SupakoolDude 0 Posted July 14, 2021 Share Posted July 14, 2021 Hi all, I have a system that’s not using the default port (5000,5001). I have successfully setup acme.sh and got the cert. My problem is with using the deploy hook to add it to the system. When I use the following; acme.sh/data --deploy -d example.com --deploy-hook synology_dsm it seems it’s trying to contact “localhost:5000” for the connection. How do I specify the port? Any help would be appreciated. Quote Link to post Share on other sites
SupakoolDude 0 Posted July 14, 2021 Author Share Posted July 14, 2021 Went digging on the GitHub and saw you can use this: export SYNO_Port="5000" Quote Link to post Share on other sites
