killseeker Posted June 10, 2015 #1 Posted June 10, 2015 Hey All, I'm having a strange issue at the moment where my x64 install of xpenology is working fine however my Network Interfaces gui is blank and stuck on Loading. I'm running 5565 Update 1 Is there anything I can do to bring it back??? I think it came around because I've installed a 2nd Network card in the device. Which went fine, the xpenology system saw the new Nic and added the devices. I tried to create a new bond0 and nothing happened. Upon reboot the blank gui started to appear. I know if this was a proper synology system I could hit the reset button once and clear my nic settings / bonds etc, however I don't have a button being a custom build. I do seem to have a large number of Ethernet interfaces in my CLI eth0 -> eth7 however only have my new Intel Dual Port card enabled. Any help would be great thank you. Cheers, Kill_Seeker
killseeker Posted June 11, 2015 Author #2 Posted June 11, 2015 Just an update: Using the same process listed here: viewtopic.php?f=2&t=1086 I changed my version file to a downgraded version 5055 Rebooted using the 5565 USB Flash and selected Update / Install from the boot menu Synology Assist found the device as Diskstation - Migratable Successfully reinstalled 5565 over the top and this resolved my Network Interfaces issues All Data on the disks is intact and OK
