ldr78 Posted August 9, 2015 Share #1 Posted August 9, 2015 Hello Thanks for this forum, I've successfully assembled my xpenology and everything is working fine except one thing. I've got an issue at bootup. The external USB drive is not mounted. The usb key with xpenology is auto mounted as usbshare1. I I unplug and plug the hard drive it is mounted as usbshare2-2 But I would like to get my usb hard drive mounted at startup Do you know how I can do it ? My system is running Xpenoboot 5.2 5592 and xpenology DSM 5.2-5592 Update 2 Thanks a lot for your help Laurent Link to comment Share on other sites More sharing options...
ldr78 Posted August 11, 2015 Author Share #2 Posted August 11, 2015 Hello, I've just investigated a little bit more and found the following pieces of information : When I boot with the Hard drive plugged it doesn't appear in DSM and the dmesg logs these lines : [ 6.318725] usb 1-1: new high-speed USB device number 2 using xhci_hcd [ 6.331430] Got empty serial number. Generate serial number from product. [ 6.332182] hub 1-1:1.0: USB hub found [ 6.332337] hub 1-1:1.0: 4 ports detected [ 8.406734] usb 1-2: new high-speed USB device number 3 using xhci_hcd [ 8.418962] Got empty serial number. Generate serial number from product. [ 8.419837] hub 1-2:1.0: USB hub found [ 8.420087] hub 1-2:1.0: 3 ports detected [ 10.598807] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd [ 10.611285] Got empty serial number. Generate serial number from product. [ 10.611294] drivers/usb/core/hub.c (2486) Same device found. Change serial to ffffffccfffffffbffffffcbfffffff0 [ 10.612640] hub 2-1:1.0: USB hub found [ 10.612766] hub 2-1:1.0: 4 ports detected [ 11.714806] usb 1-1.2: new high-speed USB device number 4 using xhci_hcd [ 12.840820] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd [ 12.852820] Got empty serial number. Generate serial number from product. [ 12.852839] drivers/usb/core/hub.c (2486) Same device found. Change serial to ffffffd6ffffffa3ffffffebffffffc0 [ 12.853144] usb 1-1.3: ep 0x81 - rounding interval to 1024 microframes, ep desc says 2040 microframes [ 12.854143] hub 1-1.3:1.0: USB hub found [ 12.854293] hub 1-1.3:1.0: 3 ports detected [ 15.096450] usb 2-1.4: Device not responding to set address. [ 15.300198] usb 2-1.4: Device not responding to set address. [ 15.500712] usb 2-1.4: device not accepting address 3, error -71 [ 18.243779] usb 1-1.3.1: new full-speed USB device number 7 using xhci_hcd [ 18.255894] Got empty serial number. Generate serial number from product. [ 18.255908] drivers/usb/core/hub.c (2486) Same device found. Change serial to ffffffd6ffffffa3ffffffebffffffc0 [ 18.255912] drivers/usb/core/hub.c (2486) Same device found. Change serial to ffffffd6ffffffa3ffffffebffffffc1 [ 18.256273] usb 1-1.3.1: ep 0x81 - rounding interval to 128 microframes, ep desc says 192 microframes [ 18.256288] usb 1-1.3.1: ep 0x82 - rounding interval to 256 microframes, ep desc says 384 microframes [ 19.341782] usb 1-1.3.3: new low-speed USB device number 8 using xhci_hcd [ 19.357290] Got empty serial number. Generate serial number from product. [ 19.357654] usb 1-1.3.3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes [ 19.583804] EXT4-fs (md0): synoacl module has not been loaded. Unable to mount with synoacl, vfs_mod status=-1 [ 19.592985] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1 [ 20.427852] EXT4-fs (md0): re-mounted. Opts: (null) But when I unplug the drive and replug it with DSM running it appears in DSM and I see only these lines in dmesg [ 164.481725] usb 2-1.4: new SuperSpeed USB device number 5 using xhci_hcd [ 164.501502] usb-storage 2-1.4:1.0: USB Mass Storage device detected [ 164.501613] scsi5 : usb-storage 2-1.4:1.0 [ 168.859570] scsi 5:0:0:0: Direct-Access ST1000LM 024 HN-M101M 2AR1 PQ: 0 ANSI: 2 [ 168.859797] sd 5:0:0:0: Attached scsi generic sg5 type 0 [ 168.863490] sd 5:0:0:0: [sdu] 1953525165 512-byte logical blocks: (1.00 TB/931 GiB) [ 168.863978] sd 5:0:0:0: [sdu] Write Protect is off [ 168.863983] sd 5:0:0:0: [sdu] Mode Sense: 03 00 00 00 [ 168.864689] sd 5:0:0:0: [sdu] No Caching mode page found [ 168.864693] sd 5:0:0:0: [sdu] Assuming drive cache: write through [ 168.869489] sd 5:0:0:0: [sdu] No Caching mode page found [ 168.869495] sd 5:0:0:0: [sdu] Assuming drive cache: write through [ 169.069146] sdu: sdu1 sdu2 [ 169.096486] sd 5:0:0:0: [sdu] No Caching mode page found [ 169.096491] sd 5:0:0:0: [sdu] Assuming drive cache: write through [ 169.096496] sd 5:0:0:0: [sdu] Attached SCSI disk [ 171.043714] CIFS VFS: Malformed UNC in devname. [ 171.270406] UDF-fs: warning (device sdu1): udf_fill_super: No partition found (1) How can I do to get my usb disk drive working at boot ? Thanks Laurent Link to comment Share on other sites More sharing options...
