Benedict Posted December 12, 2020 #1 Posted December 12, 2020 Hi, would like to ask for some help regarding the installation of DSM for MSI H410I PRO WIFI & I3 10100. I was using DSM 6.1 previously and it crash so i upgraded to the above hardware. I'm having issue detecting the hardware, unable to find synology using synology assistance. I have follow the guide and change the VID (USB Drive), SID(USB Drive), Sn(USB Drive) and mac address(motherboard NIC). Is there anything that i miss out. I have also try to replacing the extra.lzma/extra2.lzma from below thread. Anyone can point me to the correct direction? Many thanks. Quote
IG-88 Posted December 12, 2020 #2 Posted December 12, 2020 8 hours ago, Benedict said: MSI H410I PRO WIFI & I3 10100. I was using DSM 6.1 previously and it crash so i upgraded to the above hardware. I'm having issue detecting the hardware, unable to find synology using synology assistance. you did not specify what loader and dsm type you where using, the hardware is capable of 918+ but not all people choose that 8 hours ago, Benedict said: Sn(USB Drive) no thats supposed to be the SN of the synology product, but a valid sn is only needed for same special things and there are ways around that too, just keep the original sn and mod the last 4 digits (avoids possible blacklisting from synology) 8 hours ago, Benedict said: I'm having issue detecting the hardware, imho to early for that conclusion, depends on what dsm type you tried if you used 3615/17 loader 1.03b then you would need to use csm mode and the legacy (non-uefi) usb boot device if possible boot a rescue linux and check the pci vid/pid of the i219 nic with lspci thats the device list for the i219 you can use with the drivers you can download atm https://xpenology.com/forum/topic/37536-hi-guys-any-driver-for-intel%C2%AE-i219v/?tab=comments#comment-180769 also you are linking to a old driver thread for dsm 6.2.2, if you combine these drivers with dsm 6.2.3 its not going to work, you need extra drivers for 6.2.3 https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/ (if you let it download dsm over internet its going to be 6.2.3 (25426) Quote
Benedict Posted December 12, 2020 Author #3 Posted December 12, 2020 Hi IG-88, Thanks for your reply. I'm using 1.04b ds918+ loader. I have used OSFmount to change the VIP,PID and MAC on the grub file. Kept the sno as default. Copied extra.lzma/extra2.lzma for loader 1.04b ds918+ DSM 6.2.3 v0.13.3 and burn it to USB. I also tried to copy the zImage and rd.gz from "DSM_DS918+_25426.pat I'm still unable to detect xpenology. Is it due to my NIC is not supported? I'm trying to get my pci vid/pid now. Any advise? Quote
IG-88 Posted December 12, 2020 #4 Posted December 12, 2020 4 hours ago, Benedict said: Is it due to my NIC is not supported? might be the case, 918+ does work in uefi and csm mode so it should not be a boot problem 4 hours ago, Benedict said: I'm trying to get my pci vid/pid now. that would be the way to know for sure (beside using a serial port on the system and monitor the boot process with a null-modem-cable on a serial console) 4 hours ago, Benedict said: Any advise? use a added nic that works in a pcie slot until i have the new extra/extra2 with the newer intel drivers that would support newer i219 Quote
Benedict Posted December 13, 2020 Author #5 Posted December 13, 2020 Hi IG-88, I have the output for ispci. I used Truenas shell to get the output thou. is my NIC supported? root@truenas[~]# lspci 00:00.0 Class 0600: Device 8086:9b63 (rev 03) 00:02.0 Class 0300: Device 8086:9bc8 (rev 03) 00:08.0 Class 0880: Device 8086:1911 00:14.0 Class 0c03: Device 8086:a3af 00:14.2 Class 1180: Device 8086:a3b1 00:16.0 Class 0780: Device 8086:a3ba 00:17.0 Class 0106: Device 8086:a382 00:1d.0 Class 0604: Device 8086:a398 (rev f0) 00:1d.2 Class 0604: Device 8086:a39a (rev f0) 00:1f.0 Class 0601: Device 8086:a3da Quote
bearcat Posted December 16, 2020 #6 Posted December 16, 2020 @Benedict as far as I can tell, none of the listed devices are networkcards 🤔 If you do a "lspci | grep 0200" it should only return the devices with Class=0200 = NIC's. Quote
IG-88 Posted December 16, 2020 #7 Posted December 16, 2020 On 12/13/2020 at 5:28 AM, Benedict said: root@truenas[~]# lspci that list should be longer, like this (and yes class 0200 would be network, in this example a realtek 8168/8111 and a dualport 10G broadcom nic) 0000:00:00.0 Class 0600: Device 8086:3e1f (rev 08) 0000:00:01.0 Class 0604: Device 8086:1901 (rev 08) 0000:00:02.0 Class 0300: Device 8086:3e91 0000:00:08.0 Class 0880: Device 8086:1911 0000:00:14.0 Class 0c03: Device 8086:a2af 0000:00:16.0 Class 0780: Device 8086:a2ba 0000:00:17.0 Class 0106: Device 8086:a282 0000:00:1b.0 Class 0604: Device 8086:a2e9 (rev f0) 0000:00:1b.3 Class 0604: Device 8086:a2ea (rev f0) 0000:00:1b.4 Class 0604: Device 8086:a2eb (rev f0) 0000:00:1c.0 Class 0604: Device 8086:a292 (rev f0) 0000:00:1c.3 Class 0604: Device 8086:a293 (rev f0) 0000:00:1c.4 Class 0604: Device 8086:a294 (rev f0) 0000:00:1c.5 Class 0604: Device 8086:a295 (rev f0) 0000:00:1c.6 Class 0604: Device 8086:a296 (rev f0) 0000:00:1c.7 Class 0604: Device 8086:a297 (rev f0) 0000:00:1d.0 Class 0604: Device 8086:a298 (rev f0) 0000:00:1f.0 Class 0601: Device 8086:a2cc 0000:00:1f.2 Class 0580: Device 8086:a2a1 0000:00:1f.3 Class 0403: Device 8086:a2f0 0000:00:1f.4 Class 0c05: Device 8086:a2a3 0000:01:00.0 Class 0106: Device 197b:0585 0000:04:00.0 Class 0200: Device 14e4:16a1 (rev 11) 0000:04:00.1 Class 0200: Device 14e4:16a1 (rev 11) 0000:07:00.0 Class 0200: Device 10ec:8168 (rev 16) 0000:0a:00.0 Class 0106: Device 1b4b:9215 (rev 11) 0001:00:02.0 Class 0000: Device 8086:6f04 (rev ff) 0001:00:02.2 Class 0000: Device 8086:6f06 (rev ff) 0001:00:03.0 Class 0000: Device 8086:6f08 (rev ff) 0001:00:03.2 Class 0000: Device 8086:6f0a (rev ff) 0001:00:1f.0 Class 0000: Device 8086:8c54 (rev ff) 0001:00:1f.3 Class 0000: Device 8086:8c22 (rev ff) 0001:06:00.0 Class 0000: Device 1b4b:1475 (rev ff) 0001:08:00.0 Class 0000: Device 1b4b:9235 (rev ff) 0001:09:00.0 Class 0000: Device 8086:1533 (rev ff) 0001:0c:00.0 Class 0000: Device 8086:1533 (rev ff) 0001:0d:00.0 Class 0000: Device 8086:1533 (rev ff) Quote
Benedict Posted December 17, 2020 Author #8 Posted December 17, 2020 Hi all, Thanks for the info. Please see below output, can advise if it's supported? Where do i get the list of NIC that are supported? 00:1f.6 Class 0200: Device 8086:0d55 Quote
flyride Posted December 17, 2020 #9 Posted December 17, 2020 https://xpenology.com/forum/topic/14127-guide-to-native-drivers-dsm-621-on-ds918/ https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/ Quote
IG-88 Posted December 17, 2020 #10 Posted December 17, 2020 (edited) 15 hours ago, Benedict said: 00:1f.6 Class 0200: Device 8086:0d55 i edited my old post , about already supported i219, looks like i forgot to copy a block with lower id's used for i219 https://xpenology.com/forum/topic/37536-hi-guys-any-driver-for-intel®-i219v/?do=findComment&comment=180769 so the drivers we use should support the i219 on your systemboard Edited December 17, 2020 by IG-88 Quote
Benedict Posted December 18, 2020 Author #11 Posted December 18, 2020 Hi guys, Not sure which part that i did wrong or miss out, I'm unable to detect my synology after it boot to Jun's loader. Here are the steps that i perform, any help will be deeply appreciated. Used Jun's loader - v1.04b (DS918+) Replaced grub.cfg VID (USB), PID (USB), S.no.(No change), MAC (Systemboard MAC) Replaced the following extra.lzma/extra2.lzma from extra.lzma/extra2.lzma for loader 1.04b ds918+ DSM 6.2.3 v0.13.3 Replaced the following zImage and rd.gz from "DSM_DS918+_25426.pat" Write to thumbdrive. I manage to boot to Jun's loader screen. After awhile, the NIC port no more connectivity. Unable to scan my synology from synology assistance. Quote
Benedict Posted December 20, 2020 Author #12 Posted December 20, 2020 Any help on the installation steps? Do I need to format the data disk before the installation? Quote
IG-88 Posted December 21, 2020 #13 Posted December 21, 2020 On 12/20/2020 at 2:44 AM, Benedict said: Any help on the installation steps? Do I need to format the data disk before the installation? maybe just try loader 1.04b as it comes without any changes or newer extra.lzma the basic boot and network operations are working without any changes, the usb vid/pid would only be important when trying to install dsm to a disk but atm you are failing even the 1st step of finding it in network, if you get this part working then you can start things like usb vid/pid and mac an grub.cfg beside synology assistant you can check your dhcp server for activity aka new addresses Quote
Benedict Posted December 23, 2020 Author #14 Posted December 23, 2020 No luck with default loader. Can't seems to detect synology in my network. Port have activity but router is not showing any IP for synology. Quote
