I have a Thecus N7510 running very stable for about two years now.
There's one thing bugging me and that is that the two USB3 ports on the front are not working.
A fellow Thecus owner has a slightly different model (5 bays instead of 7 and less USB ports). His USB3 port on the front is working fine on his rig.
The controller is the same.
I generated dmesg > dmesg.txt -- I find:
- up to ata10 SATA entries,
- ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 11.982054] ACPI: bus type USB registered
[ 11.982648] usbcore: registered new interface driver usbfs
[ 11.982958] usbcore: registered new interface driver hub
[ 11.985305] usbcore: registered new interface driver ethub
[ 11.991474] usbcore: registered new device driver usb
[ 12.044255] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 12.064521] ehci-pci: EHCI PCI platform driver
[ 12.064717] ehci-pci 0000:00:1a.7: setting latency timer to 64
[ 12.064737] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 12.064750] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 12.064774] ehci-pci 0000:00:1a.7: debug port 1
[ 12.068711] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 12.068754] ehci-pci 0000:00:1a.7: irq 18, io mem 0xc0604c00
[ 12.073979] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 12.074639] hub 1-0:1.0: USB hub found
[ 12.074658] hub 1-0:1.0: 2 ports detected
[ 12.075091] ehci-pci 0000:00:1d.7: setting latency timer to 64
[ 12.075119] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 12.075138] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 12.075172] ehci-pci 0000:00:1d.7: debug port 1
[ 12.079124] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 12.079190] ehci-pci 0000:00:1d.7: irq 23, io mem 0xc0604800
[ 12.085009] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 12.086184] hub 2-0:1.0: USB hub found
[ 12.086215] hub 2-0:1.0: 6 ports detected
[ 12.132375] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 12.155401] uhci_hcd: USB Universal Host Controller Interface driver
[ 12.155654] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 12.155666] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 12.155691] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 12.155751] uhci_hcd 0000:00:1a.0: irq 16, io base 0x000060a0
[ 12.156752] hub 3-0:1.0: USB hub found
[ 12.156775] hub 3-0:1.0: 2 ports detected
[ 12.157182] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 12.157193] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 12.157213] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 12.157274] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00006080
[ 12.160612] hub 4-0:1.0: USB hub found
[ 12.160651] hub 4-0:1.0: 2 ports detected
[ 12.161140] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 12.161153] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 12.161174] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 5
[ 12.161238] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00006060
[ 12.166040] hub 5-0:1.0: USB hub found
[ 12.166072] hub 5-0:1.0: 2 ports detected
[ 12.166488] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 12.166501] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 12.166527] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
[ 12.166593] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00006040
[ 12.175048] hub 6-0:1.0: USB hub found
[ 12.175073] hub 6-0:1.0: 2 ports detected
[ 12.252953] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 12.252976] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 7
[ 12.258420] xhci_hcd 0000:03:00.0: irq 47 for MSI/MSI-X
[ 12.258437] xhci_hcd 0000:03:00.0: irq 48 for MSI/MSI-X
[ 12.258449] xhci_hcd 0000:03:00.0: irq 49 for MSI/MSI-X
[ 12.258461] xhci_hcd 0000:03:00.0: irq 50 for MSI/MSI-X
[ 12.258475] xhci_hcd 0000:03:00.0: irq 51 for MSI/MSI-X
[ 12.259265] xHCI xhci_add_endpoint called for root hub
[ 12.259274] xHCI xhci_check_bandwidth called for root hub
[ 12.259720] hub 7-0:1.0: USB hub found
[ 12.259750] hub 7-0:1.0: 2 ports detected
[ 12.259970] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 12.259987] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 8
[ 12.262403] xHCI xhci_add_endpoint called for root hub
[ 12.262412] xHCI xhci_check_bandwidth called for root hub
[ 12.262911] hub 8-0:1.0: USB hub found
[ 12.262941] hub 8-0:1.0: 2 ports detected
[ 12.353584] usbcore: registered new interface driver usb-storage
[ 12.410288] VMware PVSCSI driver - version 1.0.2.0-k
[ 12.410889] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 12.431553] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
[ 12.452532] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[ 12.517922] Fusion MPT base driver 3.04.20
[ 12.517928] Copyright (c) 1999-2008 LSI Corporation
[ 12.555451] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 12.555621] scsi10 : usb-storage 2-1:1.0
[ 12.555635] Fusion MPT SPI Host driver 3.04.20
[ 12.595793] Fusion MPT SAS Host driver 3.04.20
[ 12.617425] Fusion MPT misc device (ioctl) driver 3.04.20
[ 12.617736] mptctl: Registered with Fusion MPT base driver
[ 12.617745] mptctl: /dev/mptctl @ (major,minor=10,220)
So I edited my /etc/synoinfo.conf and /etc.default/synoinfo.conf
esataportcfg="0xff00000"
internalportcfg="0xfff"
usbportcfg="0xff000"
Unfortunately no USB drives are detected when inserted in either of the front USB ports.
At the end of the dmesg.txt I read:
[ 18.561705] xhci_hcd 0000:03:00.0: Timeout while waiting for a slot
[ 18.563226] hub 7-0:1.0: couldn't allocate port 2 usb_device
[ 24.562167] xhci_hcd 0000:03:00.0: Timeout while waiting for a slot
[ 24.562180] hub 8-0:1.0: couldn't allocate port 1 usb_device
Funny thing is that I can boot DSM from the front USB!
Bogey 0
I'm definitely in for some guru guidance...
Thanks,
Eddie
12 answers to this question
