30624700 Posted November 19, 2015 #1 Posted November 19, 2015 DO NOTupgrade the bootloader to 5.2.5644.1 if you required these services in the working environment. 1. ISCSI - Its not working with bootloader 5.2.5644.1, the lun will disappear after created. 2. Phpvirtualbox will not start: Once you perform online update to DSM5.2.5644 update 1, an error message The virtual machine 'XXX' has terminated unexpectedly during startup because of signal 11. The temporary solution is revert the bootloader to 5.2.5592 (its not necessary to downgrade the DSM version)
