trb Posted June 23, 2015 #1 Posted June 23, 2015 Help! I am new to XPEnology and trying to install to an Abit Digidice SFF PC that has an IS50 mainboard, am using a Pentium 4 HT CPU and 2GB RAM and just a single SATA disk to start. Have tried all boot images I could find and get a message "This kernel requires an X86-64 CPU, but only detected an i686 CPU. Unable to boot – please use a kernel appropriate for your CPU" have updated BIOS to latest available version and tried all settings I can think of in the BIOS but get the same message for all images. Really want to use XPEnology and put the old Digidice machine to good use or else chuck it out which would be a waste, any help would be greatly appreciated!
htpcdude Posted June 23, 2015 #2 Posted June 23, 2015 All the latest images are for 64bit CPUs, you are using a 32bit CPU. You can go to http://xpenology.me/downloads/ and try one of the Nanoboot images under Nanoboot DSM-5.0-4528 DS214Play. The ones with x86 in the filename.
trb Posted June 24, 2015 Author #3 Posted June 24, 2015 Hi htpcdude, Thanks for the info, I downloaded the file NanoBoot-x86-5.0.3.1-fat.img and wrote this to a 4GB USB stick using Win32DiskImager. I now get a message during boot "unknown keyword in configuration file" which appears several times and then just a cursor, I saw another post that said to type help then hit enter then hit enter again but this did not work. I tried to write the image several times to the stick (which is new today) but still the same result each time, also formatting in full first using the HPUSB tool then using the Win32DiskImager tool again to write the image also did not work. Any ideas? Thanks in advance.
trb Posted June 24, 2015 Author #4 Posted June 24, 2015 OK so tried the VFAT image and it worked, will let you know how I get on!
trb Posted June 25, 2015 Author #5 Posted June 25, 2015 So I'm still having issues, now when I try to load the pat file DSM_DS214play_4528.pat with the above NanoBoot I get an error in SA: Server error (error code 38) If you are installing using wireless connection yada, yada, yada...... Also the formatting data partition step 3 is greyed out, the diskstation gets an IP address OK because I see it in SA and also the webpage half opens up, I am direct connected using an Ethernet cable so don't know why I see this error. Could not find any reference to this error code on the forums either....
trb Posted June 29, 2015 Author #6 Posted June 29, 2015 Is anyone able to help me with my issue, tried over the weekend with no success. Thanks in advance
trb Posted July 2, 2015 Author #7 Posted July 2, 2015 Still not luck in getting this working, could really do with some help! Thanks in advance.
brantje Posted July 3, 2015 #8 Posted July 3, 2015 Still not luck in getting this working, could really do with some help! Thanks in advance. DSM_DS214play_4528.pat with the bootloader NanoBoot-x86-5.0.3.1-fat.img is not gonna work. Make sure you get corresponding pat file with the bootloader.
trb Posted July 3, 2015 Author #9 Posted July 3, 2015 Thanks for the info, please could you direct me to the correct pat file as I could only find what was in the list and assumed they would work? This is the boot image I have: NanoBoot x86 5.0.2.4-vfat Server error (error code 38) If you are installing using wireless connection yada, yada, yada...... Also the formatting data partition step 3 is greyed out, the diskstation gets an IP address OK because I see it in SA and also the webpage half opens up, I am direct connected using an Ethernet cable so don't know why I see this error. Could not find any reference to this error code on the forums either....
brantje Posted July 6, 2015 #10 Posted July 6, 2015 Thanks for the info, please could you direct me to the correct pat file as I could only find what was in the list and assumed they would work? This is the boot image I have: NanoBoot x86 5.0.2.4-vfat Server error (error code 38) If you are installing using wireless connection yada, yada, yada...... Also the formatting data partition step 3 is greyed out, the diskstation gets an IP address OK because I see it in SA and also the webpage half opens up, I am direct connected using an Ethernet cable so don't know why I see this error. Could not find any reference to this error code on the forums either.... Try this pat: http://ukdl.synology.com/download/DSM/5 ... s_5022.pat
trb Posted July 6, 2015 Author #11 Posted July 6, 2015 Thanks for the help brantje. Unfortunately the file does not work, when trying to load using SA I get a warning message 'You have selected an installation file incompatible with the system model'. Any ideas?
trb Posted July 7, 2015 Author #12 Posted July 7, 2015 So now I am using NanoBoot-x86-5.0.2.4-vfat.img with DSM_DS214play_5022.pat and it is happy with the pat file, I get the following when trying to install the pat file: Server error (error code 38) If you are installing using wireless connection yada, yada, yada...... Also the formatting data partition step 3 is greyed out, the diskstation gets an IP address OK because I see it in SA and also the webpage half opens up, I am direct connected using an Ethernet cable so don't know why I see this error. Is it possible that there is a disk or SATA controller issue causing this, do I need to prep the hard disk in any way before trying to install the pat file? Really need help to get this working.
Nobi Posted July 20, 2015 #15 Posted July 20, 2015 Hi, some problem here with a i686 cpu, i have also tried all mentioned combination of boot loader and .pat files, and ran into the port 23 not reachable error. But everything is connected by cable on an unmanaged switch and firewall is deactivated Anyone an other idea? regards norbert
