terminal hp t5720 problem problem with installing xpenology
I have a problem I tried to install it xpenology terminal HP t5720 first DSM 5.2-5592 DS3615xs xpenoboot but I had error message : The kernel requires an x86-64 CPU, but only detected an i686 CPU
Then I tried to install the DSM 5.0-4528 DS214Play nanaoboot and now I have during installation only inscription in the upper left corner of a black screen nanoboot and what I have to do to get it working ??
ps sorry for my English but I am of Polish
it looks like the thin client is freezing when nanoboot tries to load
Does the thin client work with its own o/s?
You could also check that your nanoboot USB boots in another device ok
Try;
disable all of the unnecessary peripherals in the bios
remove the ATA flash drive
install your SATA/PCI adapter and connect one drive
dont forget to try some various 32bit linux o/s's to see if the unit will boot linux at all
