d95gas 0 · ID: 1 Posted November 26, 2015 Hi All, Just joined up after lurking for some time now. This afternoon has not been a good one, trying to get Synology DSM to insall/run on a HP Microserver. So started from scratch running through VirtualBox first. So I have managed to start off with "5.1.4044" and its all installed and running fine. I have then tried to upgrade to "5.2.5592". Followed the proess to creat the new boot key, which runs fine, it then brings up the Synology interface to upgrade and I select manual, and point it to the relevant PAT file for 5.2.5592". The process starts than after approx 20 sseconds reports that the file must be corrupt and terminates. Now its obvious that hte "Novice" is doing something wrong, but i have followed the instructions to the letter. Anyone advice where the heck I am going wrong? Thanks P.S Massive thanks to the guys who have spent the time developing this for us, totally awesome. Share this post Link to post Share on other sites
imaleecher 2 · ID: 2 Posted November 26, 2015 Have you tried selecting Upgrade during XPEnoboot boot selection and not via the Synology web console? Share this post Link to post Share on other sites
d95gas 0 · ID: 3 Posted November 27, 2015 Yep tried that and I still get the issue. Currently running 5.2.5592 on the HP, not attempted any updates on that yet. Within the PAT folder of 5592 there are 4 updates. Can I go straight to update No 4 or do I need to do each in turn ? Thanks Share this post Link to post Share on other sites
dutchmhk 0 · ID: 4 Posted November 28, 2015 No, you need to run the 5592.pat file first. You can tell them appart from the file size. The biggest file is the basic 5592 sw - run that first, and then - when it's all god, run the updates 1>4 regards dutch Share this post Link to post Share on other sites
