Onknight 2 Posted March 28 Share Posted March 28 I did major upgrade and changed loaders. And motherboard is an NVIDIA chipset don't like like they are supported my SATA card is working but losing 4 Good SATA Onboard ports sucks could use some help here @IG-88 or anyone who has solution for me would be appreciated Thank you again for this great community in advance Quote Link to post Share on other sites
IG-88 755 Posted March 28 Share Posted March 28 On 3/26/2021 at 5:57 PM, Onknight said: on 6.2.3-25426 was running 6.1 with no Issues with DS3615xs 6.1 Jun's Mod it not seeing Asus Motherboard m3n78-vm SATA Ports ... it dose is my SATA Card and all 3 3TB Drives I like to be able to get onboard SATA Working again That gives me 4 more Drives other wise I have 1 drive left the chipset might be mcp78 and thats supported in linux ahci driver that is part of dsm any log like /var/log/dmesg ? check the bios, maybe rest it to defaults and look for sata to be in ahci mode i dont see much difference in ahci and kernel between 6.1 and 6.2, should work the same in both Quote Link to post Share on other sites
Onknight 2 Posted March 28 Author Share Posted March 28 1 hour ago, IG-88 said: the chipset might be mcp78 and thats supported in linux ahci driver that is part of dsm any log like /var/log/dmesg ? check the bios, maybe rest it to defaults and look for sata to be in ahci mode i dont see much difference in ahci and kernel between 6.1 and 6.2, should work the same in both I looked into Setting it old core 2 Dual Motherboard m3n78-vm and looks like dose not have ACHI mode http://static.highspeedbackbone.net/pdf/(e3849)_m3n78-vm.pdf Manual for the board @IG-88 Quote Link to post Share on other sites
Onknight 2 Posted March 28 Author Share Posted March 28 (edited) Motherboard is this PB5-VM SE dose not have ACHI mode bit they may be a solution I've included the link https://www.bios-mods.com/forum/Thread-Asus-P5B-VM-SE Edited March 28 by Onknight Quote Link to post Share on other sites
Onknight 2 Posted March 28 Author Share Posted March 28 @ig88 Unfortunally desktop Intel chipsets ICH9 and less are not supporting AHCI mode.Only ICH10 and some ICH9 supports it (P35 chipset). I not found the switching option for AHCI, so this mb doesn't support AHCI. so I am out luck unless you guys have any ideas Quote Link to post Share on other sites
IG-88 755 Posted March 29 Share Posted March 29 10 hours ago, Onknight said: Unfortunally desktop Intel chipsets ICH9 and less are not supporting AHCI mode.Only ICH10 and some ICH9 supports it (P35 chipset). where did you picked that up? ich6 upward can do ahci according to my sources https://ata.wiki.kernel.org/index.php/SATA_hardware_features 11 hours ago, Onknight said: I looked into Setting it old core 2 Dual Motherboard m3n78-vm and looks like dose not have ACHI mode http://static.highspeedbackbone.net/pdf/(e3849)_m3n78-vm.pdf Manual for the board maybe you should really read it? page 2-18 you could even search (text) for ahci in the pdf and find about 10 references to ahci i'm not going to check any further, if you don't bother to do even search in a manual you referencing ... good luck with your further efforts Quote Link to post Share on other sites
Onknight 2 Posted March 29 Author Share Posted March 29 (edited) @ig88 Yes but I goofed the original motherboard model I give you is not the motherboard I actually have When I went into the bios for my board I saw the correct model number I then did a Google search and found the manual it does not the ability ahci it was not included in the Bios I even Flash the BIOS to the newest version I search the Manual Yes some board in PB5-VM Series to have AHCI but SE Model is not one ... This is PB5-VM SE motherboard unfortunately Manual.pdf Edited March 29 by Onknight Quote Link to post Share on other sites
