endormmc 4 Posted December 29, 2020 Share Posted December 29, 2020 Hi I've been searching the config file for thumbnail creation but I can't find it. I'm running xpenology under esxi with 8 Cores (xeon L5630) and 16GB ram. My goal would be to speed up the creation of thumbnails allowing more thumbs at the same time, or more cores, or more priority.... So, can you help me? Quote Link to post Share on other sites
flyride 452 Posted December 29, 2020 Share Posted December 29, 2020 Assuming you are talking about Photo Station, /usr/syno/bin/ffmpeg-thumb is aliased to /usr/bin/ffmpeg and that is v2.7.1 (released in 2015). Multithreading support did exist back then but I expect it has been improved. You might try and hack in a current version, although it will get overwritten with upgrades. However I am pretty sure it is called by script, which is likely to be single threaded. FMI: https://www.reddit.com/r/synology/comments/7ui7c1/conversion_process_details/ Quote Link to post Share on other sites
nevusZ 6 Posted December 30, 2020 Share Posted December 30, 2020 https://www.fatlemon.co.uk/2016/12/creating-thumbnails-for-the-synology-dsm-photostation/ if you have a really slow machine, that can help Quote Link to post Share on other sites
endormmc 4 Posted January 3 Author Share Posted January 3 On 12/30/2020 at 9:30 AM, nevusZ said: https://www.fatlemon.co.uk/2016/12/creating-thumbnails-for-the-synology-dsm-photostation/ if you have a really slow machine, that can help it's not a slow machine, and I already read that url. Anyway thanks for the help Quote Link to post Share on other sites
endormmc 4 Posted January 3 Author Share Posted January 3 On 12/29/2020 at 11:05 PM, flyride said: Assuming you are talking about Photo Station, /usr/syno/bin/ffmpeg-thumb is aliased to /usr/bin/ffmpeg and that is v2.7.1 (released in 2015). Multithreading support did exist back then but I expect it has been improved. You might try and hack in a current version, although it will get overwritten with upgrades. However I am pretty sure it is called by script, which is likely to be single threaded. FMI: https://www.reddit.com/r/synology/comments/7ui7c1/conversion_process_details/ Interesting.... maybe I could try to "upgrade" the package.... Quote Link to post Share on other sites
