Fan Control
Vodka2014
Good Day,
I would like to know if there is an easy way to set the Fan Control of all the fans in a system via the OS or a MOD. If not i take it i need to do this all in the BIOS to get the fans to the correct speed that i want.
Right now the 4 fans are running full speed. I should state I have a Fan Hub with all 4 Fans connected to the Case Fan Header on the MB.
Thanks
Edited by Vodka2014
2 answers to this question
BIOS or internal script daemon are the likely plausible options.  Scripting will require the ability to control fans from the shell.  lm_sensors and other typical tools are not part of DSM and need to be added somehow.
Synology manages fans through a proprietary UART based interface so the native functionality isn't useful for physical fan control.  I suppose it would be possible to leverage their script logic and link into a typical hardware interface, but I have not seen anyone do this before.
Edited by flyride
Answer this question...
