Kayhan Belek 0 Posted December 22, 2020 Share Posted December 22, 2020 Hi there, I want to share my setup for budget AMD system. Hardware: MSI A320M A Mainboard AMD Ryzen 3 3100 CPU (no GPU support) 8 GB 3000Mhz G.Skill RAM Software: DSM_DS918+_25426 Baremetal 1.04b Notes: Since the CPU does not support graphics cards, I had to install an extra GPU (RX560). I do not know if this graphics card will help the transcoding process. Can't upgrade to 25426 Update 3, yet. And it's working well... Maybe it will be someone useful. Quote Link to post Share on other sites
IG-88 770 Posted December 23, 2020 Share Posted December 23, 2020 10 hours ago, Kayhan Belek said: do not know if this graphics card will help the transcoding process. no kernel driver, so it can't work wit any software 10 hours ago, Kayhan Belek said: Can't upgrade to 25426 Update 3, yet. ??? maybe try this, there are cases where its not just in esxi environment, afaik it it will not make anything worse on a baremetal system, i tried it at least once to see if it would interfere on a baremetal and it had no negative effect https://xpenology.com/forum/topic/28183-running-623-on-esxi-synoboot-is-broken-fix-available/ 1 Quote Link to post Share on other sites
Kayhan Belek 0 Posted December 23, 2020 Author Share Posted December 23, 2020 8 hours ago, IG-88 said: no kernel driver, so it can't work wit any software I swapped my i3 computer with AMD system. Xpenology running on Asus Z370P + Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz 8 hours ago, IG-88 said: maybe try this, there are cases where its not just in esxi environment, afaik it it will not make anything worse on a baremetal system, i tried it at least once to see if it would interfere on a baremetal and it had no negative effect https://xpenology.com/forum/topic/28183-running-623-on-esxi-synoboot-is-broken-fix-available/ Update issue has been solved with FixSynobooth.sh script. Thank you so much. Quote Link to post Share on other sites
IG-88 770 Posted December 23, 2020 Share Posted December 23, 2020 3 minutes ago, Kayhan Belek said: Xpenology running on Asus Z370P + Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz then if you have not already, read this for transcoding in videostation (plex with plexpass should not need this) https://xpenology.com/forum/topic/24864-transcoding-without-a-valid-serial-number/ https://xpenology.com/forum/topic/30552-transcoding-and-face-recognitionpeople-and-subjects-issue-fix-in-once/ 1 Quote Link to post Share on other sites
