scoobdriver Posted February 11, 2021 Share #126 Posted February 11, 2021 @youhq Running DS3615Xs DSM 6.2.3-25426 Update 3 with loader 1.03b works for me with the 4sag spk packaged hilo.ko , but not @v02max standard or 3617 hpilo.ko, or the one @IG-88 provided , (maybe something changed since these where compiled) I am also able to replace amshelper with the more recent 2.10.1 release (red hat 7) . I'm not able to see software though . does anybody know what the options are after calling Amshelper ? specifically -M1,5,14,16,18,23,99 (I think 99 must relate to the software monitoring) Thanks Quote Link to comment Share on other sites More sharing options...
IG-88 Posted February 11, 2021 Share #127 Posted February 11, 2021 (edited) 1 hour ago, scoobdriver said: Running DS3615Xs DSM 6.2.3-25426 Update 3 with loader 1.03b works for me with the 4sag spk packaged hilo.ko , but not @v02max standard or 3617 hpilo.ko, or the one @IG-88 provided , (maybe something changed since these where compiled) as a general rule, dont use driver (*.ko) from 6.2.1 and 6.2.2 for 6.2.3 for 6.2.3 you should try stuff that worked with 6.2.(0) and the original loader back in 2018 Edited February 11, 2021 by IG-88 2 Quote Link to comment Share on other sites More sharing options...
haldi Posted April 5, 2022 Share #128 Posted April 5, 2022 Anyone on DSM7 has got this working? Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 17, 2022 Share #129 Posted April 17, 2022 On 4/5/2022 at 7:44 PM, haldi said: Anyone on DSM7 has got this working? in theory it might work hpilo.ko as driver is part or kernel 4.4 and is no problem to build (beside 3615 all units we have for 7.x use that) packages like the "hp_ams-5.2_2.5.0-1.spk" will not work as 7.x prevents things like using root user to run a package but its possible to mimic the installation of the spk (can be extracted and there are scripts for installing and running) and then match it the way it has to be to run in 7.x i native 7.x might be better but as long as there is none it might be possible to make it work by installing the files manually Quote Link to comment Share on other sites More sharing options...
haldi Posted April 17, 2022 Share #130 Posted April 17, 2022 8 minutes ago, IG-88 said: hpilo.ko as driver is part or kernel 4.4 and is no problem to build (beside 3615 all units we have for 7.x use that) Oh. Yeah. For some reason all people with a HP Microserver Gen8 baremetal ran the 3615 so i did that too.^^ might take a look at a manual installation if i have too much time. If it works i'll report back here. Thanks. Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 17, 2022 Share #131 Posted April 17, 2022 (edited) 1 hour ago, haldi said: Oh. Yeah. For some reason all people with a HP Microserver Gen8 baremetal ran the 3615 so i did that too.^^ in 7.0 there is a new kernel version, so no kernel modules 6.2.x will work there, if you want a system with security fixes you best chance is rp loader for 6.2.4 that way you can still use the old spk and even the old 6.2.3 driver Quote might take a look at a manual installation if i have too much time. If it works i'll report back here. Thanks. if you go 7.x then you would at least need the hpilo.ko driver for the platform in question (i use 918+ aka apollolake myself so i could provide a driver for that without much effort) edit: as the driver is for 7.0 918+ and might work an 3617/3622 too (same kernel version) but its no use for 3615 (and as hpe microserver gen8 is only 3rd gen intel, it cant run 918+) hpilo.ko Edited April 17, 2022 by IG-88 Quote Link to comment Share on other sites More sharing options...
shenwrt Posted May 5, 2022 Share #132 Posted May 5, 2022 On 4/17/2022 at 6:10 PM, IG-88 said: in 7.0 there is a new kernel version, so no kernel modules 6.2.x will work there, if you want a system with security fixes you best chance is rp loader for 6.2.4 that way you can still use the old spk and even the old 6.2.3 driver if you go 7.x then you would at least need the hpilo.ko driver for the platform in question (i use 918+ aka apollolake myself so i could provide a driver for that without much effort) edit: as the driver is for 7.0 918+ and might work an 3617/3622 too (same kernel version) but its no use for 3615 (and as hpe microserver gen8 is only 3rd gen intel, it cant run 918+) hpilo.ko 367.28 kB · 4 downloads Hello, may I ask how you compiled, I compiled error, prompting as shown in the picture. Can you help me.Thank you My machine is: Gen8 DS3615xs 7.0.1 Quote Link to comment Share on other sites More sharing options...
IG-88 Posted May 5, 2022 Share #133 Posted May 5, 2022 17 hours ago, shenwrt said: Hello, may I ask how you compiled i still use the things i wrote about here but you need to look for some info about added thinhs for 6.2 and when using 7.0 you also need the stuff from here (https://archive.synology.com/download/ToolChain) https://xpenology.com/forum/topic/7187-how-to-build-and-inject-missing-drivers-in-jun-loader-102a/ but maybe use this one (does not need to be win10) https://xpenology.com/forum/topic/7341-tutorial-compile-xpenology-drivers-in-windows-10/ there are also "DSM_Developer_Guide_6_0.pdf" and "DSM_Developer_Guide_7_0_Beta.pdf" from synology on how to set up a build enviroment Quote Link to comment Share on other sites More sharing options...
shenwrt Posted May 27, 2022 Share #134 Posted May 27, 2022 On 5/6/2022 at 3:04 AM, IG-88 said: i still use the things i wrote about here but you need to look for some info about added thinhs for 6.2 and when using 7.0 you also need the stuff from here (https://archive.synology.com/download/ToolChain) https://xpenology.com/forum/topic/7187-how-to-build-and-inject-missing-drivers-in-jun-loader-102a/ but maybe use this one (does not need to be win10) https://xpenology.com/forum/topic/7341-tutorial-compile-xpenology-drivers-in-windows-10/ there are also "DSM_Developer_Guide_6_0.pdf" and "DSM_Developer_Guide_7_0_Beta.pdf" from synology on how to set up a build enviroment OK,Thank you very much. It is already working properly. Although its fan speed has not been reduced... It works at 44%🤣🤣🤣 This is the version of gen8 dsm7.0.1 ds3615xs. give to those who need it. hp-ams.zip 1 Quote Link to comment Share on other sites More sharing options...
DHChoi Posted August 16, 2022 Share #135 Posted August 16, 2022 On 4/17/2022 at 7:10 PM, IG-88 said: in 7.0 there is a new kernel version, so no kernel modules 6.2.x will work there, if you want a system with security fixes you best chance is rp loader for 6.2.4 that way you can still use the old spk and even the old 6.2.3 driver if you go 7.x then you would at least need the hpilo.ko driver for the platform in question (i use 918+ aka apollolake myself so i could provide a driver for that without much effort) edit: as the driver is for 7.0 918+ and might work an 3617/3622 too (same kernel version) but its no use for 3615 (and as hpe microserver gen8 is only 3rd gen intel, it cant run 918+) hpilo.ko 367.28 kB · 4 downloads Can I use this AMS driver to HPE Microserver Gen10 Plus with iLO 5? My DSM version is DSM 7.1-42661 Update 4 for DS3617xs. Quote Link to comment Share on other sites More sharing options...
yonesmit Posted October 8, 2022 Share #136 Posted October 8, 2022 (edited) Hi! I'm running DSM 7.1.1-42962 Update 1 for DS3622xs+ in a HP Proliant Microserver Gen8 (Xeon E3 1260L and 16GB RAM). I'm trying to setup hpilo module without success. I tested the latest ko modules but are not acceted by the kernel (my kernel is 4.4.180+) even I downloaded linux-4.4.x.txz (it's 4.4.180) and renamed makefile to identify it as 4.4.180+ and the ompiled hpilo.ko. The module loads ok but it crashed when I call amsHelper. Anyone running hpilo.ko with 4.4.180+ kernel? is kernel 4.4.180+ source code available to complie the module? any other idea? Thanks in advance Best Regards. Edited October 8, 2022 by yonesmit 1 Quote Link to comment Share on other sites More sharing options...
ADMiNZ Posted October 28, 2022 Share #137 Posted October 28, 2022 Hello. No one has yet made a .spk for DSM7 ? Quote Link to comment Share on other sites More sharing options...
WiteWulf Posted October 28, 2022 Share #138 Posted October 28, 2022 AFAIK you cannot run hp-ams on DSM7 as it requires root privs and DSM7 does not allow software installed via .spk to run as root. If you really want it to manage/monitor your hardware you could install ESXi on your Gen8 and run xpenology as a guest. There are loads of threads and guides on how to do this on the forums. jooi, what is it you want from hp-ams? There may be another way to achieve it... Quote Link to comment Share on other sites More sharing options...
haldi Posted October 28, 2022 Share #139 Posted October 28, 2022 Mainly to get rid of the annoying message in the "storage" tab.... So manually installing all files and running them via Task planner at Startup with root rights should work right? Quote Link to comment Share on other sites More sharing options...
WiteWulf Posted October 28, 2022 Share #140 Posted October 28, 2022 Give it a go and let us know how you get on, just don't expect it to survive a DSM update Quote Link to comment Share on other sites More sharing options...
pocopico Posted October 28, 2022 Share #141 Posted October 28, 2022 @yonesmit Hi, from old notes, you will need a linux system and a process like the below : Kernel sources : https://archive.synology.com/download/ToolChain/Synology NAS GPL Source/7.0-41890 You can download the source and the toolkit for your platform https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.broadwell-7.0.dev.txz/download I would extract the toolkit into $KHOME and the kernel source inside $KHOME You have to : cp linux-4.4.x/synoconfigs/broadwell to linux-4.4.x/.config cd linux-4.4.x echo + > .scmversion make oldconfig make modules_prepare In my example the toolkit is extracted inside /opt/dsm-kernel/broadwelll/ And then use a script like : KERNEL_SOURCE="/opt/dsm-kernel/broadwell/linux-4.4.x" KHOME="/opt/dsm-kernel/broadwell" function dsmmake(){ make \ CROSS_COMPILE="$KHOME/usr/local/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/usr/bin/x86_64-pc-linux-gnu-" \ CFLAGS="-I$KHOME/usr/local/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/usr/include/" \ LDFLAGS="-I$KHOME/usr/local/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/lib/" \ RANLIB="/usr/bin/x86_64-linux-gnu-ranlib" \ LD="/usr/bin/x86_64-linux-gnu-ld" \ CC="/usr/bin/x86_64-linux-gnu-gcc" \ LD_LIBRARY_PATH="$KHOME/usr/local/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/usr/lib" \ -C "$KHOME/usr/local/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/usr/lib/modules/DSM-7.0/build/" \ ARCH=x86_64 M=`pwd` modules $@ } cd $YOURSOURCES dsmmake Quote Link to comment Share on other sites More sharing options...
tbc0309 Posted December 23, 2022 Share #142 Posted December 23, 2022 (edited) thanks @4sag @shenwrt @IG-88 @v02max I have packed the spk file, but there is no machine test. Please feed back if you have any problems. for DSM6.2.3 6.2.4 918:apollolake broadwell 3615:bromolow Edited January 3 by Polanskiman spk files deleted at the request of the user Quote Link to comment Share on other sites More sharing options...
tbc0309 Posted December 23, 2022 Share #143 Posted December 23, 2022 (edited) SHH connection repair is required after DSM7 installation sudo sed -i 's/package/root/g' /var/packages/hp-ams/conf/privilege I have packed the spk file, but there is no machine test. Please feed back if you have any problems. for DSM7.x 918:broadwell apollolake dockerx64 kvmx64 denverton broadwellnk geminilake r1000 v1000 3615:bromolow Edited January 3 by Polanskiman spk files deleted at the request of the user 1 Quote Link to comment Share on other sites More sharing options...
lwdamazing Posted December 23, 2022 Share #144 Posted December 23, 2022 (edited) Cloud you please make a spk package of DVA3221 DSM7? I try to use hp_ams-2.9.1-DSM7-918.spk on DVA3221 and it doesn’t work. I have tried to run the command after installation and it shows No such file or directory. Because DVA3221 adds eight cameras, I have to use this image. I'm using it on a DL20 GEN9, thanks a lot. Edited December 23, 2022 by lwdamazing Quote Link to comment Share on other sites More sharing options...
lwdamazing Posted December 24, 2022 Share #145 Posted December 24, 2022 22 hours ago, tbc0309 said: SHH connection repair is required after DSM7 installation sudo sed -i 's/package/root/g' /var/packages/hp-ams/conf/privilege I have packed the spk file, but there is no machine test. Please feed back if you have any problems. for DSM7.x 918:broadwell apollolake dockerx64 kvmx64 denverton broadwellnk geminilake r1000 v1000 3615:bromolow hp_ams-2.9.1-DSM7-918.spk 3.52 MB · 1 download hp_ams-2.9.1-DSM7-3615.spk 3.51 MB · 1 download Cloud you please make a spk package of DVA3221 DSM7? I try to use hp_ams-2.9.1-DSM7-918.spk on DVA3221 and it doesn’t work. I have tried to run the command after installation and it shows No such file or directory. Because DVA3221 adds eight cameras, I have to use this image. I'm using it on a DL20 GEN9, thanks a lot. Quote Link to comment Share on other sites More sharing options...
tbc0309 Posted December 24, 2022 Share #146 Posted December 24, 2022 14 minutes ago, lwdamazing said: Cloud you please make a spk package of DVA3221 DSM7? I try to use hp_ams-2.9.1-DSM7-918.spk on DVA3221 and it doesn’t work. I have tried to run the command after installation and it shows No such file or directory. Because DVA3221 adds eight cameras, I have to use this image. I'm using it on a DL20 GEN9, thanks a lot. /sbin/insmod /var/packages/hp-ams/target/hpilo.ko ./var/packages/hp-ams/target/sbin/amsHelper -f -I0 -M1,5,14,16,18,23,99 SSH connects to NAS and run the above command. What's the feedback Quote Link to comment Share on other sites More sharing options...
lwdamazing Posted December 26, 2022 Share #147 Posted December 26, 2022 On 12/24/2022 at 11:25 AM, tbc0309 said: /sbin/insmod /var/packages/hp-ams/target/hpilo.ko ./var/packages/hp-ams/target/sbin/amsHelper -f -I0 -M1,5,14,16,18,23,99 SSH connects to NAS and run the above command. What's the feedback hi I try to enter the command but he seems to have an error. Merry Christmas! Quote Link to comment Share on other sites More sharing options...
Madboy128 Posted December 27, 2022 Share #148 Posted December 27, 2022 Hello, this is my first post here. Can anyone make HP-ASM spk for Gen8 DSM7 - 3622+? Quote Link to comment Share on other sites More sharing options...
AuxXxilium Posted December 28, 2022 Share #149 Posted December 28, 2022 On 12/23/2022 at 6:00 AM, tbc0309 said: SHH connection repair is required after DSM7 installation sudo sed -i 's/package/root/g' /var/packages/hp-ams/conf/privilege I have packed the spk file, but there is no machine test. Please feed back if you have any problems. for DSM7.x 918:broadwell apollolake dockerx64 kvmx64 denverton broadwellnk geminilake r1000 v1000 3615:bromolow hp_ams-2.9.1-DSM7-918.spk 3.52 MB · 2 downloads hp_ams-2.9.1-DSM7-3615.spk 3.51 MB · 2 downloads 19 hours ago, Madboy128 said: Hello, this is my first post here. Can anyone make HP-ASM spk for Gen8 DSM7 - 3622+? Please look at the post above. "918:broadwell apollolake dockerx64 kvmx64 denverton broadwellnk geminilake r1000 v1000" broadwellnk is 3622 Quote Link to comment Share on other sites More sharing options...
Madboy128 Posted December 28, 2022 Share #150 Posted December 28, 2022 (edited) After install HP-AMS /918 package/ - start putty and type sudo sed -i 's/package/root/g' /var/packages/hp-ams/conf/privilege after this command click on repair on hp-ams in package center tell me "failed to run the package service", DSM send me again messege "repair hp-ams" ? some kind of solution? Edited December 28, 2022 by Madboy128 Quote Link to comment Share on other sites More sharing options...
