Trantor Posted June 23, 2013 Share #51 Posted June 23, 2013 (edited) Hello everyone, I just repack this build (source from the andy928's git repo), recompil the kernel with more drivers: NETWORK Marvell Yukon 2 (sky2) : 88E8021/88E8022/88E8035/88E8036/88E8038/88E8050/88E8052/88E8053/88E8055/88E8061/88E8062, SysKonnect SK-9E21D/SK-9S21 JMicron JMC250 (jme) VIA Rhine (via-rhine) : (Rhine-I (VT86C100A), Rhine-II (VT6102), or Rhine-III (VT6105) SCSI VMware PVSCSI driver Link : new version available viewtopic.php?f=2&t=41&p=4365#p4365 If anyone want new drivers (SCSI RAID, network...), please tell me I will update this repack. I will also post optimized kernel for Intel (Core 2/newer Xeon), (Intel P4 / older Netburst based Xeon) and AMD (Opteron/Athlon64/Hammer/K8) CPUs. Edited June 29, 2013 by Guest Quote Link to comment Share on other sites More sharing options...
interested Posted June 24, 2013 Share #52 Posted June 24, 2013 Can you add e1000e.ko intel (I217-V) network driver > > > > PLEASE < < < < LINK > https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=15817 Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 24, 2013 Share #53 Posted June 24, 2013 Can you add e1000e.ko intel (I217-V) network driver > > > > PLEASE < < < < LINK > https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=15817 My repack include the same built in network drivers as andy's version (see first page), plus sky2, jme, via-rhine. So e1000e is include I just forgot to add all SCSI drivers... maybe in futur repack. Quote Link to comment Share on other sites More sharing options...
interested Posted June 25, 2013 Share #54 Posted June 25, 2013 could it be, that I need new, maybe latest version of e1000e.ko ??? becouse, like U see In ubuntu 13.04 (i217-v) works: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: ASUSTeK Computer Inc. Device 859f Flags: bus master, fast devsel, latency 0, IRQ 44 Memory at f0500000 (32-bit, non-prefetchable) [size=128K] Memory at f053d000 (32-bit, non-prefetchable) [size=4K] I/O ports at f080 [size=2] Capabilities: [c8] Power Management version 2 Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [e0] PCI Advanced Features Kernel driver in use: e1000e modinfo e1000e: dejan@Linux:~$ modinfo e1000e filename: /lib/modules/3.8.0-19-generic/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko version: 2.1.4-k license: GPL description: Intel(R) PRO/1000 Network Driver author: Intel Corporation, srcversion: 2631BAE58994F6AA09DC82F alias: pci:v00008086d00001559sv*sd*bc*sc*i* alias: pci:v00008086d0000155Asv*sd*bc*sc*i* alias: pci:v00008086d0000153Bsv*sd*bc*sc*i* alias: pci:v00008086d0000153Asv*sd*bc*sc*i* alias: pci:v00008086d00001503sv*sd*bc*sc*i* alias: pci:v00008086d00001502sv*sd*bc*sc*i* alias: pci:v00008086d000010F0sv*sd*bc*sc*i* alias: pci:v00008086d000010EFsv*sd*bc*sc*i* alias: pci:v00008086d000010EBsv*sd*bc*sc*i* alias: pci:v00008086d000010EAsv*sd*bc*sc*i* alias: pci:v00008086d00001525sv*sd*bc*sc*i* alias: pci:v00008086d000010DFsv*sd*bc*sc*i* alias: pci:v00008086d000010DEsv*sd*bc*sc*i* alias: pci:v00008086d000010CEsv*sd*bc*sc*i* alias: pci:v00008086d000010CDsv*sd*bc*sc*i* alias: pci:v00008086d000010CCsv*sd*bc*sc*i* alias: pci:v00008086d000010CBsv*sd*bc*sc*i* alias: pci:v00008086d000010F5sv*sd*bc*sc*i* alias: pci:v00008086d000010BFsv*sd*bc*sc*i* alias: pci:v00008086d000010E5sv*sd*bc*sc*i* alias: pci:v00008086d0000294Csv*sd*bc*sc*i* alias: pci:v00008086d000010BDsv*sd*bc*sc*i* alias: pci:v00008086d000010C3sv*sd*bc*sc*i* alias: pci:v00008086d000010C2sv*sd*bc*sc*i* alias: pci:v00008086d000010C0sv*sd*bc*sc*i* alias: pci:v00008086d00001501sv*sd*bc*sc*i* alias: pci:v00008086d00001049sv*sd*bc*sc*i* alias: pci:v00008086d0000104Dsv*sd*bc*sc*i* alias: pci:v00008086d0000104Bsv*sd*bc*sc*i* alias: pci:v00008086d0000104Asv*sd*bc*sc*i* alias: pci:v00008086d000010C4sv*sd*bc*sc*i* alias: pci:v00008086d000010C5sv*sd*bc*sc*i* alias: pci:v00008086d0000104Csv*sd*bc*sc*i* alias: pci:v00008086d000010BBsv*sd*bc*sc*i* alias: pci:v00008086d00001098sv*sd*bc*sc*i* alias: pci:v00008086d000010BAsv*sd*bc*sc*i* alias: pci:v00008086d00001096sv*sd*bc*sc*i* alias: pci:v00008086d0000150Csv*sd*bc*sc*i* alias: pci:v00008086d000010F6sv*sd*bc*sc*i* alias: pci:v00008086d000010D3sv*sd*bc*sc*i* alias: pci:v00008086d0000109Asv*sd*bc*sc*i* alias: pci:v00008086d0000108Csv*sd*bc*sc*i* alias: pci:v00008086d0000108Bsv*sd*bc*sc*i* alias: pci:v00008086d0000107Fsv*sd*bc*sc*i* alias: pci:v00008086d0000107Esv*sd*bc*sc*i* alias: pci:v00008086d0000107Dsv*sd*bc*sc*i* alias: pci:v00008086d000010B9sv*sd*bc*sc*i* alias: pci:v00008086d000010D5sv*sd*bc*sc*i* alias: pci:v00008086d000010DAsv*sd*bc*sc*i* alias: pci:v00008086d000010D9sv*sd*bc*sc*i* alias: pci:v00008086d00001060sv*sd*bc*sc*i* alias: pci:v00008086d000010A5sv*sd*bc*sc*i* alias: pci:v00008086d000010BCsv*sd*bc*sc*i* alias: pci:v00008086d000010A4sv*sd*bc*sc*i* alias: pci:v00008086d0000105Fsv*sd*bc*sc*i* alias: pci:v00008086d0000105Esv*sd*bc*sc*i* depends: intree: Y vermagic: 3.8.0-19-generic SMP mod_unload modversions parm: debug:Debug level (0=none,...,16=all) (int) parm: eeprom_bad_csum_allow:Allow bad EEPROM checksums (int) parm: copybreak:Maximum size of packet that is copied to a new buffer on receive (uint) parm: TxIntDelay:Transmit Interrupt Delay (array of int) parm: TxAbsIntDelay:Transmit Absolute Interrupt Delay (array of int) parm: RxIntDelay:Receive Interrupt Delay (array of int) parm: RxAbsIntDelay:Receive Absolute Interrupt Delay (array of int) parm: InterruptThrottleRate:Interrupt Throttling Rate (array of int) parm: IntMode:Interrupt Mode (array of int) parm: SmartPowerDownEnable:Enable PHY smart power down (array of int) parm: KumeranLockLoss:Enable Kumeran lock loss workaround (array of int) parm: WriteProtectNVM:Write-protect NVM [WARNING: disabling this can lead to corrupted NVM] (array of int) parm: CrcStripping:Enable CRC Stripping, disable if your BMC needs the CRC (array of int) dejan@Linux:~$ Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 25, 2013 Share #55 Posted June 25, 2013 could it be, that I need new, maybe latest version of e1000e.ko ??? becouse, like U see In ubuntu 13.04 (i217-v) works: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: ASUSTeK Computer Inc. Device 859f Flags: bus master, fast devsel, latency 0, IRQ 44 Memory at f0500000 (32-bit, non-prefetchable) [size=128K] Memory at f053d000 (32-bit, non-prefetchable) [size=4K] I/O ports at f080 [size=2] Capabilities: [c8] Power Management version 2 Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [e0] PCI Advanced Features Kernel driver in use: e1000e modinfo e1000e: dejan@Linux:~$ modinfo e1000e filename: /lib/modules/3.8.0-19-generic/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko version: 2.1.4-k license: GPL description: Intel(R) PRO/1000 Network Driver author: Intel Corporation, srcversion: 2631BAE58994F6AA09DC82F alias: pci:v00008086d00001559sv*sd*bc*sc*i* alias: pci:v00008086d0000155Asv*sd*bc*sc*i* alias: pci:v00008086d0000153Bsv*sd*bc*sc*i* alias: pci:v00008086d0000153Asv*sd*bc*sc*i* alias: pci:v00008086d00001503sv*sd*bc*sc*i* alias: pci:v00008086d00001502sv*sd*bc*sc*i* alias: pci:v00008086d000010F0sv*sd*bc*sc*i* alias: pci:v00008086d000010EFsv*sd*bc*sc*i* alias: pci:v00008086d000010EBsv*sd*bc*sc*i* alias: pci:v00008086d000010EAsv*sd*bc*sc*i* alias: pci:v00008086d00001525sv*sd*bc*sc*i* alias: pci:v00008086d000010DFsv*sd*bc*sc*i* alias: pci:v00008086d000010DEsv*sd*bc*sc*i* alias: pci:v00008086d000010CEsv*sd*bc*sc*i* alias: pci:v00008086d000010CDsv*sd*bc*sc*i* alias: pci:v00008086d000010CCsv*sd*bc*sc*i* alias: pci:v00008086d000010CBsv*sd*bc*sc*i* alias: pci:v00008086d000010F5sv*sd*bc*sc*i* alias: pci:v00008086d000010BFsv*sd*bc*sc*i* alias: pci:v00008086d000010E5sv*sd*bc*sc*i* alias: pci:v00008086d0000294Csv*sd*bc*sc*i* alias: pci:v00008086d000010BDsv*sd*bc*sc*i* alias: pci:v00008086d000010C3sv*sd*bc*sc*i* alias: pci:v00008086d000010C2sv*sd*bc*sc*i* alias: pci:v00008086d000010C0sv*sd*bc*sc*i* alias: pci:v00008086d00001501sv*sd*bc*sc*i* alias: pci:v00008086d00001049sv*sd*bc*sc*i* alias: pci:v00008086d0000104Dsv*sd*bc*sc*i* alias: pci:v00008086d0000104Bsv*sd*bc*sc*i* alias: pci:v00008086d0000104Asv*sd*bc*sc*i* alias: pci:v00008086d000010C4sv*sd*bc*sc*i* alias: pci:v00008086d000010C5sv*sd*bc*sc*i* alias: pci:v00008086d0000104Csv*sd*bc*sc*i* alias: pci:v00008086d000010BBsv*sd*bc*sc*i* alias: pci:v00008086d00001098sv*sd*bc*sc*i* alias: pci:v00008086d000010BAsv*sd*bc*sc*i* alias: pci:v00008086d00001096sv*sd*bc*sc*i* alias: pci:v00008086d0000150Csv*sd*bc*sc*i* alias: pci:v00008086d000010F6sv*sd*bc*sc*i* alias: pci:v00008086d000010D3sv*sd*bc*sc*i* alias: pci:v00008086d0000109Asv*sd*bc*sc*i* alias: pci:v00008086d0000108Csv*sd*bc*sc*i* alias: pci:v00008086d0000108Bsv*sd*bc*sc*i* alias: pci:v00008086d0000107Fsv*sd*bc*sc*i* alias: pci:v00008086d0000107Esv*sd*bc*sc*i* alias: pci:v00008086d0000107Dsv*sd*bc*sc*i* alias: pci:v00008086d000010B9sv*sd*bc*sc*i* alias: pci:v00008086d000010D5sv*sd*bc*sc*i* alias: pci:v00008086d000010DAsv*sd*bc*sc*i* alias: pci:v00008086d000010D9sv*sd*bc*sc*i* alias: pci:v00008086d00001060sv*sd*bc*sc*i* alias: pci:v00008086d000010A5sv*sd*bc*sc*i* alias: pci:v00008086d000010BCsv*sd*bc*sc*i* alias: pci:v00008086d000010A4sv*sd*bc*sc*i* alias: pci:v00008086d0000105Fsv*sd*bc*sc*i* alias: pci:v00008086d0000105Esv*sd*bc*sc*i* depends: intree: Y vermagic: 3.8.0-19-generic SMP mod_unload modversions parm: debug:Debug level (0=none,...,16=all) (int) parm: eeprom_bad_csum_allow:Allow bad EEPROM checksums (int) parm: copybreak:Maximum size of packet that is copied to a new buffer on receive (uint) parm: TxIntDelay:Transmit Interrupt Delay (array of int) parm: TxAbsIntDelay:Transmit Absolute Interrupt Delay (array of int) parm: RxIntDelay:Receive Interrupt Delay (array of int) parm: RxAbsIntDelay:Receive Absolute Interrupt Delay (array of int) parm: InterruptThrottleRate:Interrupt Throttling Rate (array of int) parm: IntMode:Interrupt Mode (array of int) parm: SmartPowerDownEnable:Enable PHY smart power down (array of int) parm: KumeranLockLoss:Enable Kumeran lock loss workaround (array of int) parm: WriteProtectNVM:Write-protect NVM [WARNING: disabling this can lead to corrupted NVM] (array of int) parm: CrcStripping:Enable CRC Stripping, disable if your BMC needs the CRC (array of int) dejan@Linux:~$ So your intel card doesn't work with my repack ? Quote Link to comment Share on other sites More sharing options...
interested Posted June 25, 2013 Share #56 Posted June 25, 2013 Trantor, - Yes, my network card not working ... - A also dont see any packages with your relese ??? Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 25, 2013 Share #57 Posted June 25, 2013 I will test the e1000e with my TYAN S8230-D quad LAN (Intel 82574L / Intel 82576EB). What's your mainboard reference ? What packages do you talk about ? Quote Link to comment Share on other sites More sharing options...
interested Posted June 25, 2013 Share #58 Posted June 25, 2013 MB > https://www.asus.com/Motherboards/GRYPHON_Z87/#specifications Packages, I mean DSM addons (connection failed) Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 25, 2013 Share #59 Posted June 25, 2013 You mean packages available from packages center in DSM ? Quote Link to comment Share on other sites More sharing options...
interested Posted June 25, 2013 Share #60 Posted June 25, 2013 yes, with all others compilations I have access to Packages > http://www.synology.com/dsm/dsm_app.php?lang=enu Quote Link to comment Share on other sites More sharing options...
interested Posted June 26, 2013 Share #61 Posted June 26, 2013 it looks like first version of i217-v network controller has been released: - 28.1.2013, linux 2.2.14 ver - 11.3.2013, linux 2.3.2 ver. - 20.6.2013, linux 2.4.14 ver. Probably the driver in your compilation does not recongnite the new 2013 network controller. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22The+e1000e+Linux*+stable+base+driver+for+the+Intel%C2%AE+PCI-Express*+%22&OSVersion=Linux*&DownloadType=Drivers&sort=Date&sortDir=ascending&perpage=10 Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 26, 2013 Share #62 Posted June 26, 2013 I test on two computer: ZOTAC AD01 (realtek network, amd neo x2 cpu, 2gb) : install ok, network ok, packages ok TYAN S8230-D (intel network 82574L & 82576EB (e1001e and igb), amd opteron 6174, 16gb : install ok, network ok, packages ok You right, after closer look I217x support began with 2.2.14 version and 2.4.14 offer I218x support. The e1000e drivers include is older than these, because this is the built-in version included in 3.2.11 kernel (release 03-13-12). I think it's work with the other release, because it' base on DSM 4.2 (3.2.30 kernel) and/or odie82544's build include the e1000e driver from intel website that is newer than mine. I will try to include the latest e1000e driver in my next rebuild/repack Quote Link to comment Share on other sites More sharing options...
interested Posted June 26, 2013 Share #63 Posted June 26, 2013 OK. TNX for the info. I will try one more time your compilation & see what is with packages ... Do you know, why UPS is not recognized through USB ??? Funny thing is, that Synology say`s its supported (APC Smart 750). Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 26, 2013 Share #64 Posted June 26, 2013 UPS is detected in DSM but you can't configure it ? Quote Link to comment Share on other sites More sharing options...
interested Posted June 26, 2013 Share #65 Posted June 26, 2013 UPS is connected throught USB cable, but not recgnited: https://dl.dropboxusercontent.com/u/34829066/Synology/Slike/UPS.JPG UPS compatibility > http://www.synology.com/support/faq_show.php?q_id=300 Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 26, 2013 Share #66 Posted June 26, 2013 I willy try this with my eaton UPS. Did your UPS work with other release ? EDIT : @interested : maybe your packages issue is related to your network card which is not reconized correctly... Quote Link to comment Share on other sites More sharing options...
interested Posted June 26, 2013 Share #67 Posted June 26, 2013 Packages are working on DSM 4.2-3202 & 4.2-3211 Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 27, 2013 Share #68 Posted June 27, 2013 Packages are working on DSM 4.2-3202 & 4.2-3211 And with 4.1++ ? Did your UPS work with other release ? Quote Link to comment Share on other sites More sharing options...
interested Posted June 27, 2013 Share #69 Posted June 27, 2013 I did try 4.1++ & yours 4.1 , but packages not working by me. Changing DNS settings & so on ... nothing helped. But pinging to outside works (SSH). Today I received new: - USB PCI Express Card (D-link DUB-1310), I wil try UPS with this card >>> UPS issues http://xpenology.com/forum/viewtopic.php?f=2&t=788 - Intel network card ( EXPI9301CTBLK - based on 82574L ), I will try the packages To see if this all problems are in hardware ... I will be back in 9 hours , maybe with good results . Quote Link to comment Share on other sites More sharing options...
interested Posted June 27, 2013 Share #70 Posted June 27, 2013 New hardware did not solve the problem. Packages are working only in DSM 4.2-3202 & 4.2-3211, neu USB controller don't see UPS. Quote Link to comment Share on other sites More sharing options...
totalnas Posted June 27, 2013 Share #71 Posted June 27, 2013 I willy try this with my eaton UPS.Did your UPS work with other release ? EDIT : @interested : maybe your packages issue is related to your network card which is not reconized correctly... Hi, To enable your UPS see: http://xpenology.com/forum/viewtopic.php?f=2&t=917 Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 28, 2013 Share #72 Posted June 28, 2013 I will shortly post updated version of my repack with latest intel & realtek lan drivers + lot of SCSI drivers Quote Link to comment Share on other sites More sharing options...
Vortex Posted June 28, 2013 Share #73 Posted June 28, 2013 That would be great! Quote Link to comment Share on other sites More sharing options...
postdeals Posted June 29, 2013 Share #74 Posted June 29, 2013 I have this versionrunning fine but its on version 4.1 how can i get it to upgrade to 4.2 ? it fails no matter if i use manual update ( pat file ) or use internet upgrade. Quote Link to comment Share on other sites More sharing options...
Trantor Posted June 29, 2013 Share #75 Posted June 29, 2013 (edited) New version for the 4.1++ repack v1.1 The .config file is included in kernel NETWORK Replace the REALTEK r8169 driver with the r8168 v8.036 (RTL8111x/RTL8168x/RTL8411x) Add REALTEK driver r8101 v1.024.00 (RTL8100x/RTL8101x/RTL8102x/RTL8103x/RTL8401x/RTL8105x/RTL8106x) Update INTEL e1000e driver to v2.4.14 (support I217x and I218x chip) list of supported intel adapter : https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=15817&keyword=e1000e〈=eng USB USB_OHCI_HCD (thanks totalnas for the tip) SATA VIA SATA support (SATA_VIA) SCSI 3ware 5/6/7/8xxx ATA-RAID 3ware 9xxx SATA-RAID 3ware 97xx SAS/SATA-RAID HP Smart Array SCSI Adaptec AIC7xxx (New Driver) Adaptec AIC79xx U320 Adaptec AIC94xx SAS/SATA Marvell 88SE64XX/88SE94XX SAS/SATA LSI Logic New Generation RAID Device (MEGARAID_NEWGEN) HighPoint RocketRAID 3xxx/4xxx Controller IBM ServeRAID Intel® C600 Series Chipset SAS Qlogic QLA 1240/1x80/1x160 SCSI QLogic ISP4XXX and ISP82XX Link : new version available here : viewtopic.php?f=2&t=937 As usual give feedbacks Edited July 7, 2013 by Guest Quote Link to comment Share on other sites More sharing options...
