DirtyCajunRice Posted November 9, 2015 Share #1 Posted November 9, 2015 Ok, I have done about 1000 tests before coming on here trying to fix it myself and i am unable. It is blowing my mind. Issue: After a constantly changing amount of time, i can only read/write the HDD at about 500kbps to 800kbps via CIFS/SAMBA/FTP. The issue also is simply internal as plex cannot read the information on the disks fast enough once it goes into this state. Non-resolutions: I initially thought it was a conflicting package issue, so i fresh installed the DSM and installed no additional packages. same issues. I then thought it was a disk spindown issue, so i turned off disk spindown. same issues. I have a laptop running DSM just fine. no issues. I am starting to believe it is a hardware issue. but i cannot surmise which hardware is having the issue! Is it my NIC card? Is it my HDDs? Is it a setting on the BIOS putting something to sleep i cannot find??? HELP! Link to comment Share on other sites More sharing options...
DirtyCajunRice Posted November 10, 2015 Author Share #2 Posted November 10, 2015 So for anyone this helps, I finally deduced it to a hardware issue. I ran debug from boot and moved some folders around until it gave me an IRQ 17. Which was talking about my NIC. It disabled my nic and ruined everything after some event. I added irqpoll to the kernel line and it fixed the issue. atleast for now. ill update if something changes Link to comment Share on other sites More sharing options...
