futureline 0 Posted January 21 Share Posted January 21 I used a tool "XPEnology Tool 1.4.2" to make a USB boot stick. After reading the HOWTO the laptop starts successful. After finding de installation on DSAssistant I use de manual installation en use de PAT file the tool tells me to download for the model i have chosen. Loader 1.03b : "DS3615xs" DSM 6.1 for DS3615xs: "DSM_DS3615xs_23739.pat" The installation webpage tells me everything is ready and is rebooting. The laptop reboots on the USB. The same intro text appears but nothing happens. I wait for the countdown to end. Still nothing. I try to find the system with DSAssistant but it is not to be found. A PING makes IP unreachable. Can someone help me or tell me what it is i am doing wrong? Quote Link to post Share on other sites
elipicerie 0 Posted January 21 Share Posted January 21 i ve got the same probleme. after a good installation ... -the same intro text appears with usb stick or - diskboot failure without Quote Link to post Share on other sites
billat29 38 Posted January 21 Share Posted January 21 (edited) @futureline I'm a bit confused which DSM you tried to install and you need to check. 6.1 will not work with the 1.03b loader. However DSM_DS3615xs_23739 seems to refer to 6.2.0 which I would not install on your system due to driver issues. See here : A question. When you first booted from USB (before starting installation) you would have seen a series of messages on the laptop screen before you went to a web browser to start the installation. When you boot now, do you get those messages? @elipicerie The USB stick is always required to boot the system. If you have a further problem, please start a new thread in the appropriate forum Edited January 21 by billat29 Quote Link to post Share on other sites
futureline 0 Posted January 22 Author Share Posted January 22 I use the software tool that someone made. Following the steps at the howto, I can use the version DS3615xs with 6.1 and loader 1.03b. Thanks for the reply. I will try your suggestion and follow those steps. Verstuurd vanaf mijn ELE-L29 met Tapatalk Quote Link to post Share on other sites
