Raice Posted December 17, 2015 #1 Posted December 17, 2015 Hello! Just assembled temporary NAS box. ASUS P5KPL-AM +2*500GB WD HDDs, 2GB RAM. Booting XPenoboot from USB. Installed .pat file successfully, but cannot create volume. Tried reinstalling from scratch - same. This is screenshot with error DSM Version - latest from xpenology Please help
skylinegtr Posted December 17, 2015 #2 Posted December 17, 2015 I have same problem and don't know how to solve this Even though update 2, still cannot fix it.
andale Posted December 17, 2015 #3 Posted December 17, 2015 There is a known error with the PAT file for 5644. Please use this file for installation from the "official" XPEnology download page: https://drive.google.com/open?id=0B8WTs ... XNxb1FiWW8
brantje Posted December 18, 2015 #4 Posted December 18, 2015 There is a known error with the PAT file for 5644. Please use this file for installation from the "official" XPEnology download page: https://drive.google.com/open?id=0B8WTs ... XNxb1FiWW8 You got more info about that?
Sonnyboy666 Posted December 18, 2015 #5 Posted December 18, 2015 There is a known error with the PAT file for 5644. Please use this file for installation from the "official" XPEnology download page: https://drive.google.com/open?id=0B8WTs ... XNxb1FiWW8 You got more info about that? http://xpenology.com/forum/viewtopic.php?f=2&t=9578
Here2rock Posted December 18, 2015 #6 Posted December 18, 2015 There is a known error with the PAT file for 5644. Please use this file for installation from the "official" XPEnology download page: https://drive.google.com/open?id=0B8WTs ... XNxb1FiWW8 How do you use the pat file again with your setup? If there is known error then why is it still linked in main download page?
skylinegtr Posted December 19, 2015 #7 Posted December 19, 2015 I found the way to solve this problem~ I use factory rest and wipe all data~ reinstall it After install, create volume then update 1 or 2 later~ If update first, the problem is back again. However, I have new system and no data so I can try factory reset. If you have important data files, you may need to backup before factory rest.
bsalvador Posted December 21, 2015 #8 Posted December 21, 2015 Install 5592 version and create the volumes. after that you may upgrade.
brantje Posted December 22, 2015 #9 Posted December 22, 2015 Downgrading to 5592, create volume will also work i think. Have to try this on a Virtual Machine.
Raice Posted December 25, 2015 Author #10 Posted December 25, 2015 Thanks to all! Downloaded from another source and everything is OK now. By the way, is it safe to upgrade to Update-2?
brantje Posted December 25, 2015 #11 Posted December 25, 2015 Thanks to all! Downloaded from another source and everything is OK now.By the way, is it safe to upgrade to Update-2? 5592 update 2?
