Problem adding additional hard drives via eSATA
computech1228
Hey All,
So here is the situation, I am trying to add additional hard drives on an eSATA interface. I currently am using a Gigabyte GA-78LMT-USB3 motherboard, I just added a Startech.com 5 bay hard drive enclosure. I currently have 4 hard drives loaded. The bios is set for AHCI and the bios does recognize the drives during boot. The issue that I am running into is that I can see all 4 drives with the USB 3.0 connection however when connected via eSATA I can only see 1 drive. The eSATA connection is using a eSATA to SATA adapter plate and is plugged directly into the motherboard. Also when I plug in my WD 4TB My Book (to use a local backup destination) DSM does not see that drive. Has anyone ran into this issue or have a solution. Thanks!
I have edited the synoinfo.config file in both the /etc and /etc.defaults directories with the following settings.
maxdisks="24"
esataportcfg="0x0"
internalportcfg="0xffffff"
usbportcfg="0x0"
I am currently on DSM 5.2.5592 update 4
Actually I ended up finding something that I think would work better for my use case. Startech.com makes a hard drive enclosure where they provide a eSATA to SATA plate. The cable plugs directly into the SATA port on your motherboard and then you plug an eSATA plug from the adapter plate to the hard drive enclosure. It basically should see it as another set of hard drives. Which is strange how it works no problem when connected USB.
http://www.startech.com/HDD/Enclosures/ ... 355BU33ERM
Nice unit
However I think it has a built in sata port multiplier based on the jmicron chipset and this is not 'seen' by XPE so only one SATA channel shows up.
I had the same problem (but I had a stand alone multiplier) so I went with a 'dumb' enclosure and wired up directly to a controller card on the mobo
Currently I have 6 SATA ports on the motherboard, all which have a drive attached to. I added the 5 bay hard drive (which are loaded up with all 5 disks) connected to a USB 3.0 port, but I can only see 4 out of those drives. I intend on adding a SATA controller card to enable my 7th internal drive. The card I am looking at is a Syba 4 port host controller. I want to have additional ports for the future in case I want to add another 5 disk hard drive enclousure should i need more space down the road.
So to get this to work do I have the wrong settings. I'm not sure why adding additional disks is so difficult. I'd like to set it up that no matter what interface I plug a disk in that the system recognizes it. Between this and constantly having to fix CrashPlan is very frustrating. I'd welcome any suggestions or would like to know what others are using on there builds
maxdisks="30"
esataportcfg="0x0"
usbportcfg="0x0"
how many slots show up in storage manager?
when you plug in the usb/esata disks do they appear in empty slots?
you need to work out the hex values for int disks/usb/esata based on how your controllers are interpreted by DSM and then all disks should show up, provided all the hardware is compatible with the XPE drivers.
values of 0x0 means no disks of that type, plus when working out the hex values i think you need to pad with '0' s so the values map/align as in the default setup ie
esataportcfg="0xff000"
usbportcfg="0x300000"
if the syba controller you are planning to use is this
http://www.amazon.co.uk/Syba-PCI-e-Cont ... e+brackets
then i can tell you it works ok with XPE as I've used it myself :smile:
it shows the "30" slots i told it i wanted, all hard drives plugged in directly to the motherboard show up and can be added to the drive pools. However (LOL) of the 5 disks that are in the external hard drive enclosure, only 4 show up. I will try your settings and update the thread. I am not sure why any drive on any interface would show up in storage manager.
Take a look at this recent post where someone was building a 45 drive array, similar issues as you and there is some reference to working out the hex values.
viewtopic.php?f=2&t=9943
In your hardware the controllers will be interpreted by the bios, PCI slots and other settings to a unique layout and loaded by the XPE drivers/DSM.
You then have to work out the hex parameters depending on how DSM is going to interpret the resulting configuration.
The binary to hex table of 0s and 1s isnt linux, its how you do the conversion of what drive device is in what slot, to a parameter for the synoinfo.conf file.
I think you are on the right track because you are seeing drives appearing but not all of them, but you might have to do some trial and error to get the exact binary/hex configuration to match your hardware.
hope that helps
So I tried messaging around around with some of the values, I am able to get close to see all of the drives but not all of them.
@sbv3000 - I did get the sata controller not exactly the same one you have this one is the SI-PEX40065 (which also has a Marvell chipset, its all that was in stock)
Drive Config 12 total
6 connected to the motherboard
5 connected to an eSATA port on the SI-PEX40065 SATA Controller Card in PCIe 1x port
1 addtional hard drive connected to one of the SATA ports on the SI-PEX40065 SATA Controller Card
Just to mention 1 USB thumbdrive to boot from
I was wondering if anyone would be willing to help me figure out the codes as I've spent countless hours on this already. Below is the output from dmesg.....Any help would be appreciated.
[ 1.714314] ahci 0000:00:11.0: version 3.0
[ 1.714549] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[ 1.714553] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pioslum part ccc sxs
[ 1.720647] scsi0 : ahci
[ 1.721920] scsi1 : ahci
[ 1.722465] scsi2 : ahci
[ 1.722976] scsi3 : ahci
[ 1.724296] scsi4 : ahci
[ 1.724990] scsi5 : ahci
[ 1.725469] ata1: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f100 irq 22
[ 1.725472] ata2: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f180 irq 22
[ 1.725475] ata3: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f200 irq 22
[ 1.725477] ata4: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f280 irq 22
[ 1.725480] ata5: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f300 irq 22
[ 1.725482] ata6: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f380 irq 22
[ 1.725591] ahci 0000:03:00.0: irq 43 for MSI/MSI-X
[ 1.736268] ahci 0000:03:00.0: AHCI 0001.0000 32 slots 4 ports 6 Gbps 0xf imp l SATA mode
[ 1.736271] ahci 0000:03:00.0: flags: 64bit ncq sntf led only pmp fbs pio slu m part sxs
[ 1.739304] scsi6 : ahci
[ 1.740232] scsi7 : ahci
[ 1.741183] scsi8 : ahci
[ 1.741645] scsi9 : ahci
[ 1.741770] ata7: SATA max UDMA/133 abar m2048@0xfdeff000 port 0xfdeff100 irq 43
[ 1.741773] ata8: SATA max UDMA/133 abar m2048@0xfdeff000 port 0xfdeff180 irq 43
[ 1.741777] ata9: SATA max UDMA/133 abar m2048@0xfdeff000 port 0xfdeff200 irq 43
[ 1.741780] ata10: SATA max UDMA/133 abar m2048@0xfdeff000 port 0xfdeff280 ir q 43
[ 1.745785] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.777459] i8042: Failed to disable AUX port, but continuing anyway... Is th is a SiS?
[ 1.777461] i8042: If AUX port is really absent please use the 'i8042.noaux' option
[ 2.027034] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.027336] rtc_cmos 00:04: RTC can wake from S4
[ 2.027500] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 2.027536] rtc_cmos 00:04: alarms up to one month, 242 bytes nvram, hpet irq s
[ 2.027580] i2c /dev entries driver
[ 2.027647] md: linear personality registered for level -1
[ 2.027649] md: raid0 personality registered for level 0
[ 2.027650] md: raid1 personality registered for level 1
[ 2.027651] md: raid10 personality registered for level 10
[ 2.027688] md: raid6 personality registered for level 6
[ 2.027690] md: raid5 personality registered for level 5
[ 2.027691] md: raid4 personality registered for level 4
[ 2.027793] device-mapper: ioctl: 4.25.0-ioctl (2013-06-26) initialised: dm-d evel@redhat.com
[ 2.027795] cpuidle: using governor ladder
[ 2.027796] cpuidle: using governor menu
[ 2.027870] TCP: cubic registered
[ 2.027872] NET: Registered protocol family 17
[ 2.027896] Key type dns_resolver registered
[ 2.045973] ata7: SATA link down (SStatus 0 SControl 300)
[ 2.046976] ata10: SATA link down (SStatus 0 SControl 300)
[ 2.184826] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.184848] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.184870] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.184891] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.184914] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.184933] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.185818] ata3.00: ATA-9: ST3000DM001-1ER166, CC25, max UDMA/133
[ 2.185820] ata3.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.185885] ata4.00: ATA-9: ST3000DM001-1ER166, CC25, max UDMA/133
[ 2.185887] ata4.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.185940] ata1.00: ATA-8: ST3500418AS, CC38, max UDMA/133
[ 2.185942] ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 2.186285] ata5.00: ATA-8: Hitachi HUA722020ALA331, JKAOA3FD, max UDMA/133
[ 2.186286] ata5.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.186327] ata6.00: ATA-8: Hitachi HUA722020ALA331, JKAOA3FD, max UDMA/133
[ 2.186328] ata6.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.186852] ata3.00: configured for UDMA/133
[ 2.186974] ata4.00: configured for UDMA/133
[ 2.187149] ata1.00: configured for UDMA/133
[ 2.187309] ata2.00: ATA-8: WDC WD5000AADS-00M2B0, 01.00A01, max UDMA/133
[ 2.187310] ata2.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.187784] ata5.00: configured for UDMA/133
[ 2.187833] ata6.00: configured for UDMA/133
[ 2.188127] scsi 0:0:0:0: Direct-Access ATA ST3500418AS CC38 PQ: 0 ANSI: 5
[ 2.188418] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.188496] sd 0:0:0:0: [sda] Write Protect is off
[ 2.188498] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.188518] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 2.188828] ata2.00: configured for UDMA/133
[ 2.190214] scsi 1:0:0:0: Direct-Access WDC WD5000AADS-00M2B0 01.0 PQ: 0 ANSI: 5
[ 2.190670] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.190720] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.190724] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.190747] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 2.201793] ata9: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.203182] ata9.00: ATA-8: Hitachi HUA722020ALA331, JKAOA3FD, max UDMA/133
[ 2.203184] ata9.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.204695] ata9.00: configured for UDMA/133
[ 2.205119] scsi 2:0:0:0: Direct-Access ATA ST3000DM001-1ER166 CC25 PQ: 0 ANSI: 5
[ 2.205428] sd 2:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2. 72 TiB)
[ 2.205430] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[ 2.205511] sd 2:0:0:0: [sdc] Write Protect is off
[ 2.205514] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.205603] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 2.206053] scsi 3:0:0:0: Direct-Access ATA ST3000DM001-1ER166 CC25 PQ: 0 ANSI: 5
[ 2.206918] sd 3:0:0:0: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2. 72 TiB)
[ 2.206921] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[ 2.206958] sd 3:0:0:0: [sdd] Write Protect is off
[ 2.206961] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 2.206977] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 2.209322] scsi 4:0:0:0: Direct-Access Hitachi HUA722020ALA331 JKAO PQ: 0 ANSI: 5
[ 2.209323] sdb: sdb1 sdb2 sdb3 < sdb5 >
[ 2.210072] sd 4:0:0:0: [sde] 3907029168 512-byte logical blocks: (2.00 TB/1. 81 TiB)
[ 2.210132] sd 4:0:0:0: [sde] Write Protect is off
[ 2.210135] sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
[ 2.210155] sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 2.211267] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.212168] scsi 5:0:0:0: Direct-Access Hitachi HUA722020ALA331 JKAO PQ: 0 ANSI: 5
[ 2.213251] sda: sda1 sda2 sda3 < sda5 >
[ 2.213496] sd 5:0:0:0: [sdf] 3907029168 512-byte logical blocks: (2.00 TB/1. 81 TiB)
[ 2.213544] sd 5:0:0:0: [sdf] Write Protect is off
[ 2.213548] sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[ 2.213565] sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 2.217831] sde: unknown partition table
[ 2.217980] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.218535] sd 4:0:0:0: [sde] Attached SCSI disk
[ 2.222354] sdf: unknown partition table
[ 2.222849] sd 5:0:0:0: [sdf] Attached SCSI disk
[ 2.259475] sdd: sdd1 sdd2 sdd5 sdd6
[ 2.260087] sd 3:0:0:0: [sdd] Attached SCSI disk
[ 2.278434] sdc: sdc1 sdc2 sdc5 sdc6
[ 2.279074] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 2.466532] tsc: Refined TSC clocksource calibration: 3515.549 MHz
[ 2.466541] Switching to clocksource tsc
[ 3.066962] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.152571] ata8.15: Port Multiplier 1.2, 0x197b:0x575f r0, 1 ports, feat 0x5 /0xf
[ 4.161199] ahci 0000:03:00.0: FBS is enabled
[ 4.161288] ata8.00: hard resetting link
[ 4.465831] ahci 0000:03:00.0: FBS is disabled
[ 4.620485] ahci 0000:03:00.0: FBS is enabled
[ 4.620762] ata8.00: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.622180] ata8.00: ATA-8: HGST HDN724030ALE640, MJ8OA5E0, max UDMA/133
[ 4.622182] ata8.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 4.623627] ata8.00: configured for UDMA/133
[ 4.623720] ata8: EH complete
[ 4.624922] scsi 7:0:0:0: Direct-Access HGST HDN724030ALE640 MJ8O PQ: 0 ANSI: 5
[ 4.625187] sd 7:0:0:0: [sdh] 5860533168 512-byte logical blocks: (3.00 TB/2. 72 TiB)
[ 4.625191] sd 7:0:0:0: [sdh] 4096-byte physical blocks
[ 4.625228] sd 7:0:0:0: [sdh] Write Protect is off
[ 4.625230] sd 7:0:0:0: [sdh] Mode Sense: 00 3a 00 00
[ 4.625247] sd 7:0:0:0: [sdh] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 4.626527] scsi 8:0:0:0: Direct-Access Hitachi HUA722020ALA331 JKAO PQ: 0 ANSI: 5
[ 4.626781] sd 8:0:0:0: [sdi] 3907029168 512-byte logical blocks: (2.00 TB/1. 81 TiB)
[ 4.626819] sd 8:0:0:0: [sdi] Write Protect is off
[ 4.626822] sd 8:0:0:0: [sdi] Mode Sense: 00 3a 00 00
[ 4.626865] sd 8:0:0:0: [sdi] Write cache: enabled, read cache: enabled, does n't support DPO or FUA
[ 4.633393] sdi: unknown partition table
[ 4.633592] sd 8:0:0:0: [sdi] Attached SCSI disk
[ 4.656156] sdh: sdh1 sdh2
[ 4.656466] sd 7:0:0:0: [sdh] Attached SCSI disk
[ 4.656485] registered taskstats version 1
[ 4.656780] rtc_cmos 00:04: setting system clock to 2015-12-15 04:26:42 UTC ( 1450153602)
[ 4.658264] Freeing unused kernel memory: 46400k freed
[ 4.672918] Write protecting the kernel read-only data: 8192k
[ 4.674256] Freeing unused kernel memory: 852k freed
[ 4.675156] Freeing unused kernel memory: 476k freed
[ 4.782250] Loading modules backported from Linux version v3.18.1-0-g39ca484
[ 4.782252] Backport generated by backports.git v3.18.1-1-0-g5e9ec4c
[ 4.799853] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
[ 4.803077] dca service started, version 1.12.1
[ 5.042775] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.042865] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 5.042940] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 5.043032] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 5.043217] sd 4:0:0:0: Attached scsi generic sg4 type 0
[ 5.043383] sd 5:0:0:0: Attached scsi generic sg5 type 0
[ 5.043473] sd 7:0:0:0: Attached scsi generic sg6 type 0
[ 5.043810] sd 8:0:0:0: Attached scsi generic sg7 type 0
[ 5.185981] md: Autodetecting RAID arrays.
[ 5.235012] md: invalid raid superblock magic on sda5
[ 5.235015] md: sda5 does not have a valid v0.90 superblock, not importing!
[ 5.267327] md: invalid raid superblock magic on sdb5
[ 5.267330] md: sdb5 does not have a valid v0.90 superblock, not importing!
[ 5.306534] md: invalid raid superblock magic on sdc5
[ 5.306537] md: sdc5 does not have a valid v0.90 superblock, not importing!
[ 5.330527] md: invalid raid superblock magic on sdc6
[ 5.330529] md: sdc6 does not have a valid v0.90 superblock, not importing!
[ 5.372071] md: invalid raid superblock magic on sdd5
[ 5.372073] md: sdd5 does not have a valid v0.90 superblock, not importing!
[ 5.392132] md: invalid raid superblock magic on sdd6
[ 5.392133] md: sdd6 does not have a valid v0.90 superblock, not importing!
[ 5.392137] md: Scanned 14 and added 8 devices.
[ 5.392138] md: autorun ...
[ 5.392139] md: considering sda1 ...
[ 5.392142] md: adding sda1 ...
[ 5.392143] md: sda2 has different UUID to sda1
[ 5.392146] md: adding sdb1 ...
[ 5.392147] md: sdb2 has different UUID to sda1
[ 5.392150] md: adding sdc1 ...
[ 5.392151] md: sdc2 has different UUID to sda1
[ 5.392153] md: adding sdd1 ...
[ 5.392155] md: sdd2 has different UUID to sda1
[ 5.392161] md: created md0
[ 5.392163] md: bind
[ 5.392171] md: bind
[ 5.392176] md: bind
[ 5.392181] md: bind
[ 5.392186] md: running:
[ 5.392339] md/raid1:md0: active with 4 out of 12 mirrors
[ 5.392351] md0: detected capacity change from 0 to 2549940224
[ 5.392409] md: considering sda2 ...
[ 5.392412] md: adding sda2 ...
[ 5.392415] md: adding sdb2 ...
[ 5.392417] md: adding sdc2 ...
[ 5.392419] md: adding sdd2 ...
[ 5.392599] md: created md1
[ 5.392601] md: bind
[ 5.392608] md: bind
[ 5.392614] md: bind
[ 5.392621] md: bind
[ 5.392627] md: running:
[ 5.392809] md/raid1:md1: active with 4 out of 12 mirrors
[ 5.392822] md1: detected capacity change from 0 to 2147418112
[ 5.392871] md: ... autorun DONE.
[ 5.516779] ACPI: bus type USB registered
[ 5.516919] usbcore: registered new interface driver usbfs
[ 5.516990] usbcore: registered new interface driver hub
[ 5.517086] usbcore: registered new interface driver ethub
[ 5.517165] usbcore: registered new device driver usb
[ 5.521882] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 5.522004] ohci_hcd 0000:00:12.0: OHCI Host Controller
[ 5.522009] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus numbe r 1
[ 5.522038] ohci_hcd 0000:00:12.0: irq 16, io mem 0xfe02e000
[ 5.576762] hub 1-0:1.0: USB hub found
[ 5.576768] hub 1-0:1.0: 3 ports detected
[ 5.576891] ohci_hcd 0000:00:12.1: OHCI Host Controller
[ 5.576894] ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus numbe r 2
[ 5.576906] ohci_hcd 0000:00:12.1: irq 16, io mem 0xfe02d000
[ 5.631706] hub 2-0:1.0: USB hub found
[ 5.631712] hub 2-0:1.0: 3 ports detected
[ 5.631833] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 5.631837] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus numbe r 3
[ 5.631859] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfe02b000
[ 5.686653] hub 3-0:1.0: USB hub found
[ 5.686659] hub 3-0:1.0: 3 ports detected
[ 5.686780] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 5.686784] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus numbe r 4
[ 5.686795] ohci_hcd 0000:00:13.1: irq 18, io mem 0xfe02a000
[ 5.741601] hub 4-0:1.0: USB hub found
[ 5.741607] hub 4-0:1.0: 3 ports detected
[ 5.741730] ohci_hcd 0000:00:14.5: OHCI Host Controller
[ 5.741734] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus numbe r 5
[ 5.741746] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfe028000
[ 5.796540] hub 5-0:1.0: USB hub found
[ 5.796547] hub 5-0:1.0: 2 ports detected
[ 5.800632] uhci_hcd: USB Universal Host Controller Interface driver
[ 5.804362] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.804364] Warning! ehci_hcd should always be loaded before uhci_hcd and ohc i_hcd, not after
[ 5.807876] ehci-pci: EHCI PCI platform driver
[ 5.920235] usb 1-1: new full-speed USB device number 2 using ohci_hcd
[ 6.069092] usb 1-1: device descriptor read/64, error -62
[ 6.318853] usb 1-1: device descriptor read/64, error -62
[ 6.563627] usb 1-1: new full-speed USB device number 3 using ohci_hcd
[ 6.712477] usb 1-1: device descriptor read/64, error -62
[ 6.962243] usb 1-1: device descriptor read/64, error -62
[ 7.207006] usb 1-1: new full-speed USB device number 4 using ohci_hcd
[ 7.610626] usb 1-1: device not accepting address 4, error -62
[ 7.754484] usb 1-1: new full-speed USB device number 5 using ohci_hcd
[ 8.157098] usb 1-1: device not accepting address 5, error -62
[ 8.157102] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 8.404864] usb 1-3: new low-speed USB device number 6 using ohci_hcd
[ 8.575677] Got empty serial number. Generate serial number from product.
[ 8.577857] usb 1-3: USB disconnect, device number 6
[ 8.579253] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 8.579260] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus numbe r 6
[ 8.579263] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI d ummy qh workaround
[ 8.579276] ehci-pci 0000:00:12.2: debug port 1
[ 8.579317] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe02c000
[ 8.584690] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 8.585847] hub 6-0:1.0: USB hub found
[ 8.585852] hub 6-0:1.0: 6 ports detected
[ 8.585994] hub 1-0:1.0: USB hub found
[ 8.586001] hub 1-0:1.0: 3 ports detected
[ 8.586294] hub 2-0:1.0: USB hub found
[ 8.586301] hub 2-0:1.0: 3 ports detected
[ 8.586672] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 8.586682] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus numbe r 7
[ 8.586686] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI d ummy qh workaround
[ 8.586698] ehci-pci 0000:00:13.2: debug port 1
[ 8.586735] ehci-pci 0000:00:13.2: irq 19, io mem 0xfe029000
[ 8.592683] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 8.593149] hub 7-0:1.0: USB hub found
[ 8.593154] hub 7-0:1.0: 6 ports detected
[ 8.593356] hub 3-0:1.0: USB hub found
[ 8.593363] hub 3-0:1.0: 3 ports detected
[ 8.593456] hub 4-0:1.0: USB hub found
[ 8.593463] hub 4-0:1.0: 3 ports detected
[ 8.599431] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 8.599437] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus numbe r 8
[ 8.599542] xhci_hcd 0000:02:00.0: irq 45 for MSI/MSI-X
[ 8.599726] xHCI xhci_add_endpoint called for root hub
[ 8.599728] xHCI xhci_check_bandwidth called for root hub
[ 8.599799] hub 8-0:1.0: USB hub found
[ 8.599803] hub 8-0:1.0: 1 port detected
[ 8.599833] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 8.599836] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus numbe r 9
[ 8.599953] xHCI xhci_add_endpoint called for root hub
[ 8.599955] xHCI xhci_check_bandwidth called for root hub
[ 8.600020] hub 9-0:1.0: USB hub found
[ 8.600026] hub 9-0:1.0: 4 ports detected
[ 8.613394] bromolow_synobios: module license 'Synology Inc.' taints kernel.
[ 8.613396] Disabling lock debugging due to kernel taint
[ 8.613759] 2015-12-15 4:26:46 UTC
[ 8.613762] synobios: load, major number 201
[ 8.613765] Brand: Synology
[ 8.613766] Model: DS-3615xs
[ 8.613769] set group disks wakeup number to 4, spinup time deno 7
[ 8.908387] usb 6-1: new high-speed USB device number 2 using ehci-pci
[ 9.114191] synobios cpu_arch proc entry initialized
[ 9.114193] synobios crypto_hw proc entry initialized
[ 9.114195] synobios syno_platform proc entry initialized
[ 9.119732] synobios: unload
[ 9.145788] md0: unknown partition table
[ 45.089632] md/raid1:md3: active with 2 out of 2 mirrors
[ 45.089645] md3: detected capacity change from 0 to 2500475682816
[ 45.090363] md3: unknown partition table
[ 45.096705] md: md2 stopped.
[ 45.097683] md: bind
[ 45.097820] md: bind
[ 45.097963] md: bind
[ 45.098118] md: bind
[ 45.098602] md/raid:md2: device sda5 operational as raid disk 0
[ 45.098604] md/raid:md2: device sdd5 operational as raid disk 3
[ 45.098605] md/raid:md2: device sdc5 operational as raid disk 2
[ 45.098606] md/raid:md2: device sdb5 operational as raid disk 1
[ 45.098839] md/raid:md2: allocated 4344kB
[ 45.098857] md/raid:md2: raid level 5 active with 4 out of 4 devices, algorit hm 2
[ 45.098859] RAID conf printout:
[ 45.098860] --- level:5 rd:4 wd:4
[ 45.098861] disk 0, o:1, dev:sda5
[ 45.098862] disk 1, o:1, dev:sdb5
[ 45.098863] disk 2, o:1, dev:sdc5
[ 45.098864] disk 3, o:1, dev:sdd5
[ 45.098887] md2: detected capacity change from 0 to 1485481771008
[ 45.102218] md2: unknown partition table
[ 47.491796] EXT4-fs (dm-0): barriers disabled
[ 47.649750] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts : usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,data=writebac k,oldalloc
[ 49.088023] usb-storage 6-1:1.0: USB Mass Storage device detected
[ 49.088186] scsi10 : usb-storage 6-1:1.0
[ 49.088238] usbcore: registered new interface driver usb-storage
[ 49.141068] usbcore: registered new interface driver usblp
[ 49.186288] usbcore: registered new interface driver usbhid
[ 49.186296] usbhid: USB HID core driver
[ 50.238821] ata2.00: configured for UDMA/133
[ 50.238825] ata2: EH complete
[ 50.246834] ata3.00: configured for UDMA/133
[ 50.246838] ata3: EH complete
[ 50.249258] ata4.00: configured for UDMA/133
[ 50.249262] ata4: EH complete
[ 50.250455] ata5.00: configured for UDMA/133
[ 50.250462] ata5: EH complete
[ 50.250604] ata6.00: configured for UDMA/133
[ 50.250608] ata6: EH complete
[ 50.253429] ata1.00: configured for UDMA/133
[ 50.253433] ata1: EH complete
[ 50.417905] ata8.00: configured for UDMA/133
[ 50.417993] ata8: EH complete
[ 50.418144] ata9.00: configured for UDMA/133
[ 50.418147] ata9: EH complete
[ 50.447933] scsi 10:0:0:0: Direct-Access hp v220w 3276 PQ: 0 ANSI: 4
[ 50.448023] sd 10:0:0:0: Embedded Enclosure Device
[ 50.449050] sd 10:0:0:0: Failed to get diagnostic page 0x8000002
[ 50.449053] sd 10:0:0:0: Failed to bind enclosure -19
[ 50.449097] sd 10:0:0:0: Attached scsi generic sg8 type 0
[ 50.449425] sd 10:0:0:0: [sdu] 63901440 512-byte logical blocks: (32.7 GB/30. 4 GiB)
[ 50.450173] sd 10:0:0:0: [sdu] Write Protect is off
[ 50.450176] sd 10:0:0:0: [sdu] Mode Sense: 43 00 00 00
[ 50.450921] sd 10:0:0:0: [sdu] No Caching mode page found
[ 50.450924] sd 10:0:0:0: [sdu] Assuming drive cache: write through
[ 50.454042] sd 10:0:0:0: [sdu] No Caching mode page found
[ 50.454045] sd 10:0:0:0: [sdu] Assuming drive cache: write through
[ 50.454908] sdu: sdu1
[ 50.457418] sd 10:0:0:0: [sdu] No Caching mode page found
[ 50.457421] sd 10:0:0:0: [sdu] Assuming drive cache: write through
[ 50.457423] sd 10:0:0:0: [sdu] Attached SCSI removable disk
[ 52.520146] ata8.00: configured for UDMA/133
[ 52.520239] ata8: EH complete
[ 52.654313] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 52.737110] loop: module loaded
[ 52.880827] ata9.00: configured for UDMA/133
[ 52.880832] ata9: EH complete
[ 52.889881] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery d irectory
[ 52.889894] NFSD: starting 90-second grace period (net ffffffff81855980)
[ 53.006139] ata1.00: configured for UDMA/133
[ 53.006149] ata1: EH complete
[ 53.050846] ata2.00: configured for UDMA/133
[ 53.050850] ata2: EH complete
[ 53.234290] ata3.00: configured for UDMA/133
[ 53.234294] ata3: EH complete
[ 53.495425] ata4.00: configured for UDMA/133
[ 53.495434] ata4: EH complete
[ 53.747240] ata5.00: configured for UDMA/133
[ 53.747244] ata5: EH complete
[ 53.855006] ata6.00: configured for UDMA/133
[ 53.855011] ata6: EH complete
[ 54.371070] FAT-fs (sdu1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
As you are only using 12 drives then I would leave the synoinfo.conf settings at default and look more into the drives vs slots (in the expansion unit) appearance. From your dsmsg output, I would compare the serial numbers of the drives that are visible to the slots in the unit and find which one/s are not showing up. Do this for sata connection and then with usb and see if its the same. Then try moving the drives around and seeing which one/s show up. Then try leaving a drive out of one of the slots that works and see if the 'missing' drive/slot appears.
Also try the expansion unit connected to one of the onboard satas and the syba and see if there is a difference.
The goal being to see if there is a limitation/compatibility issue with the expansion unit and XPE/DSM as if there is, no amount of hex magic will make the drives all show up. The expansion unit also seems to use two different controller chips (one for sata and another for usb), which could be why you are seeing different results depending on the connection method.
did you try my suggestion to test all the slots?
also, i tried out a 30 drive hex config on a spare bare metal box i have and it showed the usb boot disk as drive 21. at the moment i've not worked out why, but think its how the controllers/pci devices are enumerated by xpe/dsm. i think yours is a similar issue, but first step is making sure all your sata channels are seen properly imho
