lidaize 0 Posted January 2 Share Posted January 2 Happy new year everyone, I have a z97 gaming 5 with 6 sata ports. I test install 918+ with 6.2 and 916+ with 6.17, both version with correct drivers and loader from jun. However both of two version seems not working with Dell Perc H310, because I can't see the esata pop up on the top right corner. So I modify the synoinfo.conf in both of ect.default and ect to get the sata and esata in order to work. z97 gaming 5 have 6 sata ports, Dell perc H310 have 8 ports. I know both 918 and 916 only support 12 disks, so I did modify like below, 4 internal ports stay in sata, 2 internal ports and 6 ports from Dell Perc H310 as esata, 2 ports from H310 disable by default maxdrives limited. esata : 111111110000 = 0xff0 insata: 000000001111 = 0xf then reboot, HOWEVER the synoinfo.conf in /etc.defaults roll back my edit to esataportcfg="0x0" and internalportcfg="0xff" The synoinfo.conf in /etc still like the same as my edited esataportcfg="0xff0" and internalportcfg="0xf" And I can't see any esata drives pop up when i login to the system. Before I was using 3617xs and 3615xs with 6.17 and 6.2, both works without any issue, thus i believe is not the H310 problems. Any one can help me on this?? Quote Link to post Share on other sites
lidaize 0
then reboot,
0 answers to this question
