I have installed XPEnology on an Gigabyte G33m-DS2R with an Intel Pro NIC and a LSI 9240-8i with 8 JBOD Drives.
The Smart Data in DSM is shown for the Intel ICHR (4x SATA) and the Marvell (2x SATA) Sata Controller of the Gigabyte Board. Everything's works fine.
The LSI 9240-8i works fine. Edited the Synoinfo, because of more than 12 drives. But in DSM the Smart Data isn't shown anything.
But with telnet the smartctrl can show me everything for any HDD.
FileStation> smartctl --all /dev/sdk
smartctl 6.2 (build date Jun 29 2015) [x86_64-linux-3.10.35] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Barracuda 7200.12
Device Model:     ST3500413AS
Serial Number:    Z2AGWLP7
LU WWN Device Id: 5 000c50 03f6055a9
Firmware Version: HP64
User Capacity:    500,107,862,016 bytes [500 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Dec  1 17:03:35 2015 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART STATUS RETURN: incomplete response, ATA output registers missing
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                       was completed without error.
                                       Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                       without error or no self-test has ever
                                       been run.
Total time to complete Offline
data collection:                (  600) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                       Auto Offline data collection on/off support.
                                       Suspend Offline collection upon new
                                       command.
                                       Offline surface scan supported.
                                       Self-test supported.
                                       No Conveyance Self-test supported.
                                       Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                       power-saving mode.
                                       Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                       General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (  85) minutes.
SCT capabilities:              (0x103b) SCT Status supported.
                                       SCT Error Recovery Control supported.
                                       SCT Feature Control supported.
                                       SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
 1 Raw_Read_Error_Rate     0x002f   119   099   006    Pre-fail  Always       -       230495588
 3 Spin_Up_Time            0x0023   100   100   000    Pre-fail  Always       -       0
 4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       349
 5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       16
 7 Seek_Error_Rate         0x002f   072   060   030    Pre-fail  Always       -       19601819
 9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1852
10 Spin_Retry_Count        0x0033   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       349
180 Unknown_HDD_Attribute   0x002b   100   100   000    Pre-fail  Always       -       4288827444
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0033   100   100   097    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   067   065   045    Old_age   Always       -       33 (Min/Max 25/35)
194 Temperature_Celsius     0x0022   033   040   000    Old_age   Always       -       33 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x003a   037   032   000    Old_age   Always       -       230495588
196 Reallocated_Event_Count 0x0032   100   100   036    Old_age   Always       -       16
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Interrupted (host reset)      90%         0         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
   1        0        0  Not_testing
   2        0        0  Not_testing
   3        0        0  Not_testing
   4        0        0  Not_testing
   5        0        0  Not_testing
Selective self-test flags (0x0):
 After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
FileStation>
Why doesn't it work within DSM, is there a Fix to see the smart data.
Best regards
DSM doesn't use smartctl. Synology uses their own proprietary tool called synodisk.
I have no issues with smart data w/ my LSI 9211 controller that is passed through in an esxi VM.
  • 3 weeks later...
I have a IBM 5016 (Same as LSI 9265) that i passtrough from ESXI with JBOD activated on the card.
It seems to work well, but the smart status and temp is not showing.
I found this link about how to activate JBOD, maybe it will work for you:
https://forums.servethehome.com/index.p ... ware.1827/
It seems like you can only get SMART status if you use a card compatilbe with IT mode, but then you will lose the cache on the card and just use it as a dumb passtrough device.
Has anyone come up with a solution for this yet?
Thanks. I tested many Firmwares with the LSI 9240 and the SMART Data doesnt work with XPEnology. I only see the data in Telnet/SSH.
I crossflashed it with the 9211 IT Firmware and now it is working!
  • 10 months later...
I have the same issue. I have flashed my Dell H200 to LSI9211-8i. I can see with sas2flsh that NVDATA Product ID is set to SAS8211-8i and that the firmware is set to 19. So I believe that the controller is on IT mode. My xpenology recognize the six drives. With smartctl I can see the SMART data, but synodisk doesn't recognize the SMART data.
In the controller name I have "SAS2008(??)". Could the "??" be the problem ?
Thanks.
Yes, the majority made it works, so I don't understand what I did wrong.
-> I followed the tutorial for flashing the H200 (https://techmattr.wordpress.com/2016/04 ... -and-h310/) and everything went well.
-> I set up the disk in passtrough in proxmox with
scsi0: /dev/disk/by-path/pci-0000:02:00.0-sas-0x4433221100000000-lun-0,size=2930266584K
I can see the disk, I can see its smart value with smartctl in the synology but not with synodisk...
I really don't get it.
  • 7 months later...
so, if you RAID controller have HBA function like "passthrough" SMART to system - xpeno will work fine
i have old DELL LSI RAID HBA Controler with correct SMART in xpeno.
another way for some controllers - update firmware for HBA mode
