Antiloader 0 Posted December 3, 2020 Share Posted December 3, 2020 (edited) Hi guys, I have a problem with the resource monitor for LAN 1. It shows me always 0 bytes up and 0 bytes download. I have already installed custom extra.lzma but no changes. I have searched for a solution, but were not able to find one. Does anybody have an idea? DSM Version: DSM 6.2.3-25426 Update 3 Loader: Jun’s Loader v1.03b DS3615xs Motherboard: FM2A88X-ITX+ LAN on board: Qualcomm Atheros AR8171 Many thanks! Edited December 3, 2020 by Antiloader Quote Link to post Share on other sites
flyride 519 Posted December 3, 2020 Share Posted December 3, 2020 Do you have more than one NIC in the system? Quote Link to post Share on other sites
Antiloader 0 Posted December 3, 2020 Author Share Posted December 3, 2020 No, only one NIC(onboard) is installed Quote Link to post Share on other sites
IG-88 773 Posted December 3, 2020 Share Posted December 3, 2020 2 hours ago, Antiloader said: No, only one NIC(onboard) is installed can you provide a dmesg log? maybe a screenshot from the webgui in the network configuration area? Quote Link to post Share on other sites
Antiloader 0 Posted December 3, 2020 Author Share Posted December 3, 2020 Sure, please find attached the log file and screenshots. Many thanks in advance. 2020_12_03_dmesg Quote Link to post Share on other sites
IG-88 773 Posted December 4, 2020 Share Posted December 4, 2020 [Thu Dec 3 19:33:03 2020] thuuuufxlufutuu: module verification failed: signature and/or required key missing - tainting kernel i have no clue whats the source of this in dmesg but i dont think it is related to your problem that would be the things i'd try - change mac address in geub.cfg to the real mac of your nic - disable ipv6 in gui - try a empty disk and loader 1.04b 918+ and see if problem is there too (newer kernel) Quote Link to post Share on other sites
Antiloader 0 Posted December 4, 2020 Author Share Posted December 4, 2020 Good morning, great, thanks! I'll try your proposals and come back to you. I guess you mean grub.cfg right? Many thanks! Quote Link to post Share on other sites
IG-88 773 Posted December 4, 2020 Share Posted December 4, 2020 10 hours ago, Antiloader said: grub.cfg right? yes, on a qwertz keyboard the "e" is right beside the "r" Quote Link to post Share on other sites
Antiloader 0 Posted December 4, 2020 Author Share Posted December 4, 2020 I've tried all the recommendations, but unfortunately no changes. Quote -change mac address in geub.cfg to the real mac of your nic - disable ipv6 in gui - try a empty disk and loader 1.04b 918+ and see if problem is there too (newer kernel) ifconfig shows me also 0 bytes for RX and TX Quote Link to post Share on other sites
IG-88 773 Posted December 5, 2020 Share Posted December 5, 2020 when reading this i'd expect it to be working with a newer kernel 4.4.59 from 918+ https://forums.gentoo.org/viewtopic-t-1012084-start-0.html i guess its a problem with the driver, as long as the system is working fine it could be seen as cosmetic (if you have ~110 MB/s when r/w big files its maxed out) if thats important you could use a different nic and disable the onboard nic Quote Link to post Share on other sites
Antiloader 0 Posted December 7, 2020 Author Share Posted December 7, 2020 great, thanks a lot for your help. Indeed, it's only a cosmetic thing, the r/w speed is absolutely ok. I will go on with another NIC Thank you! Quote Link to post Share on other sites
