Is XPEnoboot required permanently?
coalfield
Sorry in advance for this question, but I hope its a striaghtforward question for you to answer :smile:
I have a HP Gen8 microserver and am installing XPEnology direct to the box, no vitrual environment, I dont think I need it.
I have managed to get XPEnology installed to the single drive I currently have in the system, via the MicroSD card with XPEnoboot installed.
The system is up and running, however I was under the impression once installed the system was installed to the main drive, and hence I would no longer need the SD card. However after removing the microSD it fails to boot.
So am I right in saying the system will always need a microSD (or USB key) in the system in order to launch the software?
Thanks
