StanG Posted December 13, 2020 #1 Posted December 13, 2020 (edited) The serial number I see shown in "DSM control panel -> Infocenter" is different that the one in grub.conf on the synoboot.img bootdisk. I believe it's the serial number I made up when I clean installed to test the new version. However I have since changed the synoboot.img and there is a different serial number in the grub.cfg file. But the serial number in DSM still is the old one. How can I change the serial in DSM to be like the one that is now in synoboot.img? Thanks I'm using Xpenology on ESXi 6.7. I'm using DS3617XS with loader jun 1.03b. I'm running DSM 6.2.3 Edited December 13, 2020 by StanG Quote
Guest Posted December 13, 2020 #2 Posted December 13, 2020 Hi, The serial number changes in case of update, or re-installation. Changing it on the boot key is not enough. Quote
StanG Posted December 13, 2020 Author #3 Posted December 13, 2020 Is it possible to change the serial number in DSM? Quote
Vinc Posted March 27, 2021 #4 Posted March 27, 2021 On 12/13/2020 at 10:56 PM, StanG said: Is it possible to change the serial number in DSM? Yes you can, this threat explains how you can do that. Had the same problem with 2 identical machines and the same mac address Quote
