Hi all
I am trying to increase the maxdisks for my xpenology NAS.
Currently i have tried to telnet to my NAS, attempt to edit /etc.defaults/synoinfo.conf
The problem is when i VI synoinfo.conf, i don't any lines such as maxdisks
Can anyone enlighten me?
Thanks in advance!
Hi all
The value is in /etc/synoinfo.conf
For me it gets back to 12 after a reboot.
//M
Hi all
//M
Edit the file on /etc.default
HP Capacity thread I opened, I tried today to change the values and nothing.
maxdisks="20"
internalportcfg="0xffff
no luck
Edit: i change both etc and etc.defaults
maxdisks="20"
no luck
Try using winscp,change values in /etc/syno.info and /etc.default/syno.info
Always worked with my bare metal install.
I currently have 24 disks configured.
If you read the threads in detail you can see that you have to change 3 values as well as the max disks;
esataportcfg
usbportcfg
internalportcfg
The exact values will depend on your setup, these work for me for 16 disks
esataportcfg="0x0000"
usbportcfg="0x30000"
internalportcfg="0xffff"
my advice would be to setup XPE/DSM with a single drive, then mess with these settings to see if Storage Manager gives the right values and it reboots ok, then add your drives.
OK I managed 24 4TB HDDs any more and they start replacing disk 1. that's on 4.3 version.
my setup:-
LSI HBA with external JBOD enclosure that takes up to 45 HDDs, so I installed 12 on the server itself and then another 12 on the enclosure.
I disabled all internal ports including eSATA but left the USB.
I used the following method from stanza's post viewtopic.php?f=2&t=2028
when I got the 24 online I lost all USBs.
  • 3 months later...
