[Tuto] Comment installer VirtualBox sur votre xpenology
misterT
je repond à ma question
This website has an initial account of admin/admin use this to login and alter the password as soon as you are logged in. You also might want to secure this more if you are publishing a website from your DiskStation to the internet
J'ai testé :eek:
Ca a l'air pas trop mal.
Sauf que pour une raison inconnue, lors de l'installe de W7, la machine virtuelle se met en pause et impossible de la relancer ... :sad:
Edit : résolu.
Par défaut, les images s'installent dans la partition système - donc la clef usb de boot ...
l'install du package se passe bien.
par contre ça se gâte au lancement de la machine virtuelle (avec l'iso d'installation 7 AIO dans le DVD virtuel)
3 secondes apres le lacement, j'obtiens :
Failed to load VMMR0.r0
(VERR_SUPLIB_SYMLINKS_ARE_NOT_PERMITTED)
avec ça dans "detail"
Exception Object
   [message:protected] => Failed to load VMMR0.r0 (VERR_SUPLIB_SYMLINKS_ARE_NOT_PERMITTED)
   [string:Exception:private] =>
   [code:protected] => 0
   [file:protected] => /volume1/web/phpvirtualbox/lib/vboxconnector.php
   [line:protected] => 2405
   [trace:Exception:private] => Array
           [0] => Array
                   [file] => /volume1/web/phpvirtualbox/lib/vboxconnector.php
                   [line] => 938
                   [function] => remote_progressGet
                   [class] => vboxconnector
                   [type] => ->
                   [args] => Array
                           [0] => Array
                                   [progress] => db128b882460fb0a-00000000000005e6
                                   [_persist] => Array
                                           [vboxHandle] => db128b882460fb0a-00000000000005e4
                                   [fn] => progressGet
           [1] => Array
                   [file] => /volume1/web/phpvirtualbox/lib/ajax.php
                   [line] => 304
                   [function] => __call
                   [type] => ->
                   [args] => Array
                           [0] => progressGet
                           [1] => Array
                                   [0] => Array
                                           [_persist] => Array
                                           [fn] => progressGet
                                   [1] => Array
                                           [0] => Array
                                                   [data] => Array
                                                           [responseData] => Array
        [info] => Array
        [completed] => 1
        [canceled] =>
        [description] => Starting VM
        [operationDescription] => Starting virtual machine
        [timeRemaining] => Array
        [timeElapsed] => Array
        [days] => 16687
        [hours] => 14
        [minutes] => 31
        [seconds] => 11
        [percent] => 20
                                                           [success] => 1
                                                           [key] => 720f4c5f2f9c111d81c1aa4a7f53b5bc
                                                   [errors] => Array
                                                   [persist] => Array
                                                   [messages] => Array
           [2] => Array
                   [line] => 304
                   [function] => progressGet
                   [type] => ->
                   [args] => Array
                           [0] => Array
                                   [_persist] => Array
                                   [fn] => progressGet
                           [1] => Array
                                   [0] => Array
                                           [data] => Array
                                                           [info] => Array
        [completed] => 1
        [canceled] =>
        [days] => 16687
        [hours] => 14
        [minutes] => 31
        [seconds] => 11
        [percent] => 20
                                                   [success] => 1
                                           [errors] => Array
                                           [persist] => Array
                                           [messages] => Array
   [previous:Exception:private] =>
ça me cause pas des masses...
