unmesh 0 Posted February 10 Share Posted February 10 I'd like to put together a x86/x64 1-bay NAS with a 10TB 3.5" hard drive and drop it off at a friend's location as a remote NAS backup target but the SFF/Thin-Client PCs I see are typically designed for 2.5" drives. Maybe I haven't looked hard enough and someone can suggest devices. An alternative would be to hang a USB 3.0 drive off a power sipping thin client running Xpenology which would look a little kudgey. I've found the instructions to have DSM use USB drives as internal drives but is this a bad idea? Thanks Quote Link to post Share on other sites
IG-88 708 Posted February 14 Share Posted February 14 https://www.hardkernel.com/shop/odroid-h2plus/ https://www.hardkernel.com/shop/odroid-h2-case-1/ 1 Quote Link to post Share on other sites
unmesh 0 Posted February 14 Author Share Posted February 14 (edited) Very nice form factor! Though dual 2.5Gbps is definitely overkill for the application Does DSM have drivers for the RTL8125? Thanks. Edited February 14 by unmesh Quote Link to post Share on other sites
unmesh 0 Posted February 14 Author Share Posted February 14 I found a post that talks about compiling a driver for the RTL8125 for the 1.04b DS918+ loader. Quote Link to post Share on other sites
test4321 4 Posted February 15 Share Posted February 15 On 2/14/2021 at 5:50 AM, IG-88 said: https://www.hardkernel.com/shop/odroid-h2plus/ https://www.hardkernel.com/shop/odroid-h2-case-1/ This would be a dope PFSense router! Thanks for the link! Future project! Quote Link to post Share on other sites
IG-88 708 Posted February 15 Share Posted February 15 22 hours ago, unmesh said: I found a post that talks about compiling a driver for the RTL8125 for the 1.04b DS918+ loader. there is a working r8125 driver already in my extra.lzma, there might be very few newer cards that need a newer driver (possible for 918+) but the chip on that odroid is older for sure Quote Link to post Share on other sites
