So I've just installed Xpenology for the first time.
Under CPU it shows the normal CPU for the DS3615xs Core i3 and shows it running at 800mhz.
But I really have an i5, does this matter?
It is showing my ram correctly @16gb.
Don't worry its only visual and only in the webgui. If you run cat /proc/cpuinfo in terminal session, you'll see that its detected correctly.
