retrieve volume
ikam
Hi !!
When you upgrade to 5.2 to 5565 lost who had mounted volume, volume was basic UN if the files are still there but I have no access to access them, the complex recognizes and lets me Play and from the windows can But see the folder password asks me and not let me access, but not from my Synology not see the folder ..
Thanks for the help
Maybe you should invest 2 minutes to read one of the dozens other threads with exactly the same problem as yours.
It's kind of disrespectfull to ask for the help (and time) of others just because you're to lazy to try it on your own...
DSM 5.2 is not yet supported by XPEnoboot. You need to downgrade your box back to 5.1. 5055 is the latest version supported by XPEnoboot.
To downgrade you need to edit the VERSION file on your system to make appear to be an older version than 5055 - otherwise the Install/Upgrade to 5055 will not work. As M0ps mentions there are other threads that discuss this in detail. Good luck.
Thanks for answering ..
For me it would be easier to know where the answer and use it in my problem and not have to be annoying and wait for someone willing and able to answer.
Perhaps not understand English or just look bad in the forum I have not found the solution to my problem.
Anyway sorry but encuenta the solution to edit Version.
Greetings and thanks
