hkfind Posted May 16, 2015 #1 Posted May 16, 2015 Hi, all services were down after I upgrade from DSM 5.1-5022 Update 4 to 5. I received an email said the UPS connected reached low battery but I have no UPS at all. Please advise how to solve this issue. Thanks!
ninjax Posted May 19, 2015 #2 Posted May 19, 2015 You can downgrade until we have a solution. http://xpenology.me/how-to-downgrade-from-dsm-5-2/
ecsy Posted May 20, 2015 #3 Posted May 20, 2015 Can not downgrade, find.synology.com could not find storage.
Knarf Posted May 20, 2015 #4 Posted May 20, 2015 I too had this problem and when I went in to edit my version was listed as 5565, not 5022. I followed the editing directions listed lower in the forum "Downgrade 5565 to 5022" and did not have any luck when I allowed Synology Assistant to automatically apply the latest update. When I used the manual option and used the PAT file from my original installation everything worked fine. You will still need to turn off windows file sharing and restart it and you may need to go into the advanced settings and clear the SAMBA cash. Good luck and a big thanks to hongong3 for all his help.
