840PDN858004
[    0.000000] Mac1: 0011328F44F0
[    0.000000] Mac2: 0011328F44F1
[    0.000000] Internal netif num: 2
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Memory: 16069676K/16543684K available (5613K kernel code, 478K rwdata, 1848K rodata, 864K init, 688K bss, 474008K reserved, 0K cma-reserved)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:4352 nr_irqs:1024 16
[    0.000000] Console: colour dummy device 80x25
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: PIT calibration matches HPET. 1 loops
[    0.000000] tsc: Detected 1497.847 MHz processor
[    0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 2995.69 BogoMIPS (lpj=1497847)
[    0.000007] pid_max: default: 32768 minimum: 301
[    0.000013] ACPI: Core revision 20150930
[    0.014081] ACPI: 9 ACPI AML tables successfully acquired and loaded
[    0.017057] Security Framework initialized
[    0.017063] AppArmor: AppArmor initialized
[    0.017076] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.017078] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.017395] Initializing cgroup subsys io
[    0.017399] Initializing cgroup subsys memory
[    0.017406] Initializing cgroup subsys devices
[    0.017409] Initializing cgroup subsys freezer
[    0.017448] CPU: Physical Processor ID: 0
[    0.017449] CPU: Processor Core ID: 0
[    0.025132] mce: CPU supports 7 MCE banks
[    0.025176] CPU0: Thermal monitoring enabled (TM1)
[    0.025214] process: using mwait in idle threads
[    0.025217] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[    0.025218] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[    0.025226] Speculative Store Bypass: Vulnerable
[    0.027167] Freeing SMP alternatives memory: 28K (ffffffff81951000 - ffffffff81958000)
[    0.033972] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.043988] TSC deadline timer enabled
[    0.043994] smpboot: CPU0: Intel(R) Celeron(R) J4105 CPU @ 1.50GHz (family: 0x6, model: 0x7a, stepping: 0x1)
[    0.044012] Performance Events: PEBS fmt3+, generic architected perfmon, full-width counters, Intel PMU driver.
[    0.044018] ... version:                4
[    0.044019] ... bit width:              48
[    0.044020] ... generic registers:      4
[    0.044021] ... value mask:             0000ffffffffffff
[    0.044022] ... max period:             00007fffffffffff
[    0.044023] ... fixed-purpose events:   3
[    0.044024] ... event mask:             000000070000000f
[    0.053040] x86: Booting SMP configuration:
[    0.053042] .... node  #0, CPUs:      #1
[    0.063762] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.066653]  #2 #3
[    0.090513] x86: Booted up 1 node, 4 CPUs
[    0.090517] smpboot: Total of 4 processors activated (11982.77 BogoMIPS)
[    0.095214] devtmpfs: initialized
[    0.095601] PM: Registering ACPI NVS region [mem 0x755f5000-0x75654fff] (393216 bytes)
[    0.095690] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.095696] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.095806] xor: measuring software checksum speed
[    0.104919]    prefetch64-sse: 12988.000 MB/sec
[    0.114932]    generic_sse: 11032.000 MB/sec
[    0.114936] xor: using function: prefetch64-sse (12988.000 MB/sec)
[    0.114959] pinctrl core: initialized pinctrl subsystem
[    0.115213] NET: Registered protocol family 16
[    0.118945] cpuidle: using governor ladder
[    0.122954] cpuidle: using governor menu
[    0.123084] ACPI: bus type PCI registered
[    0.123168] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.123171] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.123186] PCI: Using configuration type 1 for base access
[    0.148025] raid6: sse2x1   gen()  5492 MB/s
[    0.165053] raid6: sse2x1   xor()  3759 MB/s
[    0.182089] raid6: sse2x2   gen()  6617 MB/s
[    0.199128] raid6: sse2x2   xor()  4429 MB/s
[    0.216163] raid6: sse2x4   gen()  7714 MB/s
[    0.233200] raid6: sse2x4   xor()  2548 MB/s
[    0.233202] raid6: using algorithm sse2x4 gen() 7714 MB/s
[    0.233203] raid6: .... xor() 2548 MB/s, rmw enabled
[    0.233205] raid6: using ssse3x2 recovery algorithm
[    0.233255] ACPI: Added _OSI(Module Device)
[    0.233257] ACPI: Added _OSI(Processor Device)
[    0.233258] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.233260] ACPI: Added _OSI(Processor Aggregator Device)
[    0.238227] ACPI: Executed 11 blocks of module-level executable AML code
[    0.249982] ACPI: Dynamic OEM Table Load:
[    0.249992] ACPI: SSDT 0xFFFF88046D51EC00 000190 (v02 PmRef  Cpu0Cst  00003001 INTL 20160930)
[    0.250525] ACPI: Executed 1 blocks of module-level executable AML code
[    0.250861] ACPI: Dynamic OEM Table Load:
[    0.250869] ACPI: SSDT 0xFFFF88046D51EA00 0001E6 (v02 PmRef  ApIst    00003000 INTL 20160930)
[    0.251431] ACPI: Executed 1 blocks of module-level executable AML code
[    0.251564] ACPI: Dynamic OEM Table Load:
[    0.251571] ACPI: SSDT 0xFFFF88046DF41000 0000C9 (v02 PmRef  ApCst    00003000 INTL 20160930)
[    0.252092] ACPI: Executed 1 blocks of module-level executable AML code
[    0.252972] ACPI: Interpreter enabled
[    0.252999] ACPI: (supports S0 S4 S5)
[    0.253000] ACPI: Using IOAPIC for interrupt routing
[    0.253095] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.259496] ACPI: Power Resource [DRST] (on)
[    0.259858] ACPI: Power Resource [DRST] (on)
[    0.260170] ACPI: Power Resource [DRST] (on)
[    0.260484] ACPI: Power Resource [DRST] (on)
[    0.260842] ACPI: Power Resource [DRST] (on)
[    0.261190] ACPI: Power Resource [DRST] (on)
[    0.261534] ACPI: Power Resource [WRST] (on)
[    0.266162] ACPI: Power Resource [FN00] (on)
[    0.266922] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.266930] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.267556] acpi PNP0A08:00: _OSC: platform does not support [PCIeCapability]
[    0.267730] acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
[    0.267734] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug PME AER PCIeCapability]
[    0.267736] acpi PNP0A08:00: _OSC: platform willing to grant [PCIeHotplug PME AER]
[    0.267738] acpi PNP0A08:00: _OSC failed (AE_SUPPORT); disabling ASPM
[    0.267877] PCI host bridge to bus 0000:00
[    0.267880] pci_bus 0000:00: root bus resource [io  0x0070-0x0077]
[    0.267882] pci_bus 0000:00: root bus resource [io  0x0000-0x006f window]
[    0.267884] pci_bus 0000:00: root bus resource [io  0x0078-0x0cf7 window]
[    0.267886] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.267888] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.267890] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.267892] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[    0.267894] pci_bus 0000:00: root bus resource [mem 0x78000001-0x7fffffff window]
[    0.267896] pci_bus 0000:00: root bus resource [mem 0x80000000-0xcfffffff window]
[    0.267897] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff window]
[    0.267899] pci_bus 0000:00: root bus resource [mem 0xfea00000-0xfeafffff window]
[    0.267901] pci_bus 0000:00: root bus resource [mem 0xfed00000-0xfed003ff window]
[    0.267903] pci_bus 0000:00: root bus resource [mem 0xfed01000-0xfed01fff window]
[    0.267905] pci_bus 0000:00: root bus resource [mem 0xfed03000-0xfed03fff window]
[    0.267906] pci_bus 0000:00: root bus resource [mem 0xfed06000-0xfed06fff window]
[    0.267908] pci_bus 0000:00: root bus resource [mem 0xfed08000-0xfed09fff window]
[    0.267910] pci_bus 0000:00: root bus resource [mem 0xfed80000-0xfedbffff window]
[    0.267912] pci_bus 0000:00: root bus resource [mem 0xfed1c000-0xfed1cfff window]
[    0.267914] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xfeefffff window]
[    0.267916] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.267929] pci 0000:00:00.0: [8086:31f0] type 00 class 0x060000
[    0.268233] pci 0000:00:00.1: [8086:318c] type 00 class 0x118000
[    0.268271] pci 0000:00:00.1: reg 0x10: [mem 0x80000000-0x80007fff 64bit]
[    0.268601] pci 0000:00:02.0: [8086:3185] type 00 class 0x030000
[    0.268617] pci 0000:00:02.0: reg 0x10: [mem 0xa0000000-0xa0ffffff 64bit]
[    0.268624] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.268629] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.268958] pci 0000:00:0f.0: [8086:319a] type 00 class 0x078000
[    0.269003] pci 0000:00:0f.0: reg 0x10: [mem 0xa1215000-0xa1215fff 64bit]
[    0.269086] pci 0000:00:0f.0: PME# supported from D3hot
[    0.269377] pci 0000:00:12.0: [8086:31e3] type 00 class 0x010601
[    0.269399] pci 0000:00:12.0: reg 0x10: [mem 0xa1210000-0xa1211fff]
[    0.269408] pci 0000:00:12.0: reg 0x14: [mem 0xa1214000-0xa12140ff]
[    0.269416] pci 0000:00:12.0: reg 0x18: [io  0xf090-0xf097]
[    0.269424] pci 0000:00:12.0: reg 0x1c: [io  0xf080-0xf083]
[    0.269432] pci 0000:00:12.0: reg 0x20: [io  0xf060-0xf07f]
[    0.269440] pci 0000:00:12.0: reg 0x24: [mem 0xa1213000-0xa12137ff]
[    0.269471] pci 0000:00:12.0: PME# supported from D3hot
[    0.269724] pci 0000:00:13.0: [8086:31d8] type 01 class 0x060400
[    0.269784] pci 0000:00:13.0: PME# supported from D0 D3hot D3cold
[    0.270006] pci 0000:00:13.0: System wakeup disabled by ACPI
[    0.270048] pci 0000:00:13.1: [8086:31d9] type 01 class 0x060400
[    0.270107] pci 0000:00:13.1: PME# supported from D0 D3hot D3cold
[    0.270330] pci 0000:00:13.1: System wakeup disabled by ACPI
[    0.270371] pci 0000:00:13.2: [8086:31da] type 01 class 0x060400
[    0.270430] pci 0000:00:13.2: PME# supported from D0 D3hot D3cold
[    0.270648] pci 0000:00:13.2: System wakeup disabled by ACPI
[    0.270691] pci 0000:00:13.3: [8086:31db] type 01 class 0x060400
[    0.270751] pci 0000:00:13.3: PME# supported from D0 D3hot D3cold
[    0.270969] pci 0000:00:13.3: System wakeup disabled by ACPI
[    0.271034] pci 0000:00:15.0: [8086:31a8] type 00 class 0x0c0330
[    0.271064] pci 0000:00:15.0: reg 0x10: [mem 0xa1200000-0xa120ffff 64bit]
[    0.271129] pci 0000:00:15.0: PME# supported from D3hot D3cold
[    0.271363] pci 0000:00:15.0: System wakeup disabled by ACPI
[    0.271471] pci 0000:00:1f.0: [8086:31e8] type 00 class 0x060100
[    0.271852] pci 0000:00:1f.1: [8086:31d4] type 00 class 0x0c0500
[    0.271915] pci 0000:00:1f.1: reg 0x10: [mem 0xa1212000-0xa12120ff 64bit]
[    0.271993] pci 0000:00:1f.1: reg 0x20: [io  0xf040-0xf05f]
[    0.272378] pci 0000:00:13.0: PCI bridge to [bus 01]
[    0.272422] pci 0000:00:13.1: PCI bridge to [bus 02]
[    0.272481] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[    0.272522] pci 0000:03:00.0: reg 0x10: [io  0xe000-0xe0ff]
[    0.272547] pci 0000:03:00.0: reg 0x18: [mem 0xa1104000-0xa1104fff 64bit]
[    0.272563] pci 0000:03:00.0: reg 0x20: [mem 0xa1100000-0xa1103fff 64bit]
[    0.272580] pci 0000:03:00.0: can't set Max Payload Size to 256; if necessary, use "pci=pcie_bus_safe" and report a bug
[    0.272634] pci 0000:03:00.0: supports D1 D2
[    0.272636] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.272690] pci 0000:03:00.0: System wakeup disabled by ACPI
[    0.275277] pci 0000:00:13.2: PCI bridge to [bus 03]
[    0.275281] pci 0000:00:13.2:   bridge window [io  0xe000-0xefff]
[    0.275284] pci 0000:00:13.2:   bridge window [mem 0xa1100000-0xa11fffff]
[    0.275339] pci 0000:04:00.0: [1b21:0612] type 00 class 0x010601
[    0.275367] pci 0000:04:00.0: reg 0x10: [io  0xd050-0xd057]
[    0.275379] pci 0000:04:00.0: reg 0x14: [io  0xd040-0xd043]
[    0.275389] pci 0000:04:00.0: reg 0x18: [io  0xd030-0xd037]
[    0.275399] pci 0000:04:00.0: reg 0x1c: [io  0xd020-0xd023]
[    0.275409] pci 0000:04:00.0: reg 0x20: [io  0xd000-0xd01f]
[    0.275420] pci 0000:04:00.0: reg 0x24: [mem 0xa1000000-0xa10001ff]
[    0.275498] pci 0000:04:00.0: System wakeup disabled by ACPI
[    0.278278] pci 0000:00:13.3: PCI bridge to [bus 04]
[    0.278282] pci 0000:00:13.3:   bridge window [io  0xd000-0xdfff]
[    0.278286] pci 0000:00:13.3:   bridge window [mem 0xa1000000-0xa10fffff]
[    0.278303] pci_bus 0000:00: on NUMA node 0
[    0.279209] ACPI: PCI Interrupt Link [LNKA] (IRQs *3 4 5 6 10 11 12 14 15), disabled.
[    0.279297] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 *4 5 6 10 11 12 14 15), disabled.
[    0.279372] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 10 11 12 14 15), disabled.
[    0.279452] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 *6 10 11 12 14 15), disabled.
[    0.279527] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *7, disabled.
[    0.279601] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *9, disabled.
[    0.279676] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15), disabled.
[    0.279751] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15), disabled.
[    0.280767] ACPI: Enabled 6 GPEs in block 00 to 7F
[    0.280897] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.280900] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.280902] vgaarb: loaded
[    0.280903] vgaarb: bridge control possible 0000:00:02.0
[    0.280979] SCSI subsystem initialized
[    0.281032] libata version 3.00 loaded.
[    0.281086] pps_core: LinuxPPS API ver. 1 registered
[    0.281088] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.281095] PTP clock support registered
[    0.281182] EFI Variables Facility v0.08 2004-May-17
[    0.290874] pstore: Registered efi as persistent store backend
[    0.290883] PCI: Using ACPI for IRQ routing
[    0.319155] PCI: pci_cache_line_size set to 64 bytes
[    0.319222] e820: reserve RAM buffer [mem 0x0003e000-0x0003ffff]
[    0.319224] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.319226] e820: reserve RAM buffer [mem 0x72d34000-0x73ffffff]
[    0.319227] e820: reserve RAM buffer [mem 0x764e4000-0x77ffffff]
[    0.319228] e820: reserve RAM buffer [mem 0x76c00000-0x77ffffff]
[    0.319504] clocksource: Switched to clocksource hpet
[    0.319620] AppArmor: AppArmor Filesystem Enabled
[    0.319643] pnp: PnP ACPI init
[    0.319895] system 00:00: [io  0x0280-0x028f] has been reserved
[    0.319897] system 00:00: [io  0x0290-0x029f] has been reserved
[    0.319899] system 00:00: [io  0x02a0-0x02af] has been reserved
[    0.319903] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.320193] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.320196] system 00:01: [io  0x0400-0x047f] has been reserved
[    0.320197] system 00:01: [io  0x0500-0x05fe] has been reserved
[    0.320201] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.320650] system 00:02: [mem 0xe0000000-0xefffffff] has been reserved
[    0.320653] system 00:02: [mem 0xfea00000-0xfeafffff] has been reserved
[    0.320655] system 00:02: [mem 0xfed01000-0xfed01fff] has been reserved
[    0.320657] system 00:02: [mem 0xfed03000-0xfed03fff] has been reserved
[    0.320659] system 00:02: [mem 0xfed06000-0xfed06fff] has been reserved
[    0.320661] system 00:02: [mem 0xfed08000-0xfed09fff] has been reserved
[    0.320663] system 00:02: [mem 0xfed80000-0xfedbffff] has been reserved
[    0.320665] system 00:02: [mem 0xfed1c000-0xfed1cfff] has been reserved
[    0.320668] system 00:02: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.320671] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.320863] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.321184] pnp: PnP ACPI: found 4 devices
[    0.331468] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.331595] pci 0000:00:13.0: PCI bridge to [bus 01]
[    0.331607] pci 0000:00:13.1: PCI bridge to [bus 02]
[    0.331615] pci 0000:00:13.2: PCI bridge to [bus 03]
[    0.331619] pci 0000:00:13.2:   bridge window [io  0xe000-0xefff]
[    0.331623] pci 0000:00:13.2:   bridge window [mem 0xa1100000-0xa11fffff]
[    0.331631] pci 0000:00:13.3: PCI bridge to [bus 04]
[    0.331634] pci 0000:00:13.3:   bridge window [io  0xd000-0xdfff]
[    0.331638] pci 0000:00:13.3:   bridge window [mem 0xa1000000-0xa10fffff]
[    0.331645] pci_bus 0000:00: resource 4 [io  0x0070-0x0077]
[    0.331647] pci_bus 0000:00: resource 5 [io  0x0000-0x006f window]
[    0.331649] pci_bus 0000:00: resource 6 [io  0x0078-0x0cf7 window]
[    0.331651] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.331653] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.331654] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.331656] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000fffff window]
[    0.331658] pci_bus 0000:00: resource 11 [mem 0x78000001-0x7fffffff window]
[    0.331660] pci_bus 0000:00: resource 12 [mem 0x80000000-0xcfffffff window]
[    0.331662] pci_bus 0000:00: resource 13 [mem 0xe0000000-0xefffffff window]
[    0.331664] pci_bus 0000:00: resource 14 [mem 0xfea00000-0xfeafffff window]
[    0.331666] pci_bus 0000:00: resource 15 [mem 0xfed00000-0xfed003ff window]
[    0.331668] pci_bus 0000:00: resource 16 [mem 0xfed01000-0xfed01fff window]
[    0.331669] pci_bus 0000:00: resource 17 [mem 0xfed03000-0xfed03fff window]
[    0.331671] pci_bus 0000:00: resource 18 [mem 0xfed06000-0xfed06fff window]
[    0.331673] pci_bus 0000:00: resource 19 [mem 0xfed08000-0xfed09fff window]
[    0.331675] pci_bus 0000:00: resource 20 [mem 0xfed80000-0xfedbffff window]
[    0.331677] pci_bus 0000:00: resource 21 [mem 0xfed1c000-0xfed1cfff window]
[    0.331679] pci_bus 0000:00: resource 22 [mem 0xfee00000-0xfeefffff window]
[    0.331681] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
[    0.331683] pci_bus 0000:03: resource 1 [mem 0xa1100000-0xa11fffff]
[    0.331685] pci_bus 0000:04: resource 0 [io  0xd000-0xdfff]
[    0.331687] pci_bus 0000:04: resource 1 [mem 0xa1000000-0xa10fffff]
[    0.331819] NET: Registered protocol family 2
[    0.332040] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.332289] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.332436] TCP: Hash tables configured (established 131072 bind 65536)
[    0.332463] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    0.332564] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    0.332689] NET: Registered protocol family 1
[    0.332873] RPC: Registered named UNIX socket transport module.
[    0.332875] RPC: Registered udp transport module.
[    0.332876] RPC: Registered tcp transport module.
[    0.332877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.332894] pci 0000:00:02.0: Video device with shadowed ROM
[    0.333222] PCI: CLS 64 bytes, default 64
[    0.333281] Trying to unpack rootfs image as initramfs...
[    1.539349] Freeing initrd memory: 27880K (ffff8800364c6000 - ffff880038000000)
[    1.539649] hpppfxm: module verification failed: signature and/or required key missing - tainting kernel
[    1.561681] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.561685] software IO TLB [mem 0x6a922000-0x6e922000] (64MB) mapped at [ffff88006a922000-ffff88006e921fff]
[    1.562630] audit: initializing netlink subsys (disabled)
[    1.562648] audit: type=2000 audit(1632136855.519:1): initialized
[    1.562783] Initialise system trusted keyring
[    1.570244] VFS: Disk quotas dquot_6.6.0
[    1.570267] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.574243] NFS: Registering the id_resolver key type
[    1.574270] Key type id_resolver registered
[    1.574272] Key type id_legacy registered
[    1.586734] async_tx: api initialized (async)
[    1.586743] Key type asymmetric registered
[    1.586747] Asymmetric key parser 'x509' registered
[    1.586811] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    1.586815] io scheduler noop registered
[    1.586819] io scheduler deadline registered
[    1.586841] io scheduler cfq registered (default)
[    1.623989] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.624143] serial8250: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 8250
[    1.624507] console [ttyS0] enabled
[    1.624891] Linux agpgart interface v0.103
[    2.038941] brd: module loaded
[    2.039013] Loading iSCSI transport class v2.0-870.
[    2.042513] ahci 0000:00:12.0: version 3.0
[    2.042802] ahci 0000:00:12.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    2.042806] ahci 0000:00:12.0: flags: 64bit ncq sntf pm clo only pmp pio slum part deso sadm sds apst
[    2.060813] scsi host0: ahci
[    2.084887] scsi host1: ahci
[    2.084986] ata1: SATA max UDMA/133 abar m2048@0xa1213000 port 0xa1213100 irq 120
[    2.084991] ata2: SATA max UDMA/133 abar m2048@0xa1213000 port 0xa1213180 irq 120
[    2.546221] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.550867] ata1.00: ATA-10: TOSHIBA MG08ACA14TE, 0102, max UDMA/133
[    2.550870] ata1.00: 27344764928 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.550872] ata1.00: SN:        6xxxxxxG
[    2.555537] ata1.00: configured for UDMA/133
[    2.560422] scsi 0:0:0:0: Direct-Access     TOSHIBA  MG08ACA14TE              0102 PQ: 0 ANSI: 5
[    2.560854] sd 0:0:0:0: [sda] 27344764928 512-byte logical blocks: (14.0 TB/12.7 TiB)
[    2.560857] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    2.561045] sd 0:0:0:0: [sda] Write Protect is off
[    2.561048] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.561121] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.563234] tsc: Refined TSC clocksource calibration: 1497.606 MHz
[    2.563238] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x15964d319f9, max_idle_ns: 440795273818 ns
[    2.608233]  sda: sda1 sda2 sda3
[    2.608958] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.023144] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.027858] ata2.00: ATA-10: TOSHIBA MG08ACA14TE, 0102, max UDMA/133
[    3.027861] ata2.00: 27344764928 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    3.027863] ata2.00: SN:        6xxxxxxxJG
[    3.032511] ata2.00: configured for UDMA/133
[    3.037386] scsi 1:0:0:0: Direct-Access     TOSHIBA  MG08ACA14TE              0102 PQ: 0 ANSI: 5
[    3.037846] sd 1:0:0:0: [sdb] 27344764928 512-byte logical blocks: (14.0 TB/12.7 TiB)
[    3.037849] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    3.038019] ahci 0000:04:00.0: SSS flag set, parallel bus scan disabled
[    3.038134] ahci 0000:04:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    3.038138] ahci 0000:04:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc
[    3.038197] sd 1:0:0:0: [sdb] Write Protect is off
[    3.038201] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    3.038286] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.038609] scsi host2: ahci
[    3.042908] scsi host3: ahci
[    3.043007] ata3: SATA max UDMA/133 abar m512@0xa1000000 port 0xa1000100 irq 121
[    3.043010] ata4: SATA max UDMA/133 abar m512@0xa1000000 port 0xa1000180 irq 121
[    3.082112]  sdb: sdb1 sdb2 sdb3
[    3.082702] sd 1:0:0:0: [sdb] Attached SCSI disk
[    3.347072] ata3: SATA link down (SStatus 0 SControl 300)
[    3.347082] ata3: No present pin info for SATA link down event
[    3.563280] clocksource: Switched to clocksource tsc
[    3.806973] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.807155] ata4.00: ATA-10: KINGSTON SA400S37480G, SBFKK1B3, max UDMA/133
[    3.807158] ata4.00: 937703088 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[    3.807160] ata4.00: SN:50026B7683395988
[    3.807279] ata4.00: configured for UDMA/133
[    3.807290] ata4.00: Find SSD disks. [KINGSTON SA400S37480G]
[    3.807525] scsi 3:0:0:0: Direct-Access     KINGSTON SA400S37480G             K1B3 PQ: 0 ANSI: 5
[    3.807748] sd 3:0:0:0: [sdd] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[    3.807851] sd 3:0:0:0: [sdd] Write Protect is off
[    3.807854] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    3.807887] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.807945] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    3.808844]  sdd: sdd1 sdd2 sdd3 < sdd5 >
[    3.809171] sd 3:0:0:0: [sdd] Attached SCSI disk
[    3.811366] serio: i8042 KBD port at 0x60,0x64 irq 1
[    3.811426] serio: i8042 AUX port at 0x60,0x64 irq 12
[    3.811522] i2c /dev entries driver
[    3.811782] i801_smbus 0000:00:1f.1: SMBus using polling
[    3.812084] md: linear personality registered for level -1
[    3.812088] md: raid0 personality registered for level 0
[    3.812091] md: raid1 personality registered for level 1
[    3.812094] md: raid10 personality registered for level 10
[    3.812303] md: raid6 personality registered for level 6
[    3.812305] md: raid5 personality registered for level 5
[    3.812306] md: raid4 personality registered for level 4
[    3.812381] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.812533] NET: Registered protocol family 17
[    3.812568] Key type dns_resolver registered
[    3.813073] registered taskstats version 1
[    3.813078] Loading compiled-in untrusted X.509 certificates
[    3.813082] Loading compiled-in X.509 certificates
[    3.813110] Loaded X.509 cert 'Synology SDG kernel module signing key: 7bd0b0d6bcd31651c22ce3978bdc8c8bdc417329'
[    3.814290] Loaded X.509 cert 'Synology Root Certification Authority: f2c075361f168425f8b5ef31b796406c3aab2089'
[    3.814307] Loaded X.509 cert 'Synology Kernel Module Signing Certification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[    3.814333] Loaded X.509 cert 'Synology kernel module signing key: 4646ce54489669338118a3b1286da156ac366fa5'
[    3.814344] page_owner is disabled
[    3.814376] AppArmor: AppArmor sha1 policy hashing enabled
[    3.821318] hctosys: unable to open rtc device (rtc0)
[    3.822734] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[    3.822738] Write protecting the kernel read-only data: 8192k
[    3.822977] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[    3.823510] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[    3.920701] ACPI: bus type USB registered
[    3.920734] usbcore: registered new interface driver usbfs
[    3.920748] usbcore: registered new interface driver hub
[    3.920784] usbcore: registered new interface driver ethub
[    3.920807] usbcore: registered new device driver usb
[    3.942324] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.959698] xhci_hcd 0000:00:15.0: xHCI Host Controller
[    3.959708] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 1
[    4.160838] xhci_hcd 0000:00:15.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009010
[    4.160846] xhci_hcd 0000:00:15.0: cache line size of 64 is not supported
[    4.161115] hub 1-0:1.0: USB hub found
[    4.161128] hub 1-0:1.0: 9 ports detected
[    4.162480] xhci_hcd 0000:00:15.0: xHCI Host Controller
[    4.162484] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 2
[    4.162512] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.162663] hub 2-0:1.0: USB hub found
[    4.162680] hub 2-0:1.0: 7 ports detected
[    4.189211] usbcore: registered new interface driver usb-storage
[    4.241855] VMware PVSCSI driver - version 1.0.5.0-k
[    4.249541] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
[    4.257290] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[    4.265176] Fusion MPT base driver 3.04.20
[    4.265179] Copyright (c) 1999-2008 LSI Corporation
[    4.278226] Fusion MPT SPI Host driver 3.04.20
[    4.285524] Fusion MPT misc device (ioctl) driver 3.04.20
[    4.285584] mptctl: Registered with Fusion MPT base driver
[    4.285586] mptctl: /dev/mptctl @ (major,minor=10,220)
[    4.301460] megasas: 06.808.16.00-rc1
[    4.309462] Fusion MPT SAS Host driver 3.04.20
[    4.318444] mpt3sas version 09.102.00.00 loaded
[    4.333136] rtc_cmos 00:03: RTC can wake from S4
[    4.333619] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[    4.333704] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[    4.341802] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[    4.349193] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[    4.356859] Adaptec aacraid driver 1.2-1[41010]-ms
[    4.371036] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[    4.385891] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[    4.393109] isci: Intel(R) C600 SAS Controller Driver - version 1.2.0
[    4.415803] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[    4.441648] apollolake_synobios: module license 'Synology Inc.' taints kernel.
[    4.441652] Disabling lock debugging due to kernel taint
[    4.442186] 2021-9-20 11:20:59 UTC
[    4.442190] synobios: load, major number 201
[    4.442193] Brand: Synology
[    4.442195] Model: DS-918+
[    4.442197] This is default settings: set group disks wakeup number to 1, spinup time deno 1
[    4.442200] synobios cpu_arch proc entry initialized
[    4.442202] synobios crypto_hw proc entry initialized
[    4.442204] synobios syno_platform proc entry initialized
[    4.442215] synobios open /dev/ttyS1 success
[    4.447711] synobios: unload
[    4.457338] md: Autodetecting RAID arrays.
[    4.484858] usb 1-5: new full-speed USB device number 2 using xhci_hcd
[    4.494217] md: invalid raid superblock magic on sda3
[    4.494556] md: sda3 does not have a valid v0.90 superblock, not importing!
[    4.545619] md: invalid raid superblock magic on sdb3
[    4.545972] md: sdb3 does not have a valid v0.90 superblock, not importing!
[    4.546432] md: invalid raid superblock magic on sdd5
[    4.546745] md: sdd5 does not have a valid v0.90 superblock, not importing!
[    4.546751] md: Scanned 9 and added 6 devices.
[    4.546752] md: autorun ...
[    4.546754] md: considering sda1 ...
[    4.546759] md:  adding sda1 ...
[    4.546762] md: sda2 has different UUID to sda1
[    4.546766] md:  adding sdb1 ...
[    4.546769] md: sdb2 has different UUID to sda1
[    4.546773] md:  adding sdd1 ...
[    4.546776] md: sdd2 has different UUID to sda1
[    4.546787] md: created md0
[    4.546789] md: bind<sdd1>
[    4.546816] md: bind<sdb1>
[    4.546828] md: bind<sda1>
[    4.546839] md: running: <sda1><sdb1><sdd1>
[    4.547012] md/raid1:md0: active with 3 out of 16 mirrors
[    4.547642] md0: detected capacity change from 0 to 2549940224
[    4.547656] md: considering sda2 ...
[    4.547661] md:  adding sda2 ...
[    4.547665] md:  adding sdb2 ...
[    4.547669] md:  adding sdd2 ...
[    4.548453] md: created md1
[    4.548455] md: bind<sdd2>
[    4.548467] md: bind<sdb2>
[    4.548478] md: bind<sda2>
[    4.548488] md: running: <sda2><sdb2><sdd2>
[    4.549149] md/raid1:md1: active with 3 out of 16 mirrors
[    4.549651] md1: detected capacity change from 0 to 2147418112
[    4.549666] md: ... autorun DONE.
[    4.554725] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.555408] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.555443] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.555467] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.556655] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.557324] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.557359] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.557383] random: sfdisk: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    4.558761] random: sfdisk: uninitialized urandom read (16 bytes read, 86 bits of entropy available)
[    4.559422] random: sfdisk: uninitialized urandom read (16 bytes read, 88 bits of entropy available)
[    4.696420] random: nonblocking pool is initialized
[    4.747803] usb 1-7: new high-speed USB device number 3 using xhci_hcd
[    4.882522] usb-storage 1-7:1.0: USB Mass Storage device detected
[    4.884207] scsi host4: usb-storage 1-7:1.0
[    5.575491] EXT4-fs (md0): barriers disabled
[    5.582924] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
[    5.886441] scsi 4:0:0:0: Direct-Access     SanDisk  Cruzer Blade             1.00 PQ: 0 ANSI: 6
[    5.886832] sd 4:0:0:0: [synoboot] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
[    5.887062] sd 4:0:0:0: [synoboot] Write Protect is off
[    5.887065] sd 4:0:0:0: [synoboot] Mode Sense: 43 00 00 00
[    5.887292] sd 4:0:0:0: [synoboot] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    5.899039]  synoboot: synoboot1 synoboot2 synoboot3
[    5.900035] sd 4:0:0:0: [synoboot] Attached SCSI removable disk
[    7.806775] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
[    9.187822] EXT4-fs (md0): re-mounted. Opts: (null)
[   17.702264] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   17.702318] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   17.702371] sd 3:0:0:0: Attached scsi generic sg2 type 0
[   17.702422] sd 4:0:0:0: Attached scsi generic sg3 type 0
[   18.127784] Adding 2097084k swap on /dev/md1.  Priority:-1 extents:1 across:2097084k
[   18.421509] zram: Added device: zram0
[   18.421687] zram: Added device: zram1
[   18.421843] zram: Added device: zram2
[   18.422002] zram: Added device: zram3
[   18.430147] zram0: detected capacity change from 0 to 2486173696
[   18.437389] Adding 2427900k swap on /dev/zram0.  Priority:1 extents:1 across:2427900k SS
[   18.440525] zram1: detected capacity change from 0 to 2486173696
[   18.447723] Adding 2427900k swap on /dev/zram1.  Priority:1 extents:1 across:2427900k SS
[   18.450818] zram2: detected capacity change from 0 to 2486173696
[   18.458065] Adding 2427900k swap on /dev/zram2.  Priority:1 extents:1 across:2427900k SS
[   18.461210] zram3: detected capacity change from 0 to 2486173696
[   18.468449] Adding 2427900k swap on /dev/zram3.  Priority:1 extents:1 across:2427900k SS
[   20.385991] NET: Registered protocol family 10
[   20.417166] sit: IPv6 over IPv4 tunneling driver
[   20.508457] init: syno-auth-check main process (5871) killed by TERM signal
[   20.710737] Monitor-Mwait will be used to enter C-1 state
[   20.710747] Monitor-Mwait will be used to enter C-2 state
[   20.710752] Monitor-Mwait will be used to enter C-3 state
[   20.710766] ACPI: acpi_idle registered with cpuidle
[   21.054842] SSE version of gcm_enc/dec engaged.
[   21.120846] fuse init (API version 7.23)
[   21.144591] e1000e: Intel(R) PRO/1000 Network Driver - 3.6.0-NAPI
[   21.144595] e1000e: Copyright(c) 1999 - 2019 Intel Corporation.
[   21.160516] Intel(R) Gigabit Ethernet Linux Driver - version 5.3.5.39
[   21.160520] Copyright(c) 2007 - 2019 Intel Corporation.
[   21.167950] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.6.3
[   21.167954] Copyright(c) 1999 - 2019 Intel Corporation.
[   21.171975] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.46-k
[   21.171979] i40e: Copyright (c) 2013 - 2014 Intel Corporation.
[   21.176287] tn40xx: Tehuti Network Driver, 0.3.6.17.2
[   21.176611] tn40xx: Supported phys : MV88X3120 MV88X3310 MV88E2010 QT2025 TLK10232 AQR105 MUSTANG
[   21.181607] r8168 Gigabit Ethernet driver 8.048.03-NAPI loaded
[   21.196353] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   21.198368] r8168  Copyright (C) 2020  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   21.213000] Compat-mlnx-ofed backport release: f36c870
[   21.213004] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git f36c870
[   21.213006] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git
[   21.235965] bnx2x: QLogic 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.712.30-0 (2014/02/10)
[   21.282336] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[   21.282344] ACPI: Power Button [PWRB]
[   21.424442] [drm] GuC: No firmware known for this platform!
[   21.424446] [drm] HuC: No firmware known for this platform!
[   21.425050] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   21.425051] [drm] Driver supports precise vblank timestamp query.
[   21.425155] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   21.425850] [drm] Finished loading DMC firmware i915/glk_dmc_ver1_04.bin (v1.4)
[   22.497846] [drm] failed to retrieve link info, disabling eDP
[   22.501774] [drm] Initialized i915 1.6.0 20171222 for 0000:00:02.0 on minor 0
[   22.502871] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   22.503494] acpi device:54: registered as cooling_device4
[   22.503566] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input1
[   22.505877] [drm] Cannot find any crtc or sizes
[   22.506859] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   22.539412] Btrfs loaded, crc32c=crc32c-intel
[   22.550876] exFAT: Version 1.2.9
[   22.593811] jme: JMicron JMC2XX ethernet driver version 1.0.8
[   22.600608] sky2: driver version 1.30
[   22.611302] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.3.63
[   22.618611] QLogic/NetXen Network Driver v4.0.82
[   22.622549] Solarflare NET driver v4.0
[   22.626529] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[   22.626532] e1000: Copyright (c) 1999-2006 Intel Corporation.
[   22.630100] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
[   22.633444] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k-NAPI
[   22.656849] usbcore: registered new interface driver ax88179_178a
[   22.665785] usbcore: registered new interface driver asix
[   22.669268] Atheros(R) L2 Ethernet Driver - version 2.2.3
[   22.669272] Copyright (c) 2007 Atheros Corporation.
[   22.676713] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[   22.680397] usbcore: registered new interface driver cx82310_eth
[   22.699355] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[   22.699360] e100: Copyright(c) 1999-2006 Intel Corporation
[   22.703076] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[   22.708491] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[   22.722340] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[   22.722369] usbcore: registered new interface driver pegasus
[   22.725729] usbcore: registered new interface driver plusb
[   22.729158] usbcore: registered new interface driver rtl8150
[   22.741347] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[   22.750242] usbcore: registered new interface driver r8152
[   22.762691] vxge: Copyright(c) 2002-2010 Exar Corp.
[   22.762695] vxge: Driver version: 2.5.3.22640-k
[   22.769636] usbcore: registered new interface driver aqc111
[   22.823420] 2021-9-20 11:21:17 UTC
[   22.823426] synobios: load, major number 201
[   22.823429] Brand: Synology
[   22.823431] Model: DS-918+
[   22.823433] This is default settings: set group disks wakeup number to 1, spinup time deno 1
[   22.823436] synobios cpu_arch proc entry initialized
[   22.823438] synobios crypto_hw proc entry initialized
[   22.823440] synobios syno_platform proc entry initialized
[   22.823449] synobios open /dev/ttyS1 success
[   22.969663] systemd-udevd[7036]: starting version 204
[   23.515584] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[   23.563817] gre: GRE over IPv4 demultiplexor driver
[   23.578192] openvswitch: Open vSwitch switching datapath
[   23.821558] PPP generic driver version 2.4.2
[   23.831318] cdc_acm 1-5:1.0: ttyACM0: USB ACM device
[   23.831922] usbcore: registered new interface driver cdc_acm
[   23.831924] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   24.077587] WARNING! power/level is deprecated; use power/control instead
[   24.922216] device ovs-system entered promiscuous mode
[   24.926810] device ovs_eth0 entered promiscuous mode
[   24.949678] eth0: 0xffffc90003360000, 00:11:32:8f:44:f0, IRQ 123
[   25.211057] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   25.215397] device eth0 entered promiscuous mode
[   25.308601] ip_tables: (C) 2000-2006 Netfilter Core Team
[   25.461826] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   25.646722] md: md3 stopped.
[   25.647619] md: bind<sdd5>
[   25.648376] md/raid1:md3: active with 1 out of 1 mirrors
[   25.650251] md3: detected capacity change from 0 to 475156905984
[   25.652264] md: md2 stopped.
[   25.662362] md: bind<sdb3>
[   25.662510] md: bind<sda3>
[   25.665271] md/raid1:md2: active with 2 out of 2 mirrors
[   25.668538] md2: detected capacity change from 0 to 13995679350784
[   26.791648] BTRFS: device label 2020.03.07-20:16:13 v24922 devid 1 transid 4231630 /dev/md2
[   26.792160] BTRFS info (device md2): enabling auto syno reclaim space
[   26.792166] BTRFS info (device md2): using free space tree
[   26.792168] BTRFS info (device md2): has skinny extents
[   26.839054] BTRFS: device label 2021.02.10-12:01:26 v25426 devid 1 transid 25676 /dev/vg1000/lv
[   26.839809] BTRFS info (device dm-0): enabling auto syno reclaim space
[   26.839815] BTRFS info (device dm-0): use ssd allocation scheme
[   26.839818] BTRFS info (device dm-0): using free space tree
[   26.839819] BTRFS info (device dm-0): has skinny extents
[   28.232227] r8168: eth0: link up
[   48.166390] BTRFS error (device md2): parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   48.172185] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   48.172597] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   48.186791] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487648
[   48.187652] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487672
[   48.188538] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487664
[   48.189444] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487656
[   48.190348] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   48.190352] BTRFS error (device md2): BTRFS: md2 failed to repair parent transid verify failure on 142428061696, mirror = 2
[   48.191765] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   48.191953] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   48.192634] BTRFS: error (device md2) in btrfs_replay_log:3070: errno=-5 IO failure (Failed to recover log tree)
[   48.248481] usrquota update failed root[257], uid[0]
[   48.248484] usrquota update failed root[257], uid[0]
[   48.248486] usrquota update failed root[257], uid[0]
[   48.248488] usrquota update failed root[257], uid[0]
[   48.248489] usrquota update failed root[257], uid[0]
[   48.248491] usrquota update failed root[257], uid[0]
[   48.248492] usrquota update failed root[257], uid[0]
[   48.261540] usrquota update failed root[257], uid[0]
[   48.261571] BTRFS info (device md2): delayed_refs has NO entry
[   48.262378] BTRFS error (device md2): cleaner transaction attach returned -30
[   48.949068] BTRFS: open_ctree failed
[   49.104281] BTRFS info (device md2): enabling auto syno reclaim space
[   49.104288] BTRFS info (device md2): using free space tree
[   49.104290] BTRFS info (device md2): has skinny extents
[   69.038555] BTRFS error (device md2): parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   69.044331] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   69.044799] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   69.083818] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487672
[   69.084665] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487664
[   69.085514] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487656
[   69.086364] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487648
[   69.087247] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   69.087251] BTRFS error (device md2): BTRFS: md2 failed to repair parent transid verify failure on 142428061696, mirror = 2
[   69.088631] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   69.088834] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[   69.089376] BTRFS: error (device md2) in btrfs_replay_log:3070: errno=-5 IO failure (Failed to recover log tree)
[   69.115763] usrquota update failed root[257], uid[0]
[   69.115766] usrquota update failed root[257], uid[0]
[   69.115767] usrquota update failed root[257], uid[0]
[   69.115769] usrquota update failed root[257], uid[0]
[   69.115770] usrquota update failed root[257], uid[0]
[   69.115772] usrquota update failed root[257], uid[0]
[   69.115773] usrquota update failed root[257], uid[0]
[   69.130959] usrquota update failed root[257], uid[0]
[   69.130988] BTRFS info (device md2): delayed_refs has NO entry
[   69.131758] BTRFS error (device md2): cleaner transaction attach returned -30
[   69.738398] BTRFS: open_ctree failed
[   69.876442] BTRFS info (device md2): disabling log replay at mount time
[   69.876447] BTRFS info (device md2): using free space tree
[   69.876449] BTRFS info (device md2): has skinny extents
[   89.253954] BTRFS info (device md2): checking UUID tree
[   90.670917] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   90.670921] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[   90.695215] ehci-pci: EHCI PCI platform driver
[   90.729615] uhci_hcd: USB Universal Host Controller Interface driver
[   90.843419] usbcore: registered new interface driver usblp
[   90.932824] usbcore: registered new interface driver usbhid
[   90.932828] usbhid: USB HID core driver
[   92.759758] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_init RODSP server started, login_key(0011328f44f0).
[   92.782853] iSCSI:extent_pool.c:766:ep_init syno_extent_pool successfully initialized
[   92.804667] iSCSI:target_core_device.c:617:se_dev_align_max_sectors Rounding down aligned max_sectors from 4294967295 to 4294967288
[   92.804793] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[   92.887563] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plugin for fileio is enabled.
[   92.887571] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled.
[   92.887585] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled.
[   92.887603] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled.
[   92.887605] iSCSI:target_core_ep.c:793:ep_attach_hba ODX Token Manager is enabled.
[   92.904404] FAT-fs (synoboot2): fat_set_state: set=1 process=synopkicompatsy pid=12822
[   92.918673] FAT-fs (synoboot2): fat_set_state: set=0 process=synopkicompatsy pid=12822
[   94.266106] loop: module loaded
[   95.110352] ata1.00: configured for UDMA/133
[   95.110361] ata1: EH complete
[   95.239782] ata2.00: configured for UDMA/133
[   95.239792] ata2: EH complete
[   95.330632] ata4.00: configured for UDMA/133
[   95.330639] ata4: EH complete
[   95.577745] capability: warning: `nginx' uses 32-bit capabilities (legacy support in use)
[  265.302107] init: pkgctl-UltimateBackup pre-start process (15620) terminated with status 1
[  267.571367] init: synoscheduler-vmtouch main process (5251) killed by TERM signal
[  267.718186] init: synoscheduler-vmtouch main process (17469) killed by TERM signal
[  267.862823] init: synoscheduler-vmtouch main process (17478) killed by TERM signal
[  267.992733] init: synoscheduler-vmtouch main process (17496) killed by TERM signal
[  268.139797] init: synoscheduler-vmtouch main process (17505) killed by TERM signal
[  268.282263] init: synoscheduler-vmtouch main process (17514) killed by TERM signal
[  271.980877] BTRFS error (device md2): parent transid verify failed on 3313762107392 wanted 4225983 found 4030305
[  271.989082] parent transid verify failed on 3313762107392 wanted 4225983 found 4030305
[  272.019062] parent transid verify failed on 3313762107392 wanted 4225983 found 4030305
[  272.067206] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 6464867992
[  272.068074] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 6464867984
[  272.068927] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 6464867976
[  272.069766] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 6464867968
[  272.070630] parent transid verify failed on 3313762107392 wanted 4225983 found 4030305
[  272.070635] BTRFS error (device md2): BTRFS: md2 failed to repair parent transid verify failure on 3313762107392, mirror = 2
[  272.110685] BTRFS info (device md2): no csum found for inode 1157479 start 200704
[  272.120094] parent transid verify failed on 3313762107392 wanted 4225983 found 4030305
[  272.120275] parent transid verify failed on 3313762107392 wanted 4225983 found 4030305
[  272.120289] BTRFS info (device md2): no csum found for inode 1157479 start 204800
[  272.137650] BTRFS warning (device md2): csum failed ino 1157479 off 200704 csum 228389671 expected csum 0
[  272.137659] BTRFS warning (device md2): csum failed ino 1157479 off 204800 csum 1024926355 expected csum 0
[  272.782481] aufs 4.4-20160328
[  272.811972] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[  272.879095] Bridge firewalling registered
[  273.129888] IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
[  273.130145] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[  273.130212] IPVS: Creating netns size=2096 id=0
[  273.130229] IPVS: ipvs loaded.
[  273.139796] IPVS: [rr] scheduler registered.
[  274.921174] workqueue: max_active 1024 requested for vhost_scsi is out of range, clamping between 1 and 512
[  277.080713] tun: Universal TUN/TAP device driver, 1.6
[  277.080717] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[  279.935712] device virbr0-nic entered promiscuous mode
[  279.957485] device virbr0-nic left promiscuous mode
[  279.957502] virbr0: port 1(virbr0-nic) entered disabled state
[  280.035873] IPv6: ADDRCONF(NETDEV_UP): docker-b08e6c7c: link is not ready
[  280.189940] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[  280.349464] IPv6: ADDRCONF(NETDEV_UP): docker-ec994bb6: link is not ready
[  281.472087] init: scsi_plugin_server main process (12946) killed by TERM signal
[  281.573996] init: iscsi_pluginserverd main process (20168) killed by TERM signal
[  281.576034] init: iscsi_pluginengined main process (20156) killed by TERM signal
[  281.600920] init: scsi_plugin_server main process (20176) killed by TERM signal
[  282.107080] device docker110530d entered promiscuous mode
[  282.107162] IPv6: ADDRCONF(NETDEV_UP): docker110530d: link is not ready
[  282.169545] init: nmbd main process (20344) killed by TERM signal
[  283.259074] BTRFS error (device md2): parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[  283.273184] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[  283.273653] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[  283.286530] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487648
[  283.287397] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487672
[  283.288252] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487664
[  283.289094] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1327): No suitable device for self healing retry read at round 4 at sector 284487656
[  283.289979] parent transid verify failed on 142428061696 wanted 4230078 found 4230073
[  283.289985] BTRFS error (device md2): BTRFS: md2 failed to repair parent transid verify failure on 142428061696, mirror = 2
[  283.291208] ------------[ cut here ]------------
[  283.291233] WARNING: CPU: 1 PID: 36 at fs/btrfs/extent-tree.c:3221 btrfs_run_delayed_refs+0x2f0/0x320 [btrfs]()
[  283.291235] BTRFS: Transaction aborted (error -5)
[  283.291236] Modules linked in: pci_stub vhost_net(O) tun kvm_intel kvm irqbypass vhost_scsi(O) vhost(O) xt_ipvs ip_vs_rr ip_vs xt_mark iptable_mangle br_netfilter bridge stp aufs macvlan veth xt_conntrack xt_addrtype ipt_MASQUERADE xt_REDIRECT nf_nat_masquerade_ipv4 xt_nat iptable_nat nf_nat_ipv4 nf_nat_redirect nf_nat cifs udf isofs loop tcm_loop(O) iscsi_target_mod(O) target_core_ep(O) target_core_multi_file(O) target_core_file(O) target_core_iblock(O) target_core_mod(O) syno_extent_pool(PO) rodsp_ep(O) hid_generic usbhid hid usblp uhci_hcd ehci_pci ehci_hcd xt_mac xt_geoip(O) compat_xtables(O) nf_conntrack_ipv6 ip6table_filter ip6_tables xt_recent xt_iprange xt_limit xt_state xt_tcpudp xt_multiport xt_LOG nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables x_tables cdc_acm ppp_async ppp_generic
[  283.291287]  slhc openvswitch gre nf_defrag_ipv6 nf_conntrack apollolake_synobios(PO) firewire_sbp2(E) firewire_ohci(E) firewire_core(E) aqc111(OE) et131x(E) vxge(E) s2io(E) r8125(OE) r8152(OE) via_velocity(E) via_rhine(E) sc92031(E) rtl8150(E) plusb(E) pegasus(E) mvmdio(E) mcs7830(E) enic(E) e100(E) dl2k(E) cxgb4(E) cxgb3(E) cxgb(E) cx82310_eth(E) bna(E) atl2(E) asix(E) evdev(E) ax88179_178a(E) tg3(E) r8101(OE) bnx2(E) vmxnet3(E) pcnet32(E) e1000(E) sfc(E) netxen_nic(E) qlge(E) qlcnic(E) qla3xxx(E) sky2(E) skge(E) jme(E) uio(E) alx(E) atl1c(E) atl1e(E) atl1(E) r8169(OE) usbnet(E) libphy(E) mii(E) exfat(O) btrfs i915 drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops cfbfillrect cfbcopyarea cfbimgblt drm drm_panel_orientation_quirks iosf_mbi fb fbdev video backlight button(E) synoacl_vfs(PO)
[  283.291337]  hfsplus md4 hmac bnx2x(E) mlx5_core(E) mlx4_en(E) mlx4_core(E) mlx_compat(OE) atlantic(OE) r8168(OE) tn40xx(OE) i40e(E) ixgbe(OE) be2net(E) igb(OE) i2c_algo_bit e1000e(OE) vxlan ip6_udp_tunnel udp_tunnel fuse vfat fat crc32c_intel aesni_intel glue_helper lrw gf128mul ablk_helper arc4 cryptd ecryptfs sha256_generic ecb aes_x86_64 authenc des_generic ansi_cprng cts md5 cbc cpufreq_powersave cpufreq_performance acpi_cpufreq processor cpufreq_stats dm_snapshot dm_bufio crc_itu_t(E) crc_ccitt(E) quota_v2 quota_tree psnap p8022 llc sit tunnel4 ip_tunnel ipv6 zram sg etxhci_hcd sx8(E) aic94xx(E) mvumi(E) mvsas(E) isci(E) hptiop(E) hpsa(E) gdth(E) arcmsr(E) aacraid(E) 3w_sas(E) 3w_9xxx(E) rtc_cmos(E) mdio(E) mpt3sas(E) mptsas(E) megaraid_sas(E) megaraid(E) mptctl(E) mptspi(E) mptscsih(E) mptbase(E)
[  283.291391]  megaraid_mbox(E) megaraid_mm(E) vmw_pvscsi(E) BusLogic(E) raid_class(E) libsas(E) scsi_transport_sas(E) scsi_transport_spi(E) usb_storage xhci_pci xhci_hcd ohci_hcd(E) usbcore usb_common hpppfxm(OE) [last unloaded: apollolake_synobios]
[  283.291405] CPU: 1 PID: 36 Comm: kworker/u8:2 Tainted: P           OE   4.4.59+ #25426
[  283.291406] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./J4105-ITX, BIOS P1.60 01/17/2020
[  283.291423] Workqueue: btrfs-extent-refs btrfs_extent_refs_helper [btrfs]
[  283.291425]  0000000000000000 ffff88046dfc7cb0 ffffffff812bb8cd ffff88046dfc7cf8
[  283.291427]  ffffffffa0c051fa ffff88046dfc7ce8 ffffffff8104a1fd ffff88041de96210
[  283.291430]  ffff880466158800 ffff8800713b5f00 0000000000000020 00000000fffffffb
[  283.291432] Call Trace:
[  283.291439]  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[  283.291443]  [<ffffffff8104a1fd>] warn_slowpath_common+0x7d/0xc0
[  283.291446]  [<ffffffff8104a289>] warn_slowpath_fmt+0x49/0x50
[  283.291460]  [<ffffffffa0b5db20>] btrfs_run_delayed_refs+0x2f0/0x320 [btrfs]
[  283.291474]  [<ffffffffa0b5db82>] delayed_ref_async_start+0x32/0x90 [btrfs]
[  283.291488]  [<ffffffffa0babfdd>] normal_work_helper+0x19d/0x1b0 [btrfs]
[  283.291502]  [<ffffffffa0bac26d>] btrfs_extent_refs_helper+0xd/0x10 [btrfs]
[  283.291506]  [<ffffffff8105fe92>] process_one_work+0x142/0x360
[  283.291508]  [<ffffffff8106055a>] worker_thread+0x4a/0x450
[  283.291512]  [<ffffffff8157328f>] ? __schedule+0x2af/0x730
[  283.291514]  [<ffffffff81060510>] ? max_active_store+0x60/0x60
[  283.291516]  [<ffffffff81060510>] ? max_active_store+0x60/0x60
[  283.291519]  [<ffffffff810652d6>] kthread+0xc6/0xe0
[  283.291521]  [<ffffffff81065210>] ? kthread_create_on_node+0x180/0x180
[  283.291524]  [<ffffffff8157783f>] ret_from_fork+0x3f/0x80
[  283.291526]  [<ffffffff81065210>] ? kthread_create_on_node+0x180/0x180
[  283.291528] ---[ end trace 34d7e01c8917b95a ]---
[  283.291531] BTRFS: error (device md2) in btrfs_run_delayed_refs:3221: errno=-5 IO failure
[  283.292040] BTRFS info (device md2): forced readonly
[  283.329714] docker0: port 1(docker110530d) entered disabled state
[  283.329770] BTRFS info (device md2): delayed_refs has NO entry
[  283.331714] device docker110530d left promiscuous mode
[  283.331720] docker0: port 1(docker110530d) entered disabled state
[  283.348705] device docker581e04b entered promiscuous mode
[  283.349299] IPv6: ADDRCONF(NETDEV_UP): docker581e04b: link is not ready
[  283.351495] docker0: port 1(docker581e04b) entered disabled state
[  283.358822] device docker581e04b left promiscuous mode
[  283.358828] docker0: port 1(docker581e04b) entered disabled state
[  283.371269] device docker97a4812 entered promiscuous mode
[  283.371354] IPv6: ADDRCONF(NETDEV_UP): docker97a4812: link is not ready
[  283.371358] docker0: port 1(docker97a4812) entered forwarding state
[  283.371372] docker0: port 1(docker97a4812) entered forwarding state
[  283.373966] docker0: port 1(docker97a4812) entered disabled state
[  283.374188] device docker97a4812 left promiscuous mode
[  283.374191] docker0: port 1(docker97a4812) entered disabled state
[  283.386806] device dockerf2166af entered promiscuous mode
[  283.386886] IPv6: ADDRCONF(NETDEV_UP): dockerf2166af: link is not ready
[  283.386890] docker0: port 1(dockerf2166af) entered forwarding state
[  283.386904] docker0: port 1(dockerf2166af) entered forwarding state
[  283.388730] docker0: port 1(dockerf2166af) entered disabled state
[  283.389013] device dockerf2166af left promiscuous mode
[  283.389016] docker0: port 1(dockerf2166af) entered disabled state
[  284.293303] init: iscsi_pluginserverd main process (20225) killed by TERM signal
[  284.294358] init: iscsi_pluginengined main process (20222) killed by TERM signal
[  284.311482] init: scsi_plugin_server main process (20231) killed by TERM signal
[  284.580020] init: iscsi_pluginserverd main process (21012) killed by TERM signal
[  284.581069] init: iscsi_pluginengined main process (21011) killed by TERM signal
[  284.598141] init: scsi_plugin_server main process (21015) killed by TERM signal
[  284.665366] init: pkg-Docker-dockerd main process (18225) terminated with status 1
[  284.665431] init: pkg-Docker-dockerd main process ended, respawning
[  284.718521] init: pkg-Docker-dockerd main process (21041) terminated with status 1
[  284.718568] init: pkg-Docker-dockerd main process ended, respawning
[  284.774638] init: pkg-Docker-dockerd main process (21052) terminated with status 1
[  284.774686] init: pkg-Docker-dockerd main process ended, respawning
[  284.835398] init: pkg-Docker-dockerd main process (21061) terminated with status 1
[  284.835444] init: pkg-Docker-dockerd main process ended, respawning
[  284.913336] init: pkg-Docker-dockerd main process (21071) terminated with status 1
[  284.913379] init: pkg-Docker-dockerd main process ended, respawning
[  284.981879] init: pkg-Docker-dockerd main process (21091) terminated with status 1
[  284.981926] init: pkg-Docker-dockerd respawning too fast, stopped
[  287.794467] init: pkg-Docker-dockerd main process (21583) terminated with status 1
[  287.794512] init: pkg-Docker-dockerd main process ended, respawning
[  287.846327] init: pkg-Docker-dockerd main process (21601) terminated with status 1
[  287.846373] init: pkg-Docker-dockerd main process ended, respawning
[  287.899855] init: pkg-Docker-dockerd main process (21610) terminated with status 1
[  287.899899] init: pkg-Docker-dockerd main process ended, respawning
[  287.961835] init: pkg-Docker-dockerd main process (21621) terminated with status 1
[  287.961881] init: pkg-Docker-dockerd main process ended, respawning
[  288.014014] init: pkg-Docker-dockerd main process (21639) terminated with status 1
[  288.014061] init: pkg-Docker-dockerd main process ended, respawning
[  288.063942] init: pkg-Docker-dockerd main process (21648) terminated with status 1
[  288.063987] init: pkg-Docker-dockerd respawning too fast, stopped
[  289.578661] init: synocontentextractd main process ended, respawning
[  290.918639] init: pkg-Docker-dockerd main process (22139) terminated with status 1
[  290.918685] init: pkg-Docker-dockerd main process ended, respawning
[  290.970968] init: pkg-Docker-dockerd main process (22156) terminated with status 1
[  290.971013] init: pkg-Docker-dockerd main process ended, respawning
[  291.027983] init: pkg-Docker-dockerd main process (22165) terminated with status 1
[  291.028032] init: pkg-Docker-dockerd main process ended, respawning
[  291.082065] init: pkg-Docker-dockerd main process (22174) terminated with status 1
[  291.082111] init: pkg-Docker-dockerd main process ended, respawning
[  291.135019] init: pkg-Docker-dockerd main process (22182) terminated with status 1
[  291.135065] init: pkg-Docker-dockerd main process ended, respawning
[  291.191130] init: pkg-Docker-dockerd main process (22191) terminated with status 1
[  291.191176] init: pkg-Docker-dockerd respawning too fast, stopped
[  294.230006] init: pkgctl-Docker pre-start process (15615) terminated with status 1
[  294.599154] IPVS: [rr] scheduler unregistered.
[  294.636198] IPVS: ipvs unloaded.
Any idea how to fix the problems? Thank you.
Edited by tdse13
3 answers to this question
Some more information:
lvm> vgs
  VG     #PV #LV #SN Attr   VSize   VFree
  vg1000   1   1   0 wz--n- 442.52g    0
lvm> pvs
  PV         VG     Fmt  Attr PSize   PFree
  /dev/md3   vg1000 lvm2 a--  442.52g    0
lvm> lvs
  LV   VG     Attr       LSize   Pool Origin Data%  Meta%  Move Log Cpy%Sync Convert
  lv   vg1000 -wi-ao---- 442.52g
lvm> lvscan
  ACTIVE            '/dev/vg1000/lv' [442.52 GiB] inherit
lvm> lvmdiskscan
  /dev/md2 [      12.73 TiB]
  /dev/md3 [     442.52 GiB] LVM physical volume
  0 disks
  1 partition
  0 LVM physical volume whole disks
  1 LVM physical volume
lvm> pvscan
  PV /dev/md3   VG vg1000   lvm2 [442.52 GiB / 0    free]
  Total: 1 [442.52 GiB] / in use: 1 [442.52 GiB] / in no VG: 0 [0   ]
lvm> vgs
Any solution available? Thank you.
Answer this question...
