I'm stuck and would love some suggestions as I've run out of ideas
I'm currently running 5.2-5644 and I can't get the DSM web UI to stay responsive. Essentially I reboot the NAS, and everything works as expected, I can log into the UI, perform actions, etc...then like clockwork about 5-10 minutes later, the UI is no longer responsive and when I reload the page I get a "ERR_CONNECTION_REFUSED" error.
Some additional info:
Synology Assistant can still locate it, and says it is "Ready"
I can directly log into it (when I attached a keyboard and monitor). When I'm logged in, I've tried looking for any information in the error logs, but haven't found anything (perhaps I'm looking in the wrong places).
I've also tried restarting nginx, but that operation failed without any info as to why (also, no nginx error log).
I'm at a loss. More than anything I want to backup my data to a usb drive, before I mess with things, but I'm even running into trouble with that. I tried copying all the files over directly from the terminal to a usb drive, but ran into all sorts of permission problems when I connected it to another machine.
When I run the SMART test, it doesn't show any error, but the DSM is never up long enough for the disk partition analysis to finish. I wouldn't be surprised if a disk is having an issue, but I don't know which one (I have 4).
Any suggestions on where I can look to debug this issue?
gmoniey 0
0 answers to this question
