philsrb Posted August 4, 2015 #1 Posted August 4, 2015 i am currently running dam 5.2 5565 update 2 on 2 systems for a while.very stable, very happy. however, on one system i get I/O errors on one specific HDD (WD RED WD30EFRX, pretty new) once in a while. On that system, i am running an LSI Card in IT mode. now while i was checking, i noticed that i cannot get any info in the HDD health info overview, it says not available.same thing for history. Smart reads me out some values. furthermore i just noticed i cannot enable write cache on the system. does this have something to do with the LSI Card. I further tested and tried to get info from an ssd which is connected to the sata ports on the mainboard, and that also don't work. on the changelog of xpenoboot it once mentioned this: Fixed LSI Controller issues (If you have a problem, please add parameter "rmmod=ata_piix" in Syslinux boot line) am i experiencing issues? i am pretty conservative about meeting around with configs as i am running an 8x3tb raid5 array with my data on it. before starting to fool around i wanted to check if anyone has made similar experiences.. Quote
snoopy78 Posted August 4, 2015 #2 Posted August 4, 2015 please check your LSI firmware... viewtopic.php?f=2&t=4985&p=29840 i had the issue with P20 FW and you should take some actions asap, as i crashed my whole system.... if only 1 hdd shows this symptoms it looks like it's broken and needs to be replaced.. i've got 2 baremetal systems with 5.2-5565.2 and following HBAs running without any issues: LSI 9300-16i (driver made by trantor viewtopic.php?f=2&t=6772 ) LSI 9201-16i LSI 9211-8i (IBM M1015 LSI IT Flash) just don't use FW P20 then it should be fine... Quote
philsrb Posted August 4, 2015 Author #3 Posted August 4, 2015 i will dive into the subject of which firmware... but why can i not see the health status of disks in storage manager? is this normal with raid controllers in it mode? i don't get it... Quote
snoopy78 Posted August 5, 2015 #4 Posted August 5, 2015 for me i can see the health status in my xpe for drives connected to HBA Quote
philsrb Posted August 6, 2015 Author #5 Posted August 6, 2015 have you done any special settings? i cannot access the health info overview pane or the history pane on the HDD overview page in Storage manager which seems quite strange...further i cannot activate enable write cache...i checked, i have p19 firmware in the controller so this is not the problem...it might just be a falling drive Quote
philsrb Posted August 10, 2015 Author #6 Posted August 10, 2015 it was definitely a falling drive...still anyone got any idea as to why my system won't show health info on the hard drives tab in the storage manager? neither health info nor history works it just says service not available Quote
