hursic Posted November 26, 2015 #1 Posted November 26, 2015 Hello everyone, Due to Apple messing with Airplay in IOS9 I now have a broken sound system which used to let me use Spotify on my iPad to Airplay to a Pi running Kodi which plugged into Satellite speakers via a cable. There doesn't seem to be a fix for that coming soon, so I wondered if I could plug a USB sound card directly into my XPEnology and run the cables to the speakers. I have Airplay working to XPEnology so it just requires the audio output to a sound card. I have a Sabrent AU-MMSA USB Sound card. My question is...how on earth do I set about installing drivers and registering them with XPEnology etc ? I've read on other forums that it works with Linux so it should in theory be all good. Surely it's not "plug and play no drivers needed" as the packaging states ? Many thanks for any help Ian
anthonyuk Posted November 27, 2015 #2 Posted November 27, 2015 I use this 'bluetooth' amp - http://www.amazon.com/Nobsound-Bluetoot ... B00W9H9W42 It isn't mentioned on the specs but it has a USB DAC which is driverless on Synology and appears as USB speakers in Audio station etc. viewtopic.php?f=2&t=3151
hursic Posted November 28, 2015 Author #3 Posted November 28, 2015 You sir might just be a genius. Thanks for that, I've ordered one and will see how it works with my set up.... cheers Ian
