XPEnology DS3612xs DSM 4.1 build 2668++ (more hardware)
Andy928
New version for the 4.1++ repack
v1.1
The .config file is included in kernel
USB
USB_OHCI_HCD (thanks totalnas for the tip)
As usual give feedbacks :smile:
Great! :grin:
I hope other releases of 4.2 will include them also.
I suggest that ALL developers share the ".config" file of different releases. I feel that the community needs to try divide the efforts in:
1) Kernel patching: new drivers, USB VID:PID hack, etc.
2) BIOS hacking: SYNOBIOS modding.
3) Script improvements: like UPS, LVM, SSD hack or others.
4) Binary releases: boot IMG and PAT file for plainPC, Microserver, ESX, VirtualBOX, etc.
Peharps, after this division someone can starting to compile non-x86 versions.
TN.
I totaly agree with you totalnas :smile:
I found a bug in my repack about usb detection preventing usb external drive to mount in DSM and system to restart/shutdown correctly.
I find the fix (some modules was not compiled correctly), and now it's working great.
The usb boot stick is also detected as USB and not like hard drive. I think this will fix the grub error when install.
Wait and see...
PS: If someone have anything to add/fix please tell me :wink:
Anyway to repack this for the latest 4.2 3211 build?
v1.1
NETWORK
Replace the REALTEK r8169 driver with the r8168 v8.036 (RTL8111x/RTL8168x/RTL8411x)
Add REALTEK driver r8101 v1.024.00 (RTL8100x/RTL8101x/RTL8102x/RTL8103x/RTL8401x/RTL8105x/RTL8106x)
Update INTEL e1000e driver to v2.4.14 (support I217x and I218x chip)
list of supported intel adapter : https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=15817&keyword=e1000e〈=eng
USB
SATA
VIA SATA support (SATA_VIA)
SCSI
3ware 5/6/7/8xxx ATA-RAID
3ware 9xxx SATA-RAID
3ware 97xx SAS/SATA-RAID
HP Smart Array SCSI
Adaptec AIC7xxx (New Driver)
Adaptec AIC79xx U320
Adaptec AIC94xx SAS/SATA
Marvell 88SE64XX/88SE94XX SAS/SATA
LSI Logic New Generation RAID Device (MEGARAID_NEWGEN)
HighPoint RocketRAID 3xxx/4xxx Controller
IBM ServeRAID
Intel® C600 Series Chipset SAS
Qlogic QLA 1240/1x80/1x160 SCSI
QLogic ISP4XXX and ISP82XX
Link : http://xpenology.trantor.be/XPEnology_D ... or-v1.1.7z
v1.1
NETWORK
list of supported intel adapter : https://downloadcenter.intel.com/Detail ... e〈=eng
USB
SATA
SCSI
HP Smart Array SCSI
IBM ServeRAID
No because synology doesn't post the correct sources for the 4.2 branch.
They announce DSM 4.3, I think in few weeks we have what we need :grin:
Well my friend, I think we will have to wait for those sources (personal opinion) or, they take the easy way and they publish the first versions of the 4.3 DSM in GPL in order for us to test for them :mrgreen: . This is what i would do if i would be Syno. :ugeek:
