DSM_DS3615xs_5565 Upgrade Error 21 and Missing Volume Info
RacerX
Hello
During the summer I tested my HP N54L with DSM_DS3615xs_5565 and it was fine. So I purchased a second HP N54L do some more testing to see it if would work for me, I started reading this forum and found a lot of good info. The first time I installed it, I remember it recommended not to run the update and so I left it stock DSM 5565. So lately I have noticed that the control panel is prompting for updates. The first time I tried to upgrade to DSM 5592 through the menu it would start fine and then stop at 65% with a Error 21 and then roll back to the main screen. Most of the stuff on the web about this error is old and does not really apply.
Next,go here for the updates
http://xpenology.me/downloads/
The best way I found to manage the updates is to download each one in a different folder.
for example
DSM 5565
Update 1
Update 2
DSM 5592
Update 1
Update 2
Update 3
Then upload each update one at a time. It takes a while to do each one, but it was straght forward to do DSM 5565 Update 1, and Update 2. However, when I tried DSM 5592 I received error 21. The way now understand is that each DSM revision requires a custom bootstrap on the usb drive. So I took the usb drive out of my N54L and reimaged it with XPEnoboot 5.2-5592.1 DS3615xs on a different machine using Win32DiskImager.
When I put the usb drive back in my N54L I selected upgrade from the grub boot menu and it showed all the packages getting updated. When I logged in and checked the updates it still showed DSM 5565 so I uploaded DSM 5592 and this time it worked :grin:
When I ran the updates for DSM 5592 I noticed that it did not require a reboot. That was fine but when I did Update 3. I checked Storage Manager and the Volume information was missing. So I shutdown the N54L and then started it back up and this time the Volume Information was present. :grin:
So now there is a new Version 5.2-5644 released. If your not running a VM I would recommend waiting for the developers release of the cutom XPEnoboot for 5.2-5644...
Update
I noticed that XPEnoboot_DS3615xs_5.2-5644.1 is now available at
http://
http://download.xpenology.fr/
I downloaded the img file and then took the usb drive out of my N54L and reimaged it with XPEnoboot_DS3615xs_5.2-5644.1 on a different machine using Win32DiskImager. When I put the usb drive back in my N54L I selected the first option from the grub boot menu and it showed all the packages getting updated. When I logged in and checked the updates it still showed DSM 5592 so I downloaded and then installed it through the update screen and it worked.
I'm now on the DSM 5.2-5644.1 :grin:
Edited by Guest
  • 1 month later...
Update
I noticed that XPEnoboot_DS3615xs_5.2-5644.4 img is now available at
http://
I downloaded the img file and then took the usb drive out of my N54L and reimaged it with XPEnoboot_DS3615xs_5.2-5644.4 on a different machine using Win32DiskImager. When I put the usb drive back in my N54L I selected the first option from the grub boot menu and it showed all the packages getting updated. When I logged seems just like normal. :grin:
I'm now on the DSM 5.2-5644.4
