bearcat 76 Posted November 9, 2020 Share Posted November 9, 2020 After playing around with iSCSI on an old server I "found" around, doing a clean install with Jun's 1.03b and DSM 6.2.3-25426 Update 2, I noticed the filetransfers was too slow. And sure enough, the nic was only getting 100Mb/s, and not the 1Gb/s it is supporting. Tried all the "usual stuff", replacing the cable and using a different port on the switch it is connected to, even swapped both cabel and port with a known working setup. The problem stayed with this N36L, and the other (N40L) works great at 1Gb/s with the cable and port I started with. Using SSH, I verified that 1Gb/s should be available, but it's not... admin@N36L:/$ lspci -k |grep 0200 0000:02:00.0 Class 0200: Device 14e4:165b (rev 10) admin@N36L:/$ ethtool eth0 Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Advertised pause frame use: Symmetric Advertised auto-negotiation: Yes Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Link partner advertised auto-negotiation: Yes Speed: 100Mb/s Duplex: Full Port: Twisted Pair PHYAD: 1 Transceiver: internal Auto-negotiation: on MDI-X: off Cannot get wake-on-lan settings: Operation not permitted Current message level: 0x000000ff (255) drv probe link timer ifdown ifup rx_err tx_err Link detected: yes Anyone have a tip? Quote Link to post Share on other sites
billat29 38 Posted November 9, 2020 Share Posted November 9, 2020 I have no idea what I am talking about (and I don't know how the modes are advertised) but I see that it thinks that the switch only does 100baseT Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Link partner advertised auto-negotiation: Yes 1 Quote Link to post Share on other sites
billat29 38 Posted November 9, 2020 Share Posted November 9, 2020 I also found something that suggested that you might be able to use ethtool to force 1Gb. Quote Link to post Share on other sites
bearcat 76 Posted November 9, 2020 Author Share Posted November 9, 2020 1 hour ago, billat29 said: I see that it thinks that the switch only does 100baseT You know what, I overlooked that "minor" detail. Thanks I have seen some people trying to force 1G with ethtool, but just like them, it crashes out my system...and I must do a power off/on. Quote Link to post Share on other sites
bearcat 76 Posted November 10, 2020 Author Share Posted November 10, 2020 Update: I first verified the problem, booting from a ElementaryOS USB stick, it linked up at 100Mb, but I could "force" it to 1Gb. Looked in my cabinet, and found a small managed switch, planned to config it to use 1Gb/Fdx/no autonegotiaton. But as soon as I plugged in the cable, 1Gb link LED was on, and I verified it in DSM controlpanel. So, the other switch (unmanaged Cisco) was not playing ball with my N36L, but both a N40L and a N54L was having no problem with it on any of the ports. Verified with reflashing the latest original BIOS on the N36L, same problem. Returned it to "Thebay" as my other G7's are running, same results. So, what can you expect of a old N36L, with 4GB RAM, running 2 Travelstar Z7K500 in Raid-1, Btrfs ? This is a constant read/write verification of an iSCSI target, not bad for such old HW? Quote Link to post Share on other sites
billat29 38 Posted November 10, 2020 Share Posted November 10, 2020 Quote Link to post Share on other sites
