civic1217 Posted June 2, 2013 #1 Posted June 2, 2013 Hello all, I just got an old PC from my friends and now I am trying to install dsm4.2 I can find my nas by using assistant When I right click -> install Then I got error code 38...... Please help about this.... Thanks everyone!
pLANner Posted June 4, 2013 #3 Posted June 4, 2013 3202 doesn't see your HDD. It will not work on the old PC. Try this viewtopic.php?f=2&t=41
civic1217 Posted June 4, 2013 Author #4 Posted June 4, 2013 3202 doesn't see your HDD.It will not work on the old PC. Try this viewtopic.php?f=2&t=41 thanks for your reply! I tried but with the same result....
fonix232 Posted June 4, 2013 #5 Posted June 4, 2013 3202 doesn't see your HDD.It will not work on the old PC. Try this viewtopic.php?f=2&t=41 thanks for your reply! I tried but with the same result.... Did you try following the instructions on the picture? If yes and it did not work, it might be your router blocking port 23. Try to install through the web interface (when Synology Assistant sees the device, right click and Open it instead of Install. Same procedure as in the Assistant, upload the file, then sit back and wait).
shackwove Posted July 23, 2013 #6 Posted July 23, 2013 I had the same issue, i went with a different version and it worked. If they all fail then i guess your motherboard isn't supported.
