d34dm4n Posted February 18, 2013 #26 Posted February 18, 2013 hi, it's possible to install on intel board d945gclf2 (intel atom dual core) ? now it's running win server 2k8 with xpenology on vmware but i want to install without virtual machine.There's hardware support ? i'have tried to boot from usb but booting is ok , network ok, sata don't work. Tnx for reply Quote
r3zon8 Posted February 25, 2013 #27 Posted February 25, 2013 HI, wanted to say thank you for your work. Working on HP N40L with onboard nic and added Intel 1000 dual GbE expansion card. flashed img to usb with new disks. installed, reboot, working great! Quote
dm500 Posted February 28, 2013 #28 Posted February 28, 2013 Is there a way that someone can post a step by step how to for changing the MAC address and serialize the unit. Currently i have 2 HP n40l units running in the same subnet and its a big problem, because they have same MAC address.. Thanks Nemo Quote
dmark1 Posted March 6, 2013 #29 Posted March 6, 2013 Thanks this is great! I havent been able to download the add-on packages through package manager. Is this feature working? Anyone else have this problem? Quote
XoN Posted March 6, 2013 #30 Posted March 6, 2013 Thanks this is great! I havent been able to download the add-on packages through package manager. Is this feature working? Anyone else have this problem? It's working on my server... I use the N40L version, the software should be the same with some driver differences, so, it should work in yours too... I have to say that is not very fast, but it works in the end. Quote
dmark1 Posted March 6, 2013 #31 Posted March 6, 2013 Thanks this is great! I havent been able to download the add-on packages through package manager. Is this feature working? Anyone else have this problem? It's working on my server... I use the N40L version, the software should be the same with some driver differences, so, it should work in yours too... I have to say that is not very fast, but it works in the end. Thanks, I'm running it virtualized (Virtualbox), connectivity seems to be fine. the VM was able to ping internet sites. When i click download, the package stays at 0% downloaded. Any ideas? Quote
XPEH Posted March 6, 2013 #32 Posted March 6, 2013 Synology mirror sites are still very busy with everyone is updating their boxes. Try it again later. Quote
dreamer76 Posted March 10, 2013 #33 Posted March 10, 2013 If I boot from usb everything seems to work. he indicates "Booting the kernel. I just can not find him with assistant. it seems that the network card also does nothing. I did this tutorial on a PC viewtopic.php?f=2&t=17 Quote
obee Posted April 10, 2013 #34 Posted April 10, 2013 Hi Andy, Thanks for your great work with this! It almost working perfectly on my Atom ITX - Intel DN2800MT: http://www.intel.com/content/www/us/en/ ... 800mt.html Only the USB ports not recognized. I have read your wiki tutorial on building kernel: http://xpenology.com/wiki/en/building_xpenology However, I don't not fully understand the steps involved... Is it possible for me to build the USB module and put to the USB boot key? Also, what if I wanna add an additional PCI-E USB 3.0 card? Is there any driver already built with the existing XPEnology DS3612xs DSM4.1 build 2668+ so that I don't need to do the kernel building things? Thanks again for your effort! Quote
RainHEART Posted April 13, 2013 #35 Posted April 13, 2013 last screen shows "DiskStation login: _" but I don't know about ID and PW What is ID and PW Quote
obee Posted April 16, 2013 #36 Posted April 16, 2013 last screen shows"DiskStation login: _" but I don't know about ID and PW What is ID and PW You have it defined in "Synology Assistant" Quote
jbesclapez Posted May 3, 2013 #37 Posted May 3, 2013 Guys, could you post the image file elsewhere than on YANDEX. It takes hours to get it... Please do it, I really need this image with all the drivers!!! Quote
XciD69 Posted May 5, 2013 #38 Posted May 5, 2013 Hello, What about Sapphire Pure White E350 with MARVELL 88E8059 PCI EXPRESS GIGABIT LAN controller ? I tried 3202 but It stop at booting kernel and the 4.1 stop here : http://www.noelshack.com/2013-18-1367532089-20130502-235644.jpg with led blinking but can't found the nas on PC or Mac .. Thanks Quote
jerrychan0610 Posted May 12, 2013 #39 Posted May 12, 2013 3ware 9xxx SATA RAID, 97xx SAS SATA RAIDAdaptec AIC94xx Marvell 88SE64XX/88SE94XX SAS SATA LSI Logic MegaRAID, MPT Fusion SAS 2.0 VMWare PVSCSI can i use LSI 9260-8I in this version? thanks Jerry Quote
JvZ Posted May 26, 2013 #40 Posted May 26, 2013 I own a NAS DeLuxe NDL2700ST (Basically a Thecus N7700Pro NAS) but I was really not satisfied with the firmware they developped. This NAS is like Synology basic hardware: Intel Core2Duo 7400 3Gb memory Marvell 88SE64xx raid controller Intel 1Gb nics 7x2Tb SATA disks So I had tried several other NAS OS-es like freeNAS, openmediavault even Windows Storage Server (which at least was able to do the baisc functions I need it for (backup, iCIFS, SCSI and NFS) but it lacked performance (duh). Besides the NAS DeLux I own a RS3413xs+ which I like a lot, not only performance wise but OS like as well. So I tried to load this image on the NAS delux and to my supprise it runs smoothly. The only thing I hope for is an upgrade to DSM 4.2 with the smae drivers as in this firmware, so any plans on releasing a 4.2 build 3211++ ? grtx Johan Quote
Schnapps Posted May 26, 2013 #41 Posted May 26, 2013 Hi JvZ There is a thread with DSM 4.2 3202 repack for DS3612xs in a torrent file here http://xpenology.com/forum/viewtopic.php?f=2&t=555&start=40#p1436 I have the "original 3202" and haven't used this repacked file, but i'm seeding the torrent. Please try it and give us your feedback. Thanks! Quote
fonix232 Posted May 27, 2013 #42 Posted May 27, 2013 Hi JvZThere is a thread with DSM 4.2 3202 repack for DS3612xs in a torrent file here http://xpenology.com/forum/viewtopic.php?f=2&t=555&start=40#p1436 I have the "original 3202" and haven't used this repacked file, but i'm seeding the torrent. Please try it and give us your feedback. Thanks! It still doesn't have the extra drivers (does not boot on my hardware, while 2668++ does, I suppose it needs some extra parts like the ICH7 controller, etc.), so it is a no-go. But if someone could grab the kernel, and change the config to include those, we would be able to use it. Unfortunately the 2668++ config is not in the kernel (why enable /proc/config.gz, right?? That's it about GPL....), so we can't duplicate the changes easily, but maybe Andy can help us out a bit? Of course I would like to have 4.2 on my device too, but I don't want to erase my nearly 300GB data on the disks just for updating, especially as my connection is extremely slow (20Mbit). Quote
MosFoyer Posted June 7, 2013 #43 Posted June 7, 2013 Using a new boot virtual disk file to replace the old file. Testing Quote
didlawowo Posted June 7, 2013 #44 Posted June 7, 2013 it's possible to run xpenology on reeady nas duo v 2? Quote
zazza76 Posted June 8, 2013 #45 Posted June 8, 2013 I own a NAS DeLuxe NDL2700ST (Basically a Thecus N7700Pro NAS) but I was really not satisfied with the firmware they developped. This NAS is like Synology basic hardware: Intel Core2Duo 7400 3Gb memory Marvell 88SE64xx raid controller Intel 1Gb nics 7x2Tb SATA disks So I had tried several other NAS OS-es like freeNAS, openmediavault even Windows Storage Server (which at least was able to do the baisc functions I need it for (backup, iCIFS, SCSI and NFS) but it lacked performance (duh). Besides the NAS DeLux I own a RS3413xs+ which I like a lot, not only performance wise but OS like as well. So I tried to load this image on the NAS delux and to my supprise it runs smoothly. The only thing I hope for is an upgrade to DSM 4.2 with the smae drivers as in this firmware, so any plans on releasing a 4.2 build 3211++ ? grtx Johan Any one can help me to install DSM on TheCus N7000pro ? How to boot from usb on a system with no keyboard/video ports ? Maybe with a serial console session ? Quote
fonix232 Posted June 12, 2013 #46 Posted June 12, 2013 I own a NAS DeLuxe NDL2700ST (Basically a Thecus N7700Pro NAS) but I was really not satisfied with the firmware they developped. This NAS is like Synology basic hardware: Intel Core2Duo 7400 3Gb memory Marvell 88SE64xx raid controller Intel 1Gb nics 7x2Tb SATA disks So I had tried several other NAS OS-es like freeNAS, openmediavault even Windows Storage Server (which at least was able to do the baisc functions I need it for (backup, iCIFS, SCSI and NFS) but it lacked performance (duh). Besides the NAS DeLux I own a RS3413xs+ which I like a lot, not only performance wise but OS like as well. So I tried to load this image on the NAS delux and to my supprise it runs smoothly. The only thing I hope for is an upgrade to DSM 4.2 with the smae drivers as in this firmware, so any plans on releasing a 4.2 build 3211++ ? grtx Johan Any one can help me to install DSM on TheCus N7000pro ? How to boot from usb on a system with no keyboard/video ports ? Maybe with a serial console session ? It has a PCIex8 port, so simply jam a cheap PCIe video card in there (any cheapo will do), and use a USB keyboard (or a USBtoPS2 converter). Then you can see what the problem is. Quote
bsergiu Posted June 17, 2013 #47 Posted June 17, 2013 Hi! First of all, thanks for your great work to make DSM available to us! I have installed DSM 4.1 2668++ on Asrock AD2550-ITX http://www.asrock.com/mb/Intel/AD2550-ITX/index.asp (Dual core Atom, Intel NM10 Express, USB 3.0 with ASMedia ASM1042) and it works quite well, well with one exception though: USB. I have disabled the USB 3.0 interface. On the USB 2.0, I added my HP printer and it is correctly recognized by the DSM in the list of the "External Devices". But no luck at all with USB drives: I have tried 2 card readers, 4 USB sticks, one WD drive - no luck at all. I have seen some other questions like this, but no answer at all. Could you please give us a hint, whether we can fix it ourselves, or you plan to work at this? Thanks a lot in advance! Quote
sraptor Posted June 20, 2013 #48 Posted June 20, 2013 How you turn off the server from the power button without using the GUI web? Quote
Wurstbaum Posted June 21, 2013 #49 Posted June 21, 2013 I am very happy to hear that finally Diskstation is available on x86 Hardware Could someone please provide a bootable disc image which is possible to me mounted using ESX or should I create a USB Stick and pull its content to be stuffed into a bootable iso image? Greets from rainy Germany Quote
guldhammer Posted June 21, 2013 #50 Posted June 21, 2013 I have a prolem by trying to install it on a Dell Poweredge 860 server, it says: Warning! No microcode update loaded for processor 1. What does it mean whit that, My server have a Intel Pentium 4 3.4 Ghz 64 bit??? It hae a Intel 3000 chipset. Can you help me?? Regards Guldhammer Quote
