Stefano 2 Posted December 21, 2020 Share Posted December 21, 2020 Goodevening, i'm in trouble... after a shutdown made today with "power button" app i no longer see my HP N40L nas on the network. It worked so far ( and for the last 2 years). If i connect a monitor to the nas vga connector i see that it hangs on the screenshot attached and i don't hear the normal Hard-disk rumors of the normal boot. The two leds (the orange and green one) of lan connector on port 1 of the HP NC360T Dual NIC are on. I have tried to make a simple ping from my PC to the correct IP but it doens't work. Thank you for your feedback Quote Link to post Share on other sites
bearcat 79 Posted February 7 Share Posted February 7 Hi, have you sorted this out yet? Did you use a static IP configured on your NAS, or did you use DHCP? If DHCP, check your DHCP server and it's log, to make sure you are looking for the correct IP. Did you try to find it using the Synology Assistent? Quote Link to post Share on other sites
Orphée 5 Posted February 7 Share Posted February 7 (edited) I had a similar issue, my RTC battery was dead. Check if your bios settings were not reset. Edited February 7 by Orphée Quote Link to post Share on other sites
Stefano 2 Posted February 7 Author Share Posted February 7 Hi guys thank you for your feedback. I have resolved. I had a problem with the DHCP ( I use a raspberry pi with Pi-hole that acts as a DHCP Server). After set it correctly it worked just fine. Thank you 1 Quote Link to post Share on other sites
