Hi gang.
Im quite new to this....
I got XPEnoboot_DS3615xs_5.1-5022 update 3 running on ESXi 5.5u2
My config is a core i5 with a DELL PERC H310 Sas controller installed as passthough.
I see a couple of issues that i can not figure out...
every once in a while my HDD exists hibernation, its not related to the hibernation timer, which is default 20 min...
Last time it was 30 min and 6 sec., before that it was 26 min and 1 sec and before that it was 34 min and 12 sec... that really wird.... why dont they stay hibernated?
When i look at the Storage manager it say ZERO hot spares, but looking at Control Panel/Storage is shows 1 disk as not initialized but as hot spare.
Still looking in control panel/Storage it shows HD model numbers (mount in the sas controller) but no temperature (-1 C), status Normal..
Going back to Storage Manager/HDD Serial numbers is "Loading..." Same with firmware... and SMART not supported. but why? im pretty sure my WD RED 4TB disks should support SMART.
Any body have any ideas for my missig smart? and for the hibernation issue?
/Stig
Hibernation upsets can be caused by lots of stuff. Apps you installed in DSM, network shares, ect.
As far as your one weird drive, it's probably the bootloader image for you XPEnology VM. For every ESXI VM of DSM I've had to add rmmod=piix_ata to the kernel line in syslinux.cfg of the bootloader, or it will show the bootloader drive as a disk within DSM. If this is the case, then it's also why it's temp is -1C (because it a virtual disk).
Look for apps that are waking drives up some times: plex, download station...
I let plex on but It wakes my drives roughly every 30 minutes...
Sadly it didnt work - or i did something wrong...
HDD still shows SMART not supported, and temp at -1...
And yes, i have no modules runnings, i even stopped NTP service...
I have pasted the logs, cfg and vmx file here... hope you have more ideas :wink:
Thanks
/Stig
syslinux.cfg:
UI menu.c32
PROMPT 0
TIMEOUT 50
rmmod=piix_ata
DEFAULT xpenology
MENU TITLE XPEnoboot 5.1-5022.3
synosys.log
info 2015/03/11 20:08:53 *********: User [**********] logged in from [192.168.8.61]
info 2015/03/11 20:26:27 SYSTEM: Internal disks woke up from hibernation.
Mar 11 20:10:15 dsm51 storagehandler.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
Mar 11 20:11:00 dsm51 SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: SmartDataRead(107) read value /dev/sdd fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdd fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: SmartDataRead(107) read value /dev/sde fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sde fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sda fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: SmartFirmAndSerialRead(156) AtaSmartFirmAndSerialRead fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
Mar 11 20:11:00 dsm51 SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdb fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdc fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdd fail
Mar 11 20:11:00 dsm51 SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sde fail
scemd.log
Mar 11 20:10:11 dsm51 scemd: manutild_ip_check.c:28 stop manutild.
Mar 11 20:26:17 dsm51 scemd: AtaSmartRawValueGet(65) read value /dev/sda fail
Mar 11 20:26:17 dsm51 scemd: AtaSmartRawValueGet(65) read value /dev/sdb fail
Mar 11 20:26:17 dsm51 scemd: AtaSmartRawValueGet(65) read value /dev/sdc fail
Mar 11 20:26:17 dsm51 scemd: AtaSmartRawValueGet(65) read value /dev/sdd fail
Mar 11 20:26:17 dsm51 scemd: AtaSmartRawValueGet(65) read value /dev/sde fail
Mar 11 20:26:27 dsm51 scemd: event_disk_hibernation_handler.c:24 Fail to set disk to standby
Mar 11 20:26:27 dsm51 scemd: event_disk_hibernation_handler.c:32 The internal disks wake up from hibernation.
vmx
.encoding = "UTF-8"
config.version = "8"
virtualHW.version = "8"
nvram = "DSM51.nvram"
pciBridge0.present = "TRUE"
svga.present = "TRUE"
pciBridge4.present = "TRUE"
pciBridge4.virtualDev = "pcieRootPort"
pciBridge4.functions = "8"
pciBridge5.present = "TRUE"
pciBridge5.virtualDev = "pcieRootPort"
pciBridge5.functions = "8"
pciBridge6.present = "TRUE"
pciBridge6.virtualDev = "pcieRootPort"
pciBridge6.functions = "8"
pciBridge7.present = "TRUE"
pciBridge7.virtualDev = "pcieRootPort"
pciBridge7.functions = "8"
vmci0.present = "TRUE"
hpet0.present = "TRUE"
displayName = "DSM51"
extendedConfigFile = "DSM51.vmxf"
virtualHW.productCompatibility = "hosted"
numvcpus = "2"
cpuid.coresPerSocket = "2"
memSize = "2048"
sched.cpu.units = "mhz"
powerType.powerOff = "soft"
powerType.suspend = "hard"
powerType.reset = "soft"
ide1:0.startConnected = "FALSE"
ide1:0.deviceType = "cdrom-raw"
ide1:0.clientDevice = "TRUE"
ide1:0.fileName = "emptyBackingString"
ide1:0.present = "TRUE"
guestOS = "other26xlinux-64"
toolScripts.afterPowerOn = "TRUE"
toolScripts.afterResume = "TRUE"
toolScripts.beforeSuspend = "TRUE"
toolScripts.beforePowerOff = "TRUE"
uuid.bios = "56 4d 5d ff 69 41 4c 23-22 0b a6 b8 6b c5 90 91"
uuid.location = "56 4d 5d ff 69 41 4c 23-22 0b a6 b8 6b c5 90 91"
vc.uuid = "52 dc c3 cb 87 23 6b a6-ce ee ef d5 07 8f 39 69"
chipset.onlineStandby = "FALSE"
sched.cpu.min = "0"
sched.cpu.shares = "normal"
sched.mem.min = "2048"
sched.mem.minSize = "2048"
sched.mem.shares = "normal"
sched.swap.derivedName = "/vmfs/volumes/54e7a53f-1b9e4cde-3608-001018df4468/DSM51/DSM51-6485b6b9.vswp"
replay.supported = "FALSE"
replay.filename = ""
pciBridge0.pciSlotNumber = "17"
pciBridge4.pciSlotNumber = "21"
pciBridge5.pciSlotNumber = "22"
pciBridge6.pciSlotNumber = "23"
pciBridge7.pciSlotNumber = "24"
vmci0.pciSlotNumber = "33"
vmci0.id = "2138434670"
hostCPUID.0 = "0000000d756e65476c65746e49656e69"
hostCPUID.1 = "000306c30010080077fafbffbfebfbff"
hostCPUID.80000001 = "0000000000000000000000212c100800"
guestCPUID.0 = "0000000d756e65476c65746e49656e69"
guestCPUID.1 = "000306c30002080096d832031fabfbff"
guestCPUID.80000001 = "00000000000000000000000128100800"
userCPUID.0 = "0000000d756e65476c65746e49656e69"
userCPUID.1 = "000306c30002080096d832031fabfbff"
userCPUID.80000001 = "00000000000000000000000128100800"
evcCompatibilityMode = "FALSE"
vmotion.checkpointFBSize = "4194304"
cleanShutdown = "FALSE"
softPowerOff = "FALSE"
tools.remindInstall = "TRUE"
tools.syncTime = "FALSE"
ethernet0.virtualDev = "vmxnet3"
ethernet0.networkName = "VM Network"
ethernet0.addressType = "generated"
ethernet0.present = "TRUE"
ethernet0.pciSlotNumber = "160"
ethernet0.generatedAddress = "00:0c:29:c5:90:91"
ethernet0.generatedAddressOffset = "0"
toolsInstallManager.updateCounter = "2"
pciPassthru0.id = "01:00.0"
pciPassthru0.deviceId = "0x73"
pciPassthru0.vendorId = "0x1000"
pciPassthru0.systemId = "54e8722d-46bc-279c-c460-001018df4468"
sched.mem.pin = "TRUE"
floppy0.present = "FALSE"
pciPassthru0.pciSlotNumber = "192"
scsi0.virtualDev = "lsilogic"
scsi0.present = "TRUE"
scsi0:0.deviceType = "scsi-hardDisk"
scsi0:0.fileName = "DSM51_1.vmdk"
scsi0:0.present = "TRUE"
scsi0:0.redo = ""
scsi0.pciSlotNumber = "16"
ide0:0.fileName = "XPEnoboot_DS3615xs_5.1-5022.vmdk"
ide0:0.mode = "independent-nonpersistent"
ide0:0.present = "TRUE"
ide0:0.redo = "./XPEnoboot_DS3615xs_5.1-5022.vmdk.REDO_nnOqsc"
sched.ide0:0.shares = "normal"
sched.ide0:0.throughputCap = "off"
pciPassthru0.present = "TRUE"
sched.mem.max = "2048"
Open a ssh terminal, or via console, and do the following (replace sda with your drives letter):
synodisk --read_temp /dev/sda
synodisk is the util used by DSM to show drive temps.
Then try:
smartctl -a /dev/sda |grep Temperature
this is just smartmon tool.
synodisk needs real access to your HD to report temps, only works with baremetal and VTd (passthrough), doesn't work for RDM. Smartctl should report drive temps for all 3 (baremetal, VTd, RDM). If smartctl reports a real drive temp, and synodisk doesn't, then DSM doesn't like the controller you passed through for whatever reason. If smarctl doesn't report a real temp, then I guess it doesn't like your controller either :razz: or it's a driver issue.
as far as the wierd drive still showing up, you edited your syslinux.cfg wrong. Plus, you have your bootloader as a SCSI drive, so adding rmmod=piix_ata won't help (I don't think). I use IDE for the bootloader. Here's an example:
UI menu.c32
PROMPT 0
TIMEOUT 50
DEFAULT xpenology
MENU TITLE XPEnoboot 5.1-5022.1
LABEL xpenology
      MENU LABEL XPEnology DSM 5.1-5022
      KERNEL /zImage
      APPEND root=/dev/md0 rmmod=ata_piix ihd_num=0 netif_num=4 syno_hw_version=DS3615xs sn=B3J4N01003 vid=0x0EA0 pid=0x2168 loglevel=0 vga=0x305
LABEL debug
      MENU LABEL XPEnology DSM 5.1-5022 Debug
      KERNEL /zImage
      APPEND root=/dev/md0 rmmod=ata_piix ihd_num=0 netif_num=4 syno_hw_version=DS3615xs sn=B3J4N01003 vid=0x0EA0 pid=0x2168 loglevel=0 vga=0x305 debug=1 console=ttyS1,115200
LABEL install
      MENU LABEL XPEnology DSM 5.1-5022 Install/Upgrade
      KERNEL /zImage
      APPEND root=/dev/md0 rmmod=ata_piix ihd_num=0 netif_num=4 syno_hw_version=DS3615xs sn=B3J4N01003 vid=0x0EA0 pid=0x2168 loglevel=0 vga=0x305 upgrade=5.1-5022
dsm51> synodisk --read_temp /dev/sdb
disk /dev/sdb temp is -1
smartctl -a /dev/sdb
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
 1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
 3 Spin_Up_Time            0x0027   196   176   021    Pre-fail  Always       -       7183
 4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       59
 5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
 7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
 9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       453
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       59
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       57
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       664
194 Temperature_Celsius     0x0022   119   107   000    Old_age   Always       -       33
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
It seems smart is working just not via syno.. sigh...
And about the wird drive, i might not have been clear enough...
when i assign one 4tb disk as hotspare it dosnt show up as hotspare in the "storage manager/HDD SSD" section or in the "storage manager/overview" and also not in the "Control panel/Info center/Storage" so i dont know if the drive is actually assigned as hotspare or not.
I have digged a little further into this....
using the smartctl tool - i hav been able to detect that even thou the evenlog in dsm say that it have exited hibernation i have never actually entered hibernation, (the spin-up count) stays the same...
and this is really wird - i have managed to install iotop aswell... and here is the log - its a bit long, but i think it shows something very interesting...
when hibernation is set to 10 min, then there is activity roughly every 12 min... but if hibernation is set to 15min - then the activity occures every 17 min or so...
i was hoping that someone knows what the processes are... which is why i have included such a lengthy log..
hibernation = 10 min
iotop -boqt -d 60
16:31:22  8982 be/3 root        0.00 B/s 1702.82 B/s  0.00 %  0.10 % [jbd2/md0-8]
16:31:22 14058 be/4 root        0.00 B/s  476.79 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
16:31:22 12762 be/3 root        0.00 B/s  340.56 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
16:31:22  9428 be/4 root        0.00 B/s  340.56 B/s  0.00 %  0.00 % synologarchd -f
16:31:22 14057 be/4 root        0.00 B/s  613.02 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
16:31:22  9024 be/4 root        0.00 B/s  340.56 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
16:32:22  8982 be/3 root        0.00 B/s  272.75 B/s  0.00 %  0.00 % [jbd2/md0-8]
16:32:22 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
.. no activity
16:42:23  8982 be/3 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % [jbd2/md0-8]
16:42:23  9024 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
16:43:23 12762 be/3 root        0.00 B/s  341.05 B/s  0.00 %  0.07 % [jbd2/dm-1-8]
16:43:23 14058 be/4 root        0.00 B/s  477.47 B/s  0.00 %  0.02 % syslog-ng -F --worker-threads=2
16:43:23  8982 be/3 root        0.00 B/s 1364.20 B/s  0.00 %  0.01 % [jbd2/md0-8]
16:43:23  9428 be/4 root        0.00 B/s  613.89 B/s  0.00 %  0.00 % synologarchd -f
16:43:23 14057 be/4 root        0.00 B/s  613.89 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
16:43:23  9024 be/4 root        0.00 B/s  136.42 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
.. no activity
16:53:24  8982 be/3 root        0.00 B/s 1417.57 B/s  0.00 %  0.06 % [jbd2/md0-8]
16:53:24 14058 be/4 root        0.00 B/s  405.02 B/s  0.00 %  0.06 % syslog-ng -F --worker-threads=2
16:53:24 12762 be/3 root        0.00 B/s  337.52 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
16:53:24 14057 be/4 root        0.00 B/s  540.02 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
16:53:24  9428 be/4 root        0.00 B/s  607.53 B/s  0.00 %  0.00 % synologarchd -f
16:53:24  9024 be/4 root        0.00 B/s  202.51 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
16:53:24 30068 be/4 root      202.51 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:0]
16:54:24  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
16:54:24 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
.. no activity
17:04:25  8982 be/3 root        0.00 B/s 1435.47 B/s  0.00 %  0.09 % [jbd2/md0-8]
17:04:25 14057 be/4 root        0.00 B/s  615.20 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:04:25 12762 be/3 root        0.00 B/s  341.78 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
17:04:25  9428 be/4 root        0.00 B/s  410.13 B/s  0.00 %  0.00 % synologarchd -f
17:04:25 14058 be/4 root        0.00 B/s  410.13 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:04:25  9024 be/4 root        0.00 B/s  205.07 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:04:25 30181 be/4 root      410.13 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:2]
17:05:25  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
17:05:25 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
hibernation = 15 min
17:09:33 12762 be/3 root        0.00 B/s   68.68 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
17:09:33  8982 be/3 root        0.00 B/s  137.36 B/s  0.00 %  0.00 % [jbd2/md0-8]
17:09:33 15946 be/4 root        0.00 B/s   68.68 B/s  0.00 %  0.00 % winbindd -D
.. no activity
17:24:34 14057 be/4 root        0.00 B/s  478.79 B/s  0.00 %  0.08 % syslog-ng -F --worker-threads=2
17:24:34  8982 be/3 root        0.00 B/s  889.17 B/s  0.00 %  0.08 % [jbd2/md0-8]
17:24:34 12762 be/3 root        0.00 B/s  341.99 B/s  0.00 %  0.04 % [jbd2/dm-1-8]
17:24:34 14058 be/4 root        0.00 B/s  547.18 B/s  0.00 %  0.01 % syslog-ng -F --worker-threads=2
17:24:34 30305 be/4 root      205.19 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:0]
17:24:34 30414 be/4 root      205.19 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:3]
17:24:34  9024 be/4 root        0.00 B/s  205.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:25:34  8982 be/3 root        0.00 B/s  545.50 B/s  0.00 %  0.00 % [jbd2/md0-8]
17:25:34 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
17:25:34  9428 be/4 root        0.00 B/s  340.94 B/s  0.00 %  0.00 % synologarchd -f
17:26:34  8982 be/3 root        0.00 B/s  750.06 B/s  0.00 %  0.00 % [jbd2/md0-8]
.. no activity
17:42:35  8982 be/3 root        0.00 B/s 1432.48 B/s  0.00 %  0.08 % [jbd2/md0-8]
17:42:35 14057 be/4 root        0.00 B/s  545.71 B/s  0.00 %  0.07 % syslog-ng -F --worker-threads=2
17:42:35 12762 be/3 root        0.00 B/s  341.07 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
17:42:35  9428 be/4 root        0.00 B/s  341.07 B/s  0.00 %  0.00 % synologarchd -f
17:42:35 14058 be/4 root        0.00 B/s  682.13 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:42:35  9024 be/4 root        0.00 B/s  204.64 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
.. no activity
17:57:37  8982 be/3 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % [jbd2/md0-8]
17:57:37  9024 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:58:36  8982 be/3 root        0.00 B/s 1370.04 B/s  0.00 %  0.01 % [jbd2/md0-8]
17:58:36 12762 be/3 root        0.00 B/s  342.51 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
17:58:36 14058 be/4 root        0.00 B/s  616.52 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:58:36  9428 be/4 root        0.00 B/s  342.51 B/s  0.00 %  0.00 % synologarchd -f
17:58:36 14057 be/4 root        0.00 B/s  548.02 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
17:58:36 30414 be/4 root      205.51 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:3]
17:58:36  9024 be/4 root        0.00 B/s  137.00 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
.. no activity
18:09:38 12762 be/3 root        0.00 B/s   68.63 B/s  0.00 %  0.03 % [jbd2/dm-1-8]
18:09:38  8982 be/3 root        0.00 B/s  754.95 B/s  0.00 %  0.00 % [jbd2/md0-8]
18:09:38 15946 be/4 root        0.00 B/s  137.26 B/s  0.00 %  0.00 % winbindd -D
.. no activity
18:24:39  8982 be/3 root        0.00 B/s 1506.12 B/s  0.00 %  0.01 % [jbd2/md0-8]
18:24:39 12762 be/3 root        0.00 B/s  342.30 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
18:24:39  9428 be/4 root        0.00 B/s  342.30 B/s  0.00 %  0.00 % synologarchd -f
18:24:39 14058 be/4 root        0.00 B/s  479.22 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:24:39 14057 be/4 root        0.00 B/s  547.68 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:24:39  9024 be/4 root        0.00 B/s  273.84 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:24:39 30305 be/4 root      205.38 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:0]
18:24:39 30314 be/4 root      205.38 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:2]
18:25:39  8982 be/3 root        0.00 B/s  272.75 B/s  0.00 %  0.00 % [jbd2/md0-8]
18:25:39 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
18:26:39  8982 be/3 root        0.00 B/s  681.87 B/s  0.00 %  0.00 % [jbd2/md0-8]
.. no activity
18:42:40  8982 be/3 root        0.00 B/s 1432.62 B/s  0.00 %  0.08 % [jbd2/md0-8]
18:42:40 12762 be/3 root        0.00 B/s  341.10 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
18:42:40 14057 be/4 root        0.00 B/s  545.76 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:42:40  9428 be/4 root        0.00 B/s  409.32 B/s  0.00 %  0.00 % synologarchd -f
18:42:40 14058 be/4 root        0.00 B/s  409.32 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:42:40  9024 be/4 root        0.00 B/s  204.66 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:42:40 30305 be/4 root      204.66 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:0]
18:43:40  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
.. no activity
18:57:41  8982 be/3 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % [jbd2/md0-8]
18:57:41  9024 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:58:41  8982 be/3 root        0.00 B/s 1370.83 B/s  0.00 %  0.09 % [jbd2/md0-8]
18:58:41 12762 be/3 root        0.00 B/s  342.71 B/s  0.00 %  0.03 % [jbd2/dm-1-8]
18:58:41 14057 be/4 root        0.00 B/s  548.33 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:58:41  9428 be/4 root        0.00 B/s  342.71 B/s  0.00 %  0.00 % synologarchd -f
18:58:41 14058 be/4 root        0.00 B/s  616.87 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:58:41  9024 be/4 root        0.00 B/s  137.08 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
18:58:41 30305 be/4 root      205.62 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:0]
.. no activity
19:09:42  8982 be/3 root        0.00 B/s  747.28 B/s  0.00 %  0.00 % [jbd2/md0-8]
19:09:42 12762 be/3 root        0.00 B/s   67.93 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
19:09:42 15946 be/4 root        0.00 B/s  135.87 B/s  0.00 %  0.00 % winbindd -D
.. no activity
19:24:43 14058 be/4 root       68.49 B/s  547.89 B/s  0.00 %  0.05 % syslog-ng -F --worker-threads=2
19:24:43  8982 be/3 root        0.00 B/s 1438.22 B/s  0.00 %  0.01 % [jbd2/md0-8]
19:24:43 12762 be/3 root        0.00 B/s  342.43 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
19:24:43 14057 be/4 root        0.00 B/s  547.89 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
19:24:43  9428 be/4 root        0.00 B/s  410.92 B/s  0.00 %  0.00 % synologarchd -f
19:24:43 31958 be/4 root      205.46 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:1]
19:24:43  9024 be/4 root        0.00 B/s  205.46 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
19:24:43 31946 be/4 root      205.46 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:2]
19:25:43  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
19:25:43 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
19:26:43  8982 be/3 root        0.00 B/s  750.07 B/s  0.00 %  0.00 % [jbd2/md0-8]
.. no activity
19:42:44  8982 be/3 root        0.00 B/s 1431.85 B/s  0.00 %  0.01 % [jbd2/md0-8]
19:42:44 12762 be/3 root        0.00 B/s  340.92 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
19:42:44  9428 be/4 root        0.00 B/s  340.92 B/s  0.00 %  0.00 % synologarchd -f
19:42:44 14057 be/4 root        0.00 B/s  477.28 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
19:42:44 14058 be/4 root        0.00 B/s  681.83 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
19:42:44  9024 be/4 root        0.00 B/s  204.55 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
.. no activity
19:57:45  8982 be/3 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % [jbd2/md0-8]
19:57:45  9024 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
19:58:45 12762 be/3 root        0.00 B/s  342.96 B/s  0.00 %  0.03 % [jbd2/dm-1-8]
19:58:45 14058 be/4 root        0.00 B/s  754.51 B/s  0.00 %  0.01 % syslog-ng -F --worker-threads=2
19:58:45  8982 be/3 root        0.00 B/s 1371.84 B/s  0.00 %  0.01 % [jbd2/md0-8]
19:58:45  9428 be/4 root        0.00 B/s  342.96 B/s  0.00 %  0.00 % synologarchd -f
19:58:45 14057 be/4 root        0.00 B/s  548.74 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
19:58:45  9024 be/4 root        0.00 B/s  137.18 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
19:58:45 31946 be/4 root      205.78 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:2]
.. no activity
20:09:46  8982 be/3 root        0.00 B/s  754.89 B/s  0.00 %  0.00 % [jbd2/md0-8]
20:09:46 12762 be/3 root        0.00 B/s   68.63 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
20:09:46 15946 be/4 root        0.00 B/s  137.25 B/s  0.00 %  0.00 % winbindd -D
.. no activity
20:24:47  8982 be/3 root        0.00 B/s 1435.85 B/s  0.00 %  0.07 % [jbd2/md0-8]
20:24:47 12762 be/3 root        0.00 B/s  341.87 B/s  0.00 %  0.02 % [jbd2/dm-1-8]
20:24:47 14058 be/4 root        0.00 B/s  478.62 B/s  0.00 %  0.02 % syslog-ng -F --worker-threads=2
20:24:47  9428 be/4 root        0.00 B/s  410.24 B/s  0.00 %  0.00 % synologarchd -f
20:24:47 14057 be/4 root        0.00 B/s  615.37 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
20:24:47  9024 be/4 root        0.00 B/s  205.12 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
20:24:47 32245 be/4 root      205.12 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:1]
20:24:47 32244 be/4 root      205.12 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:0]
20:25:47  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
20:25:47 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
20:26:47  8982 be/3 root        0.00 B/s  681.87 B/s  0.00 %  0.00 % [jbd2/md0-8]
.. no activity
20:42:48 14058 be/4 root       68.17 B/s  545.33 B/s  0.00 %  0.03 % syslog-ng -F --worker-threads=2
20:42:48 12762 be/3 root        0.00 B/s  340.83 B/s  0.00 %  0.02 % [jbd2/dm-1-8]
20:42:48  8982 be/3 root        0.00 B/s 1431.50 B/s  0.00 %  0.01 % [jbd2/md0-8]
20:42:48  9428 be/4 root        0.00 B/s  409.00 B/s  0.00 %  0.00 % synologarchd -f
20:42:48 14057 be/4 root        0.00 B/s  545.33 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
20:42:48  9024 be/4 root        0.00 B/s  204.50 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
20:42:48 32244 be/4 root      204.50 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:0]
.. no activity
20:57:49  8982 be/3 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % [jbd2/md0-8]
20:57:49  9024 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
20:57:49 31946 be/4 root      204.56 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:2]
20:58:49  8982 be/3 root        0.00 B/s 1684.66 B/s  0.00 %  0.05 % [jbd2/md0-8]
20:58:49 12762 be/3 root        0.00 B/s  336.93 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
20:58:49 14057 be/4 root        0.00 B/s  539.09 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
20:58:49  9428 be/4 root        0.00 B/s  336.93 B/s  0.00 %  0.00 % synologarchd -f
20:58:49 14058 be/4 root        0.00 B/s  404.32 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
20:58:49   802 be/4 root      202.16 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:0]
20:58:49  9024 be/4 root        0.00 B/s  202.16 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
.. no activity
21:08:50 15946 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % winbindd -D
21:09:50  8982 be/3 root        0.00 B/s  754.43 B/s  0.00 %  0.00 % [jbd2/md0-8]
21:09:50 12762 be/3 root        0.00 B/s   68.58 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
21:09:50 15946 be/4 root        0.00 B/s   68.58 B/s  0.00 %  0.00 % winbindd -D
.. no activity
21:24:51  8982 be/3 root        0.00 B/s 1435.74 B/s  0.00 %  0.04 % [jbd2/md0-8]
21:24:51 14057 be/4 root        0.00 B/s  546.95 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:24:51 12762 be/3 root        0.00 B/s  341.84 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
21:24:51  9428 be/4 root        0.00 B/s  341.84 B/s  0.00 %  0.00 % synologarchd -f
21:24:51 14058 be/4 root        0.00 B/s  615.32 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:24:51  9024 be/4 root        0.00 B/s  205.11 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:24:51 31946 be/4 root      205.11 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:2]
21:25:51  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
21:25:51 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
21:26:51  8982 be/3 root        0.00 B/s  750.07 B/s  0.00 %  0.00 % [jbd2/md0-8]
.. no activity
21:41:52  8982 be/3 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % [jbd2/md0-8]
21:41:52  9024 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:41:52  1109 be/4 root      204.56 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:3]
21:42:52 12762 be/3 root        0.00 B/s  340.68 B/s  0.00 %  0.02 % [jbd2/dm-1-8]
21:42:52  8982 be/3 root        0.00 B/s 1362.73 B/s  0.00 %  0.01 % [jbd2/md0-8]
21:42:52  9428 be/4 root        0.00 B/s  408.82 B/s  0.00 %  0.00 % synologarchd -f
21:42:52 14058 be/4 root        0.00 B/s  408.82 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:42:52 14057 be/4 root        0.00 B/s  476.95 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:42:52  9024 be/4 root        0.00 B/s  136.27 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
.. no activity
21:57:53 14058 be/4 root       68.52 B/s  548.14 B/s  0.00 %  0.03 % syslog-ng -F --worker-threads=2
21:57:53  8982 be/3 root        0.00 B/s 1438.86 B/s  0.00 %  0.00 % [jbd2/md0-8]
21:57:53 14057 be/4 root        0.00 B/s  548.14 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:57:53 12762 be/3 root        0.00 B/s  342.58 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
21:57:53  9428 be/4 root        0.00 B/s  342.58 B/s  0.00 %  0.00 % synologarchd -f
21:57:53  9024 be/4 root        0.00 B/s  205.55 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
21:57:53 31946 be/4 root      205.55 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:2]
21:58:53  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
21:58:53 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
.. no activity
22:08:54 15946 be/4 root        0.00 B/s  136.37 B/s  0.00 %  0.00 % winbindd -D
22:09:54  8982 be/3 root        0.00 B/s  754.63 B/s  0.00 %  0.00 % [jbd2/md0-8]
22:09:54 12762 be/3 root        0.00 B/s   68.60 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
.. no activity
22:24:55  8982 be/3 root        0.00 B/s 1436.70 B/s  0.00 %  0.07 % [jbd2/md0-8]
22:24:55 12762 be/3 root        0.00 B/s  547.31 B/s  0.00 %  0.04 % [jbd2/dm-1-8]
22:24:55  9428 be/4 root        0.00 B/s  410.49 B/s  0.00 %  0.00 % synologarchd -f
22:24:55 14058 be/4 root        0.00 B/s  478.90 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
22:24:55 14057 be/4 root        0.00 B/s  547.31 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
22:24:55  9024 be/4 root        0.00 B/s  205.24 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
22:24:55  1463 be/4 root      410.49 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:0]
22:25:55 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
22:25:55  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
22:26:55  8982 be/3 root        0.00 B/s  681.87 B/s  0.00 %  0.00 % [jbd2/md0-8]
.. no activity
22:41:56  8982 be/3 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % [jbd2/md0-8]
22:41:56  9024 be/4 root        0.00 B/s   68.19 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
22:42:57 14058 be/4 root       68.15 B/s  545.16 B/s  0.00 %  0.03 % syslog-ng -F --worker-threads=2
22:42:57  8982 be/3 root        0.00 B/s 1362.90 B/s  0.00 %  0.02 % [jbd2/md0-8]
22:42:57 14057 be/4 root        0.00 B/s  613.31 B/s  0.00 %  0.01 % syslog-ng -F --worker-threads=2
22:42:57 12762 be/3 root        0.00 B/s  408.87 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
22:42:57  9428 be/4 root        0.00 B/s  340.73 B/s  0.00 %  0.00 % synologarchd -f
22:42:57  9024 be/4 root        0.00 B/s  136.29 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
22:42:57  1475 be/4 root      204.44 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:2]
.. no activity
22:57:57 14058 be/4 root       68.52 B/s  548.19 B/s  0.00 %  0.03 % syslog-ng -F --worker-threads=2
22:57:57  8982 be/3 root        0.00 B/s 1439.00 B/s  0.00 %  0.01 % [jbd2/md0-8]
22:57:57 12762 be/3 root        0.00 B/s  411.14 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
22:57:57  9428 be/4 root        0.00 B/s  342.62 B/s  0.00 %  0.00 % synologarchd -f
22:57:57 14057 be/4 root        0.00 B/s  616.72 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
22:57:57  9024 be/4 root        0.00 B/s  205.57 B/s  0.00 %  0.00 % syslog-ng -F --worker-threads=2
22:57:57 31946 be/4 root      205.57 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:2]
22:58:57  8982 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/md0-8]
22:58:57 12762 be/3 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [jbd2/dm-1-8]
.. no activity
23:08:58 15946 be/4 root        0.00 B/s  136.38 B/s  0.00 %  0.00 % winbindd -D
23:09:59 12762 be/3 root        0.00 B/s   67.55 B/s  0.00 %  0.03 % [jbd2/dm-1-8]
23:09:59  8982 be/3 root        0.00 B/s  743.08 B/s  0.00 %  0.00 % [jbd2/md0-8]
