daxrob 0 Posted November 15, 2020 Share Posted November 15, 2020 Hi, I just installed the 6.2 and then rebooted the DS. After the reboot the webui is not reacheable. I can do an SSH. What should be the problem? Rob Quote Link to post Share on other sites
0 IG-88 715 Posted November 15, 2020 Share Posted November 15, 2020 3 hours ago, daxrob said: I just installed the 6.2 and then rebooted the DS. After the reboot the webui is not reacheable. I can do an SSH. as in your post from yesterday https://xpenology.com/forum/topic/37191-what-is-the-correct-procedure-to-upgrade-from-62-to-622-or-later/#comment-179440 you did not specify information to be needed hardware used, loader used (at least 3 types of dsm), version of dsm used, was it a update from older version "i just installed" might imply a fresh install (as the other term would be "updated") and that's kind of impossible as SSH is not active after a fresh install so please lay out more detailed what you use and what you have done a guess is it might be this https://xpenology.com/forum/topic/26723-network-down-after-dsm-login/?tab=comments#comment-137953 Quote Link to post Share on other sites
daxrob 0
Rob
1 answer to this question
