djtale Posted March 5, 2021 Share #1 Posted March 5, 2021 (edited) Hello, I tried to upgrade my N54L from 6.1 to DSM 6.2. So I created a new USB key with Jun's loader 1.0.3 Once installed I wasn't satisifed. The system wasn't very stable. My packages were not starting automatically. So I tried to fresh reinstall my DSM. I have 4 hard drive. HDD 1 is my volume1 for the system and packages. HDD2/3/4 are my volume2 for personal data. I ran that command in SSH : sudo /usr/syno/sbin/synodsdefault --reinstall and restarted the server. The Synology Assistant indicates this version when it finds the server : 6.2-23739 I am now on my Synology Web Assistant page asking me to Migrate. I have 2 choices : - Migrate - Reinstallation What ever option I select, I get an error. If I select Reinstallation and select the pat file for 6.2, 6.2.2 or 6.2.3, iI get this error : Failed to install the file. The file is probably corrupted. (13) I'm stuck now. I have order another HDD in case I need to use a spare disk to reinstall. I would like to know if I can for example just format my HDD1 and if I will keep my HDD2/3/4 safe. Thanks Edited March 5, 2021 by djtale Quote Link to comment Share on other sites More sharing options...
djtale Posted March 6, 2021 Author Share #2 Posted March 6, 2021 Apparently my VID and PID files were incorrect. I forgot to add 0x in front of my values. Quote Link to comment Share on other sites More sharing options...
