derwoodbones Posted August 7, 2015 #1 Posted August 7, 2015 Could someone try and make sense out of this problem i am having. I am currently running this rig Dell Optiplex 755 XPEnoboot 5.2-5565.2 Xpenology 5.2 5565 Update 2 I write XPEnoboot 5.2-5592.2 to my USB drive with Win32DiskImager Boot & Choose Install / Upgrade and this is what I get ?
noki Posted August 7, 2015 #2 Posted August 7, 2015 Xpenology 5.2 5565 Update 2 OK You install XPEnoboot 5.2-5592.1 in USB drive with Win32DiskImager and INSTALL/UPGRADE on BOOT After upgrade install DSM 5.2.5592 e reboot di NAS Upgrade DSM 5.2.5592 Update 1 and POWER OFF nas You install XPEnoboot 5.2-5592.2 in USB drive with Win32DiskImager and INSTALL/UPGRADE on BOOT After upgrade install DSM 5.2.5592 Update2 e reboot di NAS I have Dell Optiplex with Xpenology......
derwoodbones Posted August 7, 2015 Author #3 Posted August 7, 2015 Well unfortunately thats not going to work, XPEnoboot 5.2-5592.1 will not load on my system either
sbv3000 Posted August 8, 2015 #4 Posted August 8, 2015 a crazy thought, but look in the Dell bios for virtualisation options and turn it off?
derwoodbones Posted August 8, 2015 Author #5 Posted August 8, 2015 OK I have determined there is some kind of hardware incompatibility with DSM 5.2.5592 & XPEnoboot 5.2-5592.2 on Dell Optiplex 745 & 755. I managed to do a clean install on another Bare metal to 5592 Update 2, ran perfect rebooted several times then swapped it into the 745 first. booted normally twice then back to the same errors seen in above image. Same results on Optiplex 755 Thank you guys for trying to help.
Jman420 Posted August 9, 2015 #6 Posted August 9, 2015 OK I have determined there is some kind of hardware incompatibility with DSM 5.2.5592 & XPEnoboot 5.2-5592.2 on Dell Optiplex 745 & 755. I managed to do a clean install on another Bare metal to 5592 Update 2, ran perfect rebooted several times then swapped it into the 745 first. booted normally twice then back to the same errors seen in above image. Same results on Optiplex 755 Thank you guys for trying to help. If you are able to figure out a driver or something that is missing let us know and we will try to add it.
derwoodbones Posted August 9, 2015 Author #7 Posted August 9, 2015 I wish I knew, the above images is all I can offer you. Like I said it will run 2 maybe 3 boots that whats shown in the image is all you get
sbv3000 Posted August 10, 2015 #8 Posted August 10, 2015 this might be the Dell bios being reset, related to this topic? viewtopic.php?f=2&t=3289 I've had a bios reset problem myself with a gigabyte mobo, I worked around it by setting the bios to the 'perfect' settings, then booting but without letting Xpenology load (ie reset once the syslinux menu appears but before the o/s loads) this set the bios and now on reset it defaults and runs to 'last known good'. maybe look at the dell bios to see what options you have and are getting with various boots?
derwoodbones Posted August 10, 2015 Author #9 Posted August 10, 2015 I appreciate the help, But I just ordered an Optiplex 760 3.06 GHz core2 duo 8 GB ram on eBay for 45 $ Will wait and try it on that.
XPEH Posted August 10, 2015 #10 Posted August 10, 2015 I appreciate the help, But I just ordered an Optiplex 760 3.06 GHz core2 duo 8 GB ram on eBay for 45 $ Will wait and try it on that. Dell Optiplex 745/755/760 is about perfect for Xpenology. My favorite platform. The only downside is power efficiency is not great.
derwoodbones Posted August 10, 2015 Author #11 Posted August 10, 2015 I appreciate the help, But I just ordered an Optiplex 760 3.06 GHz core2 duo 8 GB ram on eBay for 45 $ Will wait and try it on that. Dell Optiplex 745/755/760 is about perfect for Xpenology. My favorite platform. The only downside is power efficiency is not great. Ya I had a 745 and a 755 that were given to me, used both for NAS 745 was never cleaned loaded with crap. blew several caps The 755 is the one im running now but it's starting to go, cant wait to get the 760 looks like new.
derwoodbones Posted August 12, 2015 Author #12 Posted August 12, 2015 Optiplex 760 arrived today, Upgraded to 5592 Update 2 without a hitch working perfectly !
