NAS is not visible after first installation
DK01
I tried the get an older PC to work with XPEnology.
It's a gigabyte mainboard with a realtek network adapter and an A10-6800K AMD CPU as the base.
Installed are at the moment 2 1TB HDD.
I followed the guide from polanski
https://xpenology.com/forum/topic/7973-tutorial-installmigrate-dsm-52-to-61x-juns-loader/
I have the synoboot_3615 for the ds3615_6.2 and DSM_DS3615xs_25556.pat as software for the NAS.
I followed all steps from the guide before, I changed the VIP and PID, the Serial number and the MAC adress in the grub file.
I managed to get the file to the USB stick, started the NAS and I found it at this point.
I was asked to install the .pat file and then the machine restarts. And at this point, I am not able to find the NAS again. with the synology assistant.
Restarts don't change anything, other USB ports, other LAN cables etc. are not helping.
So at this point, I need your help, does anyone here have a idea, how to get it to work again?
1 hour ago, IG-88 said:
that's 6.2.4 and not working - there are some big warning signs, you should read them
use 6.2.3 up to update3
Thanks for the reply.
May you provide some links please?
I just found this bootloader. The pat file found was older, but I was asked to use a newer because of the bootloader.
It would be great, if someone could share the correct ones.
Sry for my mistake. 😕
